Philips 220CW9 no image, power LED cycles toghether with a high pitch whine
  • sequille
    • 33
    I disconnected the LCD panel, left only the logic board and backlight connected and it stays on (white screen). The moment I connect the LCD panel it starts cycling on-off, together with a (not very loud) squeal that stops when the LED off.
    The LCD panel is a Samsung LTM220M1-L01, if this is relevant.
  • R_J
    • Jun 2012
    • 9591
    Re: Philips 220CW9 no image, power LED cycles toghether with a high pitch whine
    How about some good quality pictures of the power supply etc. and some voltage readings so we can see what you have, It sounds like the power supply can't supply the current to run the panel.
    • dskall
      • Oct 2016
      • 2905
      • usa
      Try disconnecting t-con to panel board cables one at a time and see if one side is causing problems.
      • sequille
        • 33
        Turns out that, against all appearances, it was a capacitor. Ended up replacing them all so that i wouldn't have to go through disassembly again.
        • alro7779
          Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
          by alro7779
          Hello, guys!
          The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
          09-14-2025, 12:25 AM
        • G33RT
          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
          by G33RT
          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
          It does power up when pressing the power button.
          I already try the power button while plugin the plug with no result.
          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
          Could this be an PSU or eMMC issue ?
          07-19-2025, 03:43 AM
        • karatzdi
          Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
          by karatzdi
          I know some might say... just buy another one. Sell it as parts..!
          So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
          Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
          Spent some time downloading the Service...
          06-11-2024, 08:38 AM
        • double_DD
          Philips curling iron - is this a common AC cable?
          by double_DD
          Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
          As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
          Not sure if this is something Philips proprietary, or a standard, but the cable plug...
          08-18-2025, 10:04 AM
        • janos6662000
          Philips 47PFS7509/12 LCD TV problem
          by janos6662000
          Hi
          I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
          When i applied cable signal to check image, i had normal picture, but TV was restarting.
          I downloaded original firmware and applied the update, but the problem remained.
          From a colleague i received a "factory package software" which is a lot bigger.
          I made another firmware update, but still did not solve the problem.
          Somewhere on the way the error got worse, because at the moment the...
          08-12-2025, 12:54 PM
