Proview PL926Wbi 19" LCD no picture
  • chuck567
    • May 2008
    • 14
    Re: Proview PL926Wbi 19" LCD no picture
    LOL! Yeah it sucks when a bulb blows right in the middle of something.
    Anyways my brother lives about 45 minutes away so I didn't go all the way over there just to take his monitor a part again, so I decided to do a visual on the backlights to see if I could see anything physical. The short answer is I would like to apologize for not heeding the advise of earlier posters that suggested the backlights being the problem. When I took the top light off they were actually burnt in off at one end the bottom ones while not as bad I could see a hairline crack on one at the end. So it looks like the backlights may in fact be the problem. Again I apologize as I can be extremely anal and dismiss good ideas, a mistake that I shall not make again.
    Does anyone know where I can get some new backlights?
    Chuck
    • Krankshaft
      • Jan 2007
      • 2328
      You will need to measure the diameter of the tubes and the total length.
      This site sells them:
      http://www.ccfldirect.com/ccfls.html
      I'm sure typing CCFL lamps on google will yield more results as well.
      • chuck567
        • May 2008
        • 14
        Apparently these are an odd ball size or something, 2mm x 417mm, I suppose my micrometer may be a little off though because I can't find anything close to this length in 2mm. Closest thing I can find is 2.6mm! Think it would pose a problem if I use the 2.6mm It looks like I would have the room.
        • Falseadress
          • May 2008
          Hey guys,
          I got a ProView PL926FW
          Google didn't provide any help with this one. I just ripped it apart and i saw 4 x 470uf Capcitors dead and 1 220uf Capcitor dead. Theese are samxon capacitors. It probally died because of the heat.I repalced it with 85c ones because i ran out of the 105c ones. It worked perfectly fine. I don't know if hardware are similar but they look similar on the outside. Just less connectors?
          • Krankshaft
            • Jan 2007
            • 2328
            If they were Samxon caps they probably were GF series Samxon is a known good brand but that series was one of their bad apples.
            Like Nichicon's HM series screwup in 2004. They sent a bunch of 360s to their grave.
            Now even after Nichicon cleared up the problem the 360s now use Rubycons .
            I would be careful with 85 C caps it gets pretty toasty inside LCD inverters and I wouldn't be suprised if they bulged too in time.
            Most likely the caps you replaced the old ones with were General Purpose caps.
            The caps that should be in there are low ESR caps.
            From my experience I have never seen a Low ESR cap rated at 85 C.
            I personally use Panasonic FCs for inverter recaps.
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              #26
              i just recapped a gateway 21" widescreen that was full of samxon gf.
              every one of em bad.even the small ones in the primary.
              late 06 date on the unit.
              agreed 85c caps are likely general pupose and will not last here.
              at least you know it works and is worth a parts order to badcaps or digikey.
              • arneson
                • Sep 2005
                • 1267
                #27
                I've been gone some time and want to ask about the samxon caps.
                The gf's are suspect, assumed bad?
                Jim
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  #28
                  yep.
                  pure junk.
                  • bLampert
                    • Jun 2009
                    #29
                    I know this was posted last year but I gotta give it a shot. like chuck567, I have the exact same monitor with the same problem kinda. When i plug the monitor in the comp. It turns on for like 3-4 sec. then goes blank. While its on the whole screen is a light pink tint. From other forums, some think its the bulbs and some think its the caps. Right now I have everything completely apart. (I can take pics if needed) I'm not sure where to start. You people are saying its the caps but how can I tell if the caps are bad or not? I also did find a site where i can buy the bulbs if needed. Hope someone reads this soon. Thanks!!
                    -Bill
                    bLampert@gmail.com
                    • Bobdee
                      • Jun 2008
                      • 461
                      #30
                      -Bill
                      bLampert@gmail.com
                      From what you posted that sounds like faulty CCFLs for sure
                      Can you get another backlight unit that works to connect to Inverter to see if they stay on, also there is a kit for testing backlights, info is on the forum, someone will give you info on that as I have never used one
                      bob
                      • Bobdee
                        • Jun 2008
                        • 461
                        #31
                        Found info on kit, go to this link
                        https://www.badcaps.net/forum/showth...&highlight=kit
                        read postings numbers 24 through to 42
                        bob
                        can I take it that when monitor comes on for seconds that you do get image???
                        • Krankshaft
                          • Jan 2007
                          • 2328
                          CCFLs emitting pink or red hue is a sign that they have reached the end of their useful life.
                          An external test of the backlights would confirm this as Bob said. Since you want to make sure the inverter is driving the CCFLs properly.
                          If the lights are shot it probably is the inverter protection kicking in due to the bad backlights.
                          Replacing CCFLs is delicate work and you don't want to rip into your panel if you don't have to.
                          • EGuevarae
                            • Nov 2008
                            • 1336
                            I've seen this on several units of this model, and on almost every Polaroid TLA-XXXXX LCD TV I had come to check (except one). The red/pink hue indicates one of the lamps is dying.
                            There are 10 kind of people in this world: those that understand binary, and those who don't.
                            • ASUS ROG Maximus IX Code
                            • Intel Core i5-7600K 3.8GHz
                            • 16gb GSKILL TridentZ RGB DDR4-3200
                            • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
                            • Windows 10 Pro x64
                            • GeForce GT1050
                              2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
                            • bLampert
                              • Jun 2009
                              #34
                              Wow guys, thanks for all the responses. I'm very delicate when taking apart monitors. I've fixed some in the past with known bad caps and soldered them myself and poof, works! but this is my first encounter with bulbs. I'm at the point where I have the brackets off the edges of the LCD and seeing the bulbs itself. I was seeing if I could buy some locally but store such as Menards, Ace Hardware etc... didn't have them. So I guess I gotta purchase some from online. I see that each bulb ranges from about $6 and up. Does anyone know a good, cheap site I can buy some off of? I figured out the size I need is 2.6mm(D) x 414mm(L) bulbs. Again thanks for all the help your offering, i'll be sure to...."pay it forward" (haha)
                              -Bill
                              • Bobdee
                                • Jun 2008
                                • 461
                                #35
                                -Bill
                                Hello Bill
                                Read this thread it will help you with your task also a couple of links in there as to where to buy CCFLs, should help
                                bob
                                • xtraelectronics
                                  • Apr 2009
                                  • 49
                                  #36
                                  I've got a 22" Proview (2200W) on the bench, it would stay lit for 10 seconds, then go black. (With a pink tint when lit). Connected my "test ccfl's" and they stay lit indefinately. The top ccfl inverter was running hot, (dark spot on the PCB around the driver MOSFET). Caps test ok. Too much current draw from the top ccfl. I then left the tester on the bottom inverter and connected the original (top) 22" tube, same thing, 10 secs to black. Then dismantled the screen assy and found the top ccfl was black on the end, so it is def. bad. Now looking for new/good used ccfl's.
                                  • EGuevarae
                                    • Nov 2008
                                    • 1336
                                    Not necessarily. Do you have a spare CCFL?
                                    • GeForce GT1050
                                    • Tr0ll
                                      by Tr0ll
                                      Original T-con:
                                      First replacement T-con:
                                      10-07-2023, 07:48 PM
                                    • JJAAMM
                                      by JJAAMM
                                      Problem
                                      07-06-2023, 06:01 AM
                                    • TR103
                                      by TR103
                                      - it keeps rebooting
                                      01-22-2025, 04:12 PM
                                    • Mgiffune
                                      by Mgiffune
                                      06-09-2024, 10:28 AM
                                    • CyberPhoenix
                                      Issue with picture quality of Sony bravia TV
                                      by CyberPhoenix
                                      Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                                      01-22-2024, 02:08 AM
