Re: LCD 19" BENQ T905 problems
How did you try to test the lamps? A CCFL requires about 600-1000 volts to ignite. Unless you used a tester that produces that kind of voltage, you wouldn't get any results.
PlainBill
The main fuse is rated for 250 volts because the monitor may be plugged into circuits carrying up to 230 volts. The picofuse is rated at 125 volts because it is in a circuit carrying only 12 volts.
PlainBillLeave a comment:
125V, are you positive? Cause the main fuse is 2A 250v.Leave a comment:
The picofuse for most Benq boards is 3A 125V.
We KNOW this board very well. If you don't resolder as PlainBill states, you will have problems in the future. If you look at all the Benq board posts, it is the same advice over and over.Leave a comment:
I don't see any crack in the solder joints, the fuse I replaced didn't blow again. I did not replace the pf801 . Btw what are the specs for this PF?Leave a comment:
Replace the fuse without replacing the shorted transistors and it will blow again. Replace the transistors without resoldering the pins on the 4 inverter transformers and a transistor will short again.
This inverter design is a Royer oscillator, it is used by Benq who supplies monitors to both Dell and HP. It MIGHT not have been discussed in this thread, now it is.
However you are correct about one thing. This is an excellent opportunity to recap.
And to repeat what retiredcaps said, don't post pictures inline. Use Manage Attachments below the test entry area.
PlainBillLast edited by PlainBill; 05-03-2011, 06:34 PM.Leave a comment:
I tested the PF801 (is this the pico fuse?). Strange thing happens, the tester is stuck at 1 but some times it gives values then goes back to 1. Any clue?
Benq style power/inverter boards typically have more than one fuse. The main fuse by the AC plug and the picofuse.Leave a comment:
Hello everyone, I too have a benq t905 which is not working. I opened it and I found a blown fuse so I thought the problem was easily solvable. However replacing the fuse was a no go. Lamps don't light up, I can see the faint "benq" logo when I turn on the monitor. I'm going to check capacitors tomorrow. Any advice would be useful, thanks.Leave a comment:
Seems Im the only one who couldnt repair his TFTLeave a comment:
Wanted to stop in and post and say that this helped me in repairing my monitor. Thanks to all who contributed, and contribute to other threads like this.
cheersLeave a comment:
Hi to all,
changed transistor and with 7 dollar monitor work ok...
Thanks to all in this forumLeave a comment:
Regards to all,
I'm new in this debate but I have the same problems already described for this monitor.
Thanks to your question I found the capacitor C824 signed with a bad weld
redone that has not solved the problem but after further tests I found that the two transistors
next to it are damaged (probably due to the welding missing).
I bought on EBay and just reach those components hope to be able to report that the monitor
is "alive again."Leave a comment:
Glad to hear it is working. The resoldering of the components mentioned earlier seems to be the key to keeping these monitors working.Leave a comment:
So, for the end of the story:
The soldering iron heat detached a new track for the board when i changed 1000uF caps. I had to wrap a wire.
Only the 5707 were burnt. After the soldering of transformers & various elements, the lcd is working very well.
Thank you both !Leave a comment:
I believe fast blow based on these posts ...
https://www.badcaps.net/forum/showth...benq+fast+blow
https://www.badcaps.net/forum/showth...blow#post49446Leave a comment:
Does anyone know if the 3A pico fuse at PF801 is fast acting or slow blow?
My board has STD10PF06-1 parts in the place of the IRFU9024 parts at Q805 and Q812. The difference appears to be 10A continuous drain current as opposed to the 11A for the IRFU9024.Leave a comment:
exactly 4.55$, with shipping. First i tryed to order the components at Farnells, a French (worldwide ? idk) reseller. But at the end, it was up with too much for a 'tutorial' repair:
2€ per c5707 so 4€ total
3A fuses per 10 only for 5.5€ total
2€ par 9024 - wasn't planning to buy one, but it can help -
4 € for various caps (was interested in replacing all elite's)
and 12€ of shipping...
With the Chinese eBay provider 's set, i can afford a not working c5707 in the kit, and even burn one or two more. I could wait to reach a local store for caps. Oh, i guess i'll not be shipped before next week, but this is not a problem.
Thank you for your excellent advices, Retiredcaps.Leave a comment:
The other set with 660, 900, and 100 ohms looks okay.
For the picofuse, 1 ohm, same as failed transistors. I think this is the rounding.
For 9024, i have junctions BCE going from 800 to 1200 ohms base values, always increasing (i assume they are corrects and coupled in some way with a capacitor).
Bought on ebay a set of 4x C5707 2x 9024 1x picofuse for 4 bucks. Next time for the real repairing
(btw, i have not replaced the caps except the bad shape - slightly growth - 1000uF / 10v)Leave a comment:
by CasparHi all, I am looking for some help in ID'ing some parts in an attempt to fix a power supply from a GW2780-T monitor. The power supply PN is 715G7300-P02-006-0V3R. I have been looking around for the PN and it appear the board was used by other OEMs as well (ASUS, Viewsonic). If anyone has a schematic, it would be helpful.
Quick look on the underside of the board, I can see:
-D905 is blown - ? value
-R920 is open - 1Ω ?W
-R927 is open - 20Ω ?W
On top side, I see:
-R931 open - 0.68Ω ?W
Metered short:
-P9NK65ZFP...-
on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
i don't understand the reasons of the white stripe at the bottom of the screen below the task... -
by drscootHP Modelnumber: 14-dh0061nb
This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
All these 3 batteries are charging...2 Photos -
by HondamanRecently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
(I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...-
by swergHey everyone,
I'm a novice trying to repair my laptop. The LCD screen has an image, but no LED backlight for the image. It also produces an image when connected to an external monitor.
I have found what I believe to be a blown inductor labeled "L4502" and "120 Ohm" in the schematics (zoomed in image, blue arrow to blown component). I have included an image of the general area of the mobo and an excerpt from the schematics as well.
I am having trouble selecting a replacement component, which I believe to be a 120 Ohm ferrite bead, from the components... - Loading...
