Xerox XG-91D (proview I think)
  • abramcookson
    • Jul 2008
    I have two of these monitors and both have developed the same illness. In fact this same problem has been posted several times on the web. Turn on the LCD and It powers up. Then jumps to a stand-by mode (blinking blue light). This has nothing to do with the PC (I have several) it is an issue with the monitor. Not sure if its the Caps or Something else. Here goes:
  • abramcookson
    • Jul 2008
    Re: Xerox XG-91D (proview I think)
    Here are two images, I can get more (clearer if needed).
    • satfta1
      • Jun 2008
      • 4
      that part its probably a torrid , the caps usually go bad on the powerboard on the high voltage side, i would replace the 6 capacitors and retest lcd , i am confident sure this will solve your problem
      • Prioritymail
        • Jan 2009
        I have one of these monitors and the lcd screen shows a vertical line on the left side of the monitor about one inch from the edge. It runs the entire length of the screen. It only does this when the monitor is actually in windows. During start up it does not appear to do this. It seems to only be when there is color on the screen. Any ideas what the heck this can be? None of the capacitors appear to be bulging.
        • RJARRRPCGP
          • Jul 2004
          • 6304
          The cap model codes remind me of Nichicon.
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            That part is a Torrid (as said)
            That kind of Torrid is a piece if Iron based rod (the core) wrapped with wire (the winding) and then covered with heat shrink (insulation).
            They very rarely go bad. (There is nothing much to go bad.)
            They have other uses but in your photo they appear to be being used as the Inductors in PI output filters. (A common use for them.)
            Those Green caps (at least the one I can see) is a Samxon GF series.
            Samxon GF and GL series are pretty much junk.
            They go bad in LCD TVs and Monitors frequently.
            Mann-Made Global Warming.
            - Dr Seuss
            • repzak
              • Sep 2009
              • 3
              I have same monitor, that now starts to give problems, also with the green samxon caps... This monitor turns off after several hours use..
              I took some of the samxon caps out and measure the capacity, that seems ok, but ofcause the ESR can be bad... but is that normal?
              what about samxon KM series is that better?
              Kasper
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                No, Samxon's GF are low ESR and their KM aren't.
                http://www.manyue.com/samxon_series_chart.html
                Click on the series and the specs sheet will come up in a PDF.
                I would use Panasonic FM or better to replace Samxon GF.
                Panasonic FC are -usually- good enough for caps in screens but they aren't rated well enough to replace GF.
                Good luck.
                - Dr Seuss
                • Bobdee
                  • Jun 2008
                  • 461
                  Kasper
                  Had a Xerox XAP-192i that use to do the same thing, the two small inverter caps were the problem
                  Bob
                  • mido50
                    xerox phaser 3330
                    by mido50
                    I need a xerox phaser 3330 moded firmware that make the printer work without drum & carriage chips
                    12-31-2024, 12:30 PM
                  • pc_okay
                    Xerox Versalink C505 bad printing in color mdoe
                    by pc_okay
                    Hello friends,
                    I have a problem with this printer Xerox Versalink C505 , printing perfectly in B&W but bad in color.
                    There is a little yellow ghost printing around color print.
                    So little text in color is unreadable.
                    I already change drum cyan & yellow with no success.
                    I try (i think) all avalable calibration in printer menu..
                    (black drum is dead but it's not the problem i think)
                    I'm not a printer specialist,if anyone has an idea?
                    Thanks !...
                    12-01-2024, 09:08 AM
                  • Blunttag
                    Fuji Xerox CM405df Print Quality Issue
                    by Blunttag
                    Hi
                    I having issue diagnosing a print quality issue with this printer my sister picked it up off facebook market place saying in full working condition (she got scammed) it came with Magenta, Cyan, Yellow, missing Black toner so bought a cheap one off ebay the cartridge that came were around 30% toner box and drum are at 100% and the printer does print.
                    anyone know what the issue could be?
                    please see pictures for example...
                    08-01-2022, 07:31 PM
                  • habaso
                    Xerox M20i power supply repair - KA7553
                    by habaso
                    I am trying to repair SPMS based on KA7553.
                    Schematics (not exactly the same, but almost same usage of KA7553)
                    SPMS cycling, it produce correct output voltage, than goes down.
                    Red - output voltage
                    Blue - gate of MOSFET
                    Please advice what to check else? Datasheet of KA7553 is really not so informing. I have checked both FB and CS of KA7553 and as I understand datasheet, both of these inputs are lower than threshold voltage of overload or overcurrent shutdown.
                    02-02-2022, 12:59 PM
                  • Lwolffe
                    Xerox XG-91D (Proview)
                    by Lwolffe
                    I have a Xerox XG-91D, I believe is made by Proview. When I turn the monitor on cold it will stay on for 12-15 minutes, then go black. The led will stay on but no screen, pushing the button doesn't do anything but if I unplug it and plug it back in it will stay on for 2-3 minutes. I suspect power supply, I tore the unit apart and found a chip on the power supply board with the markings BD5A28 (near as I can tell) the one leg is burnt and part of the silicone is missing. I think its a rectifier but could be wrong. My local electronics shop doesn't have a listing for this part. I have goggled, yahooed,...
                    07-08-2008, 03:36 PM
