Xerox M20i power supply repair - KA7553
  • habaso
    • Feb 2022
    • 9
    • Česko
    I am trying to repair SPMS based on KA7553.
    Schematics (not exactly the same, but almost same usage of KA7553)
    SPMS cycling, it produce correct output voltage, than goes down.
    Red - output voltage
    Blue - gate of MOSFET
    Please advice what to check else? Datasheet of KA7553 is really not so informing. I have checked both FB and CS of KA7553 and as I understand datasheet, both of these inputs are lower than threshold voltage of overload or overcurrent shutdown.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8339
    Re: Xerox M20i power supply repair - KA7553
    Is it doing that cycling with or without a load?
    • habaso
      • Feb 2022
      • 9
      • Česko
      Without load.
      BUT I have to write as well, SPMS is more complex than schematics, from 5V it has to produce some other voltages, even high for blade etc. When trying optocoupler I have tested 5V "voltage injection" and there was not problem with that, so I hope there is no shortage inside this other following parts of SPMS.
      KA7553 was replaced, all capacitors were replaced as well with optocoupler.
      Red 5V voltage line
      Blue VCC of KA7553
      Red 5V voltage line
      Blue FB pin 2 of KA7553
      Red 5V voltage line
      Blue CS pin 8 of KA7553
      • R_J
        • Jun 2012
        • 9602
        What are the voltages? and what is the VCC voltage? Also were there any failed components that were replaced?
        The vcc shows 12.6v that is too low.
        • habaso
          • Feb 2022
          • 9
          • Česko
          Capacitors were replaced, but I could not find wrong between them.
          KA7553 and optocoupler were replace in attempt to solve problem, but SPMS stays in same state, so I think they were good before.
          VCC you can see on picture, 1 oscilloscope "click" is 5V, co VCC cycling up and down between 9V and 16V. I do not know if this VCC cycling is OK a what caused it.
          Do you think it can bee caused by zener diode?
          • R_J
            • Jun 2012
            • 9602
            The vcc voltage explains why it is operating the way it is, when it reaches 16v the ic starts, when the voltage drops to 9v it goes into under voltage shutdown. Check that the feedback (PVD3 diode in schematic) is ok. check that the transformer winding is not open, check the diode and also any resistor in that circuit. Usually the capacitor (47µf) is bad (open) and does not charge to maintain the vcc voltage.
            • habaso
              • Feb 2022
              • 9
              • Česko
              47uF 35V capacitor was replaced.
              Both diodes seems to be OK using multimeter diod testing, but I do not know if zener diod working on correct parameters now as new one.
              • habaso
                • Feb 2022
                • 9
                • Česko
                Both PVD3 and zener diode are open one way and closed other and show around 600mV voltage drop open way using multimeter diode test.
                Would you like to see some oscilloscope measured signal i.e. from not vcc side of PVD3 diode?
                • R_J
                  • Jun 2012
                  • 9602
                  PR11 & PR12 supply the initial VCC voltage from the main filter capacitor. When the ic starts, the VCC is then supplied by PVD3. It is possible PZD2 or PZD3 is leaky and zenering at a lower voltage. ZD2 seems to be a 20v zener.
                  the zeners can check good as diodes but might start to conduct at 16v shutting down the vcc
                  • habaso
                    • Feb 2022
                    • 9
                    • Česko
                    My real circuit is little bit different, there is PVD3 and powering part of circuit, but VCC is directly by zener diode (like PZD3, but without PC32, only with PC12) connected to ground.
                    I had take out this VCC grounding zener and VCC still cycling between 9V and 16V.
                    • habaso
                      • Feb 2022
                      • 9
                      • Česko
                      I had tried to help with powering KA7553 externally by voltage injection. With such VCC supported with voltage injection it stays OK, so there is no problem in following circuits, only somewhere in VCC part of KA7553 surroundings.
                      With VCC voltage injection
                      Red 5V output
                      Blue VCC of KA7553
                      Without VCC voltage injection
                      Red 5V output
                      Blue VCC of KA7553
                      • habaso
                        • Feb 2022
                        • 9
                        • Česko
                        Changed PVD3 diode (which is 1A SUPER FAST RECOVERY RECTIFIER SF10-02) and SPMS seems to be OK, problem solved, tomorrow morning I will try in printer and will see.
                        Thanks for help
                        • Tynan Dill
                          by Tynan Dill
                          Assuming...
                          11-22-2024, 01:46 PM
                          Adjustable Boost Power Supply DC-DC Constant Voltage Current Charging Module
                          I want to know if I could hook up a solar panels to this boost converter would I have any issues doing and I would have issues what would they be
                          https://www.ebay.com/itm/116497313155?var=416785404161
                          Here are some of the description from the eBay seller
                          The main parameters:
                          1. Product name: High-power non-isolated DC boost module power supply.
                          2. Product model: 100A2000W.
                          3. Input voltage: DC12V-60V.
                          4. Input current: 100A (maximum)....
                          05-18-2025, 09:45 AM
                        • Jembang
                          coocaa 50S5G smart tv dropped voltage when connecting power supply to mainboard
                          by Jembang
                          good day hoping someone can lend a hand, im repairing smart tv 50 inch, status when turning on back light is dim but you can see the tv logo then slowly fading out to black, i check the supply to tcon, i only read 5+v, must be 12v, i removed lvds cable and check voltage to mainboard turned on its also 5v, then i remove the cable mainboard to power supply, i read 12v in power supply, thinking that the problem is in the mainboard, coz theres 12v in power supply, i also check while turning on checking volts in main board 12v dropping to 5v, im just new repairing in TV, hope someone see my post t...
                          11-01-2024, 09:55 AM
                          LM358 LM358S-13 Datasheet
                          The LM358 LM358S-13 consists of two independent, high gain, internally frequency compensated operational amplifiers which were designed specifically to operate from a single power supply over a wide range of voltages. Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage.
                          Application areas include transducer amplifiers, dc gain blocks and all the conventional op amp circuits which now can be more easily implemented in single power supply systems. For example, the LM358 series can be directly...
                          10-07-2024, 04:12 AM
                          How to modify a switching power supply that has voltage/current adjustable but powering it from a battery pack
                          I have been pondering this question for a while but now I have see if this doable but I need to answer this question once and for all
                          I would like to know how to safely do this undertaking my first thought is to solder wires to the main filtering capacitors and see
                          what voltage I am getting and seeing if I can build a battery pack with voltage or not and if
                          I can find a BMS balancing protection board at this voltage level and weather or not do I have use more than one BMS balancing protection board...
                          05-11-2025, 05:22 PM
