Xerox XG-91D (Proview)
  • Lwolffe
    • Jul 2008
    I have a Xerox XG-91D, I believe is made by Proview. When I turn the monitor on cold it will stay on for 12-15 minutes, then go black. The led will stay on but no screen, pushing the button doesn't do anything but if I unplug it and plug it back in it will stay on for 2-3 minutes. I suspect power supply, I tore the unit apart and found a chip on the power supply board with the markings BD5A28 (near as I can tell) the one leg is burnt and part of the silicone is missing. I think its a rectifier but could be wrong. My local electronics shop doesn't have a listing for this part. I have goggled, yahooed, and dogpiled. Are those words? But could not find anything about it. I have looked at the part number many times and believe that is the correct number.
    1 can anyone help me with info on this part and any cross reference on it?
    2 When changing this part is there another component that I should look at replacing with it?
    3 What would cause this part to fail? Power surge?
    Thanks for any help anyone can give me
    Lwolffe
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Xerox XG-91D (Proview)
    always post pics.
    • Malcolma172
      Philips 42pfl6008s/12 red led comes on for a second and then goes away but 3.49v stay active
      by Malcolma172
      I was trying to repair my tv wich previously had a blinking red led 2 times and it kept going. After shorting the sdm the blinking led changed 5 slow blinks and 3 fast ones wich in the service manual meant error 53 / the fusion chip.
      After I heated the fusion chip with a hairdryer for 5 minutes it started working perfectly but after a day it stopped this time no led blinks even in sdm mode.
      After probing the psu I have 3.49v and for 1 second I have at least 2 12.3v lines active the fusion chip gets warm in that second the led turns on and then the 12v lines start losing power...
      07-23-2025, 01:20 PM
    • mido50
      xerox phaser 3330
      by mido50
      I need a xerox phaser 3330 moded firmware that make the printer work without drum & carriage chips
      12-31-2024, 12:30 PM
    • pc_okay
      Xerox Versalink C505 bad printing in color mdoe
      by pc_okay
      Hello friends,
      I have a problem with this printer Xerox Versalink C505 , printing perfectly in B&W but bad in color.
      There is a little yellow ghost printing around color print.
      So little text in color is unreadable.
      I already change drum cyan & yellow with no success.
      I try (i think) all avalable calibration in printer menu..
      (black drum is dead but it's not the problem i think)
      I'm not a printer specialist,if anyone has an idea?
      Thanks !...
      12-01-2024, 09:08 AM
    • Hannibal_Hector
      Samsung UN39EH5003FXZA won't stay powered off
      by Hannibal_Hector
      Purchased a broken Samsung UN39EH5003FXZA (Version CD01) to have fun fixing. When I first acquired it, I did not connect any video signals and only plugged it into the wall. The unit booted and showed the “no signal” window and I could navigate all menus and change sources. I unplugged it, connected my over-the-air antenna to the coax, powered it on, got the unit to scan the HDTV channels, and I think then the TV self-shutdown with the melody. When I powered back up (melody), it would show the channel selected on the OSD and after a couple of seconds, it self-shutdown...
      03-02-2021, 07:57 PM
    • mferna14
      MacBook A1707 820-00928-A does not stay on
      by mferna14
      Hi., I am working on a MacBook A1707 820-00928-A does not stay on. It shuts down by itself after about 40~45 sec. The amps it takes is so normal .80 ~ .45 ~ .90 within this span of time & all voltages VCORE CPU core present, the CPU & GPU both get warm & then back to 20v 0.0amp. The logic board is like brand new, not even much dust on it. Upon trouble shooting, I see that 3.3V is always present but when the logic board shuts down 5v also drops to 0 & no CORE voltages present. I checked every single point of the 5v rail, physically nothing seems to be shorted. Any tips will be really...
      06-09-2023, 04:51 PM
