Sourcing replacement backlight SMD LEDs or Strips (LG panel)
  • cmg
    • Dec 2016
    • 32
    • United Kingdom
    Hi. I would like to gather advice about sourcing replacement SMD LEDs and/or LED backlight strip PCBs. As this is a general issue I thought we can have have a new thread.
    As you will see here, I have an HP ZR2740W 27" IPS monitor for which I need to repair or replace one of the backlight strips. The panel is made by LG. I cannot work out how to find replacements.
    I know the electrical characteristics, physical dimensions and details of the panel. I need to identify the correct replacements and find a supplier who will sell in a low qty (say 10) and ship to UK.
    The specs for the LEDs I need to find:
    Panel:
    Mfr: LG
    Panel Model: LM270WQ1-SDDA
    Backlight:
    Configuration: 2 strip PCBs each with 3 electrical strips of 12 LEDs. 35.5V each.
    Part number on PCB "SUNG WEI 20V0", "LM270WQ1 *RIGHT* WR (100223 MB27083U rev B)"
    LED chips:
    Fwd Current: 310-330mA
    Voltage: 3V
    Power: Approx 1W
    Lens: hemispherical domed yellow lens
    Package: 4 pin SMD, only 2 pins used.
    Obviously they also need to be the same colour and luminosity but I can't see specs for these. Is there at least a standard colour temp used?
    I have attached pics showing the LEDs next to a ruler. The one I have damaged (during disassembly) shows the electrical pinout.
    thanks in advance!
  • cmg
    • Dec 2016
    • 32
    • United Kingdom
    Re: Sourcing replacement backlight SMD LEDs or Strips (LG panel)
    So I found the LEDs are coded with a 4 digit number which represents the x,y dimensions in tenths of mm. For instance there is 3528 which is 3.5mm x 2.8mm.
    Mine are 3.0mm square so I'm looking for 3030 SMD. This doesn't seem very common and none of these parts have the domed lenses that the original strip has.
    I guess the LEDs for the LG panel would have been manufactured by "LG Innotek" so I will see if there is a parts division I can email.
    These are the most similar I found so far.
    Any ideas anyone? I'd also be interested to know how much it is likely to matter to get the exact same brightness and colour.
    HP's spec for the monitor says "Default color temperature 6500 K". Could I assume this is the correct colour for the LEDs?
    thanks!
    • cmg
      • Dec 2016
      • 32
      • United Kingdom
      I had naively thought that the LEDs might be generic or easy to find. This is definitely not the case. My advice for anyone else looking for backlight LEDs chips is to contact 'lelos2' on the most popular auction site. He has been exceptionally helpful and is building a database of LED part compatibility.
      • petehall347
        • Jan 2015
        • 4438
        • United Kingdom
        see if any of these match up ...https://uk.rs-online.com/web/c/displ...333020534D4426
          • 31197
          or here:
          https://www.rapidonline.com/surface-mount-power-leds
          • cmg
            • Dec 2016
            • 32
            • United Kingdom
            Hi. Thanks for the help. I think i've got the right parts on order now thanks to Mr 'lelos2' on eBay.
            I had seen the Osram ones looked similar but they were not the same. The parts he found were Lumileds LXML-PWD9N, 3W 3V 3030. They certainly are the same voltage, have the same type of lens and have the same solder pad pattern. I'm awaiting the order, so will be able to try in a couple of weeks.
            My advice is that it is really hard to find the exact correct LED, and that I found someone who was able to help locate the right part in the end!
            I realised that the other 3V 3mmx3mm ones i found simply would not fit due to the different solder pad patterns. I just looked at the data sheet for the Osram ones on RS which you posted (thanks PeteHall). These have 3 parallel strips as pads. See attached for the pads on these LEDs which seem pretty unique.
            I'm hoping these turn out to be exactly the same as the originals, and hoping i can solder them on with the hot air station OK. Both things harder than anticipated
            • petehall347
              • Jan 2015
              • 4438
              • United Kingdom
              only way i know of doing it properly is using a heat pad so the heat comes from the back of the strip
              .. i have not tried replacing single led.s yet .
              fingers crossed the light is the same as originals when you do yours .
              i have only replaced whole strips from same id number panel .
              in the manuals i have read it says replace all strips . as you will know this is too expensive even if used ones are used .never mind a set of new ones .
              • cmg
                • Dec 2016
                • 32
                • United Kingdom
                Thanks Pete.
                Well, Google hasn't shown me any hits at all that point to being able to find a replacement strip so that is not an option anyway. It is definitely special for this panel as the PCB has the panel model # on it.
                When i was trying to remove it i was focusing on the side with the A, K pins and didn't think of the huge heat pad underneath the other side. Maybe better next time as there are a handful i need to replace. I cracked the lenses off when removing the strip. I think the original fault was a dry joint on the connector (which is really weedy and fell off the PCB whist removing). All but one of the LEDs worked and the strip that was causing the PSU to shutdown was not the one with the shorted LED in.
                • vinceroger69
                  • Mar 2012
                  • 6714
                  have you got a link to the seller your using thanks
                  this is a good video showing the heat pad method but you can also use a hot air gun on the underside of the strip
                  https://www.youtube.com/watch?v=EZVQKEp6jxk
                  and from 12 minutes in on this video
                  https://www.youtube.com/watch?v=Bf5T2wwtydY
                  • cmg
                    • Dec 2016
                    • 32
                    • United Kingdom
                    Hi. The seller's page is here: http://www.ebay.co.uk/usr/lelos2
                    He's very helpful and he has lots of LEDs listed. I haven't yet got the LEDs so I can't say if they are definitely right.
                    Thanks for the videos - that was interesting. The strip i have is small and narrow (see pics). I think I'll continue to try heating from above with the rework gun. I was using the narrowest nozzle (<2mm dia); perhaps I should use a larger one and turn up the flow and/or temp. The specs for such LEDs seem to say the reflow temp should be 260C but this wouldnt budge until the station was set to about 350C.
                    thanks!
                    • petehall347
                      • Jan 2015
                      • 4438
                      • United Kingdom
                      did you add flux ?
                      • cmg
                        • Dec 2016
                        • 32
                        • United Kingdom
                        did you add flux ?
                        No. I've got flux and lead free solder paste in the mail. Actually I didn't realize flux will help with desoldering. I'm new to hot air soldering. I'm planning to solder the new LEDs on with solder paste and hot air. It is not possible to solder these with an iron as the pad is right underneath. When i get the paste and flux i'll practice with some scrap PCBs. Hopefully small SMD power transistors / voltage regs will seem similar to solder.
                        • petehall347
                          • Jan 2015
                          • 4438
                          • United Kingdom
                          hope you can get them hot enough without damaging the led.s . they are normally done with a heat pad .
                          i would use leaded solder because it melts at lower temp. . not sure if you can get leaded paste for these days though ..we used to use leaded for tinning the steel for body soldering on vehicles before they invented polyester body filler ..
                          • kc8adu
                            • Nov 2003
                            • 8832
                            • U.S.A!
                            too bad its not 3535.lots of choices.
                            btw most lcd strips i have seen are 7500-8000k
                            blueish/purplish.
                            • diif
                              • Feb 2014
                              • 6978
                              • England
                              thanks!
                              The temperature on your station display is not the temperature at the nozzle.
                              I have mine set about 380c.
                              I'd use a larger nozzle as there is less chance of damage to the LED.
                              I use a dab of flux to remove and another dab to help the reattachment.
                              I used working LEDs pulled off one strip to repair 4 strips.
                              • cmg
                                • Dec 2016
                                • 32
                                • United Kingdom
                                Thanks for the advice. I'll give it a try on some scrap PCBs while waiting for the new LEDs.
                                • cmg
                                  • Dec 2016
                                  • 32
                                  • United Kingdom
                                  OK.. I fixed it now! This was thanks to the seller mentioned above finding the right LEDs.
                                  Soldering the new ones on was very tricky indeed. The first few i did look pretty awful and eventually the don't look too far off the original ones.
                                  The LEDs were closely spaced so heating the whole strip seemed like a bad idea. The most successful method i had was to tin the pads and the underside of the LED with an iron, then melt the solder on the pads with the hot air set at 315C. Then i'd slowly lower the LED over it, keep heating for a few seconds and remove the hot air. Then go round adding solder paste and either reflowing or using the iron until the A and K were soldered well. I couldnt manage to just sit the LED there with paste and apply hot air. The LEDs got melted and/or flew off the board.
                                  • cmg
                                    • Dec 2016
                                    • 32
                                    • United Kingdom
                                    Updating this due to comments on the other thread.
                                    Pic shows the strip fixed, then tested using a little constant current source PCB (showing 33V). Finally i tested it in situ. This WAS necessary because the connector is very dodgy and once I didn't solder it very well, finding it failed again when I had reassembled the panel.
                                    • horia
                                      • Dec 2017
                                      • US
                                      I have the same issue on hp z1 g2 27” cheap Samsung. Thank you for the useful forum.
                                      • horia
                                        • Dec 2017
                                        • US
                                        Did you get the same left hand and right hand side intensity? Ty
                                        • howardc64
                                          Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                          by howardc64
                                          Failure Symptom
                                          No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                          Where is the short?
                                          Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                          Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                          05-27-2025, 02:56 PM
                                        • mc900fthanna
                                          Visio M70-C3 LED replacement strips
                                          by mc900fthanna
                                          So... I have the patchy back light issue with my Visio M70, meaning some light up, others do not. I finally got around to testing the LED driver board and found that was not the issue (swapped another one in and the same issue persisted) and I am considering if i dare dive deeper into this TV and go after the LED strips.
                                          Right away i see that they don't seem to stock them anywhere out there (E700DLB0016-002) is a part number that i see a you tube / seller guy list out. He has a nice video of how to get into my exact TV out there: https://www.youtube.com/watch?v=0AcUPiN83Tg
                                          11-28-2022, 03:03 PM
                                        • Firentiosi
                                          1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
                                          by Firentiosi
                                          Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
                                          The issues are as follows: the...
                                          11-27-2024, 12:33 AM
                                        • mecha1166
                                          75UK6190 blank screen, shorted caps on panel strips
                                          by mecha1166
                                          I have 2: 75UK6190 units. One has a broken panel - it lights up and shows a bit of graphics. The other LG tv lights up but has no video. Turns on/off ok, and I swapped all the boards to check them all. I exposed the strips on the bottom of both panels. I tested the caps along the LED strips on the bottom of the panel. About 12 smd cap chips on the tv with no video, test shorted. I talked to LG tech support but they do not repair to this level, they just replace the panel. Now, there is a Philips mainboard that a smd capacitor chip shorts and causes a squeal from the power supply, and the fix is...
                                          12-17-2021, 02:00 PM
                                        • lmcancu
                                          RCA RLDED 4331B: 43 inch LED TV: Backlight issue
                                          by lmcancu
                                          Hi I am having an issue with the LED backlight of this TV. I can see the picture with a flash light, so I determined it was a backlight issue.
                                          Initially, after opening it I found 2 shorted and 1 open LED on 2 strips (total of 4). I removed the LEDs and shorted the pads together to verify if the backlight would work.
                                          Testing it, I found the backlight turned on and I measured 54V when TV was in standby (off), and 100v when TV was turned on. The 4 strips each contain 9 LEDs, so 36 in all minus 3.
                                          Instead of putting it back together I decided to replace...
                                          04-01-2023, 01:11 PM
