Benq FP51g turning off completely after few seconds
  • Joe Black
    eager to learn
    • Sep 2015
    • 173
    • southeastern europe
    Just as in title. When power ON is pressed, it turns on, but just to turn off after 4-5 seconds... (no LED, no faint image, no nothing... dead as dodo.)
    It will work OK, after 10 minutes of ON-OFF cycles, though.
    However, when I heat up upper right corner of the board with blow-dryer, it works perfectly every time. (those 5 elcos, inductor and diode)
    Tested caps on ESR,they all look good. Tried replacing (with used ones, but known good), no result. But heating up works as charm.
    Apart from caps, I don't know what else to try.
    (tried resoldering all in that area-no result)
    Thanks in advance for ideas!
    stay classy
    Re: Benq FP51g turning off completely after few seconds
    'But heating up works as charm' heated the top side or the bottom side of the board?
    You have some SMD parts on the bottom side that may be affected by heat.
    BTW, when it does not work, do you lose the Voltage feeding the main board too, or lose the control signals from the main board?
    BTW, did you replace the main filter cap? Isn't standing it up will still fit into the chassis?
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Some solder joints to me dont look so good either on the power devices. Try resoldering them:
      • Joe Black
        eager to learn
        • Sep 2015
        • 173
        Heating only corner of the board, directly into caps.
        Will check and report tonight or tommorow (GMT +2)
        Replaced it a year ago or so, worked good till now. It fits easily
        ...and will do some more resoldering as sugested.
        Thanks, guys! You rock!
        stay classy
        • Joe Black
          eager to learn
          • Sep 2015
          • 173
          Here goes nothing
          Monitor turns on, and shuts down immediately as backlight is lit.
          On the connector to control board I measure 3.4 V, which drops for a second when backlight is lit, and stabilizes back as it shuts down. (I think it drops to 0V, but DMM can't catch it that fast).
          Also, there's a fuse or something (pf 751) above the heatsink (cant be seen on pic) which reads near 0 Ohm, but as backlight turns on jumps to 170 Ohms or so, and back to zero as backlight shuts down.
          Confirmed that heating with hair dryer works, but now picture gets lost, only the LED stays lit. (Was working good before if I heat corner with output caps, now it wont shut down completely but still loses image)
          Resoldered mosfet receey pointed to. Immediately after that, monitor worked flawlessly, for a 10 or 15 mins. Then it all broke down again Tested mosfet -OK.
          Tried to pull output caps out one at a time, no difference in behaviour whatsoever.
          Got frustrated at myself 'cause I just seem to make no progress in repair skills, although I did some monitors before, and read a lot, every time it seems like I never did anything like this before.
          Get confused so easily for whatever reason
          stay classy
          • Joe Black
            eager to learn
            • Sep 2015
            • 173
            If I unplug either CCFL bulb, monitor will stay on, but without any light, just dark image that can be seen under flashlight...
            I can unplug any bulb, and it works, logically bulbs are OK? (monitor won't shut down with upper plugged in nor with lower plugged in, just shuts off with both)
            Meanwhile, changed caps to new, checked unfamous c5707s and their caps, and it seems power supply is OK...
            stay classy
            • lion_sta
              • Apr 2016
              • 48
              • Moldova
              I saw in many videos that we should check that there are 12V and 5V on the appropriate exits. But there are no indication which one is ground and which ones are 5 and the 12.
              How can we deduct that?
              • Joseph cauchi
                jccomputers
                • Jan 2015
                • 89
                • Malta
                Check capacitors C723 and C739 sometimes the Benq have this problem I think these are 33j 6KV these are for backlight.
                • Joseph cauchi
                  jccomputers
                  • Jan 2015
                  • 89
                  • Malta
                  Sorry I think I mixed the caps these are 15j 3kv
                  • Joe Black
                    eager to learn
                    • Sep 2015
                    • 173
                    They are both 27J 3KV and measure 30 and 31 pF on ESR meter, repsectively.
                    Here is the shematics if someone experienced wants to take a look
                    stay classy
                    • viziks
                      • Mar 2012
                      • 33
                      • India
                      What you are saying is that if either of the lamp lights up,the monitor switches off.
                      Please check voltage on big mains filter 68uf 450V which should be stable around 320V. If this voltage drops when backlight lights up ,the Capacitor needs to be replaced.
                      • Joe Black
                        eager to learn
                        • Sep 2015
                        • 173
                        Well, technically, lamps only light up in pair, I can't light up single one because when i unplug one the whole inverter wont start. But yes, when they light up (they both are lit for that half a second) monitor instantly switches off (no led).
                        Checked large cap, V is rock solid, doesn't drop at all.
                        stay classy
                        • M.Malone
                          LG OLED C7P55 - keep turning off after 15-30 seconds.
                          by M.Malone
                          Sound and screen work while it is on.
                          I attempted to troubleshoot the power cable by unplugging it and pressing the power button for 10-30 seconds before trying to turn it on again. However, the problem persists.
                          I removed the back cover and tried replacing the power board, but the problem did not get fixed. Although, for a brief moment, it seemed like the issue was resolved as the TV stayed on for 5 minutes before reverting to turning off after 15-30 seconds.
                          I attempted to replace the T-CON board, but each time I turn the TV on with a new T-Con board,...
                          09-15-2023, 04:23 AM
                        • kalemaroni
                          BenQ 3501R turns off after 1-2 seconds
                          by kalemaroni
                          The capacitor on the board was slightly bulged at the top so I replaced. Unfortunately the cap I bought on eBay was much thinner than the original, even though the spec was the same (4.7uf 100v). The problem persists. Would the thickness of the cap actually make a difference - is it worth trying to find the correct one?
                          11-19-2024, 11:55 AM
                        • xZeroCool
                          Biostar A320MH Ver 6x - Turning off on random seconds/minutes
                          by xZeroCool
                          Hi, I've got a Biostar A320MH Ver 6x. This motherboard basically turns off by itself even if I'm only in the BIOS Screen.
                          Sometimes it will just turn on but no display, but if it POSTed it will show CMOS Fail everytime.
                          The things I did to try fixing the problems with no luck.
                          1. Changing CMOS Battery
                          2. Reflash BIOS CHIP with latest bios file using desoldering method.
                          3. Check voltages and it is just normal.
                          Any ideas what the problem might be?...
                          07-20-2024, 11:12 PM
                        • PowellSkier
                          Harman/Kardon AVR 645 returning to stand-by after a few seconds.
                          by PowellSkier
                          A Harman/Kardon AVR 645 repair has been a hobby of mine for the past several years. My latest attempt involved the purchase of a DOA unit for part swapping and testing. The original AVR would power up then shut down after a few seconds. I completely tore down both units, found a couple of bad components and reassembled one of them. Same issue, no speakers connected. After extensive research I found a repair document from Harman/Kardon that explains the protection circuit in fantastic detail and provides specific test points for each fault (power, DC detection, overload & power) and the voltage...
                          06-17-2024, 11:43 AM
                        • Scenic
                          Thinkpad T14 Gen1 (Intel ; NM-C931) fan not working
                          by Scenic
                          Got a weird issue with a Thinkpad T14 Gen1 motherboard out of/currently still in a scrap machine (cracked display, damaged case, otherwise working) that I bought to rob parts from for another thinkpad.
                          The motherboard generally works (booted into a test install of Win10 with no issues), however the fan never spins during use. It does spin for about 2 seconds right after turning on the laptop, but after that, never again.
                          Just to double-check, I've tried a different (known working) fan from a T14 Gen2 and it does the exact same thing when plugged into this mobo, and the fan from...
                          06-29-2025, 04:02 PM
