Proview PL926Wbi 19" LCD no picture
+ More Options
Posts
  • chuck567
    • May 2008
    • 14
    My Proview PL926Wbi 19" LCD will turn on and work fine for a wile and then starts flickering a bit until it loses it's picuture. After it loses the picture if you turn it off and then back on it will have a picture for about 3 seconds before losing it's picture again. Power light stays on solid at all times. I have checked the the inverter board and vga card and there are no signs of overheating, bulging/busted caps or solder fractures. Also when holding a bright light to the screen you can still see the image. I am kind of at a loss for what to do next. Any help would be much appreciated.
  • Newbie2
    • Sep 2005
    • 885
    Re: Proview PL926Wbi 19" LCD no picture
    The backlights in the LCD panel may be bad.
    My gaming PC:
    AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
    ASUS M4A77TD AMD 770 AM3 Motherboard
    PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
    G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
    TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
    WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
    ASUS Xonar DG 5.1 Channel PCI sound card
    Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
    Antec Three Hundred Mid-Tower Case
    Microsoft Windows 10 Pro 64-bit
    Microsoft Windows 7 Ultimate SP1 64-bit
    • chuck567
      • May 2008
      • 14
      Since the lights actually light up I wouldn't think it's the lights themselves. It seems like more of an inverter problem from what I have been able to find on the subject. I just can't find any obvious problems. I am hopeful that someone here may be a little more advanced than I am and can set me on the right path.
      • Krankshaft
        • Jan 2007
        • 2328
        Capacitors can fail without bulging the tops in some instances and they only way to sniff them out is with an ESR meter.
        This tool is around 70 bucks so its just more economical to replace all of the caps on the secondary side of the inverter and rule them out.
        However bad caps aside problems like this can also arise from bad solder joints on the inverter board.
        These boards get pretty hot in operation and the thermal shock the joints have to go through with the inverter heating up an cooling down due to powering the LCD on and off can crack some joints.
        • chuck567
          • May 2008
          • 14
          I will just go a head and change the capacitors. As far solder fractures I don't see any would they be visible or is there another way to find them?
          • Krankshaft
            • Jan 2007
            • 2328
            I just go over the board with a magnifying glass very slowly if this is what you've already done you can rule them out.
            If you still have problems after the recap let us know and we can go from there.
            You'd be suprised how many times the problems you describe are from these 2 main causes.
            • chuck567
              • May 2008
              • 14
              Usaully I just buy kits of capacitors but I haven't been able to find any kits for this board. Any suggestions as to brand and series?
              I need the following sizes.
              470uf 25v 105c 10mm X 16mm
              220uf 25v 105c 8mm X 12mm
              47uf 50v 105c 6.3mm X 11mm
              100uf 400v 105c 18mm X 32mm
              220uf 25v 105c 8mm X 8mm
              10uf 50v 105c 8mm X 5mm
              Any advice is appreciated.
              • Krankshaft
                • Jan 2007
                • 2328
                Here you go:
                That is the Panasonic FC datasheet they can be ordered from Digikey that datasheet lists the sizes of their caps.
                Just make sure that when you order from them that you compare the manufacturers part number on the datasheet to the one you are buying since many cap values in the FC series come in different case sizes.
                For example your 470 uf 25 volts at 10 X 16mm would be Panasonic part number: EEUFC1E471.
                You can also do the same with any other top tier cap manufacturer just find one of their low ESR series caps and get their datasheet.
                • chuck567
                  • May 2008
                  • 14
                  I ordered them so they should be here in a couple of days or so.
                  Does it matter on the overall height of the cap?
                  Example:
                  If the current cap is 220uf 25v 105c 8mm X 8mm
                  Would it be okay to us 220uf 25v 105c 8mm X 12mm
                  or does th height need to be the exact same?
                  • chuck567
                    • May 2008
                    • 14
                    Also I noticed that a couple of the smaller caps don't have vents but otherwise are identical in appearance. Name brands appear different as well NEC on the larger caps and Xunda on the smaller ones without vents. Would the smaller non-vented caps still be electrolytic or some other type of cap?
                    • Krankshaft
                      • Jan 2007
                      • 2328
                      The height doesn't matter you just have to make sure that the cap isn't too large.
                      I remember when I used to order caps without measuring first then afterward my monitor cover wouldn't fit because I installed a cap that was too large.
                      If you are going to use a different size make sure that there is enough clearance to put the rear cover back on.
                      Thats why I always measure the original caps with a digital micrometer first especially in cramped quarters like inside a monitor.
                      The smaller caps are also electrolytic however the reason that they don't have vents is because they don't contain enough electrolyte to burst the can.
                      So the manufacturers don't score the top like they do with bigger caps.
                      • chuck567
                        • May 2008
                        • 14
                        I did measure them all to ensure I got the right sizes there was just a couple I couldn't find the exact right size for 220uf25v 8mm X 8mm to be exact. I just wanted make sure I could use the taller 8mm X 12mm in their place. there is plenty of room for these so I think I am safe.
                        I know I am asking alot of questions but I am what people would refer to is a perfectionist and I don't like making mistakes so hopefully you don't mind all the questions.
                        A couple of the caps were actually glued down one with a thick yellow substance and the other with a white hard as rock type glue, any cluse as to what kind of glue this is?
                        Thanks again for all your help to this point your advice and knowledge have been extremely valuable and appreciated.
                        • Krankshaft
                          • Jan 2007
                          • 2328
                          There are many manufacturers of capacitor adhesive and plenty of different forumulations out there.
                          It is just there so the components don't fall out of their holes until the automated soldering process affixes them to the board.
                          You don't need it for reinstallation simply insert the component making sure that its flush with the board then bend the legs of the capacitor on the solder side of the board to hold it in.
                          Now solder the legs clip off the excess leads and you're done.
                          • chuck567
                            • May 2008
                            • 14
                            Well that didn't go well, now it powers up and just stays black screen. Any idea where I can buy a new invertor board?
                            • alvarado
                              • May 2008
                              Same problem here. I've tested for intermittent connections -- no negative results. I've done a "shotgun" resolder job on the power board -- there were a few lands that were a little gray or may have had hairlines. Again no results. I've copied your list of caps and will go out and buy them to try. I don't know why my customer wants to spend to repair this instead of buying a new unit, but that's to my advantage if I can fix it. Would appreciate any new tips! Thanks.
                              • Krankshaft
                                • Jan 2007
                                • 2328
                                Did you check the inverter driver transistors?
                                If they are shorted you won't get anything.
                                • chuck567
                                  • May 2008
                                  • 14
                                  I replaced the power/inverter board with a new one, and still same thing. Works fine for a while and then starts flickering and then shuts off. Turn it off and back on it stays on for a while and then the same thing. I took the new board over to my brothers as he has the same exact monitor and it works fine in his.
                                  • anno
                                    • Sep 2007
                                    • 140
                                    • netherlands
                                    if you replaced the power/inverter board then the problem is somewhere else. I think the backlights in the lcd panel
                                    • chuck567
                                      • May 2008
                                      • 14
                                      Again this is not likely to be a backlight problem as the monitor works for quite some time before losing it's pic. It appears as though it may be heat related, if someone has actually seen backlights fail in this way please feel free to post. I am gonna start looking into the vga board and see what I find there. If anyone knows what the likely cause is I would surely appreciate the 411.
                                      • Krankshaft
                                        • Jan 2007
                                        • 2328
                                        If you can try swapping over the LCD panels (if you have an indentical monitor and see if it still shuts down) if it doesn't shut down then its probably the backlights.
                                        It's not uncommon for the inverter to shut down if the backlights are on their last legs. CCFLs aren't like fluorescent or incandescent bulbs they aren't an all or nothing deal (either they work or not).
                                        The can slowly become dimmer emit wierd colors and a slew of other things before they fail outright.
                                        Oh crap speaking of bulbs my 150 watt halogen architect worklight just blew out. I guess it saw me typing about bulbs .
                                        Oh well the quartz case was glowing cherry red for some time now I actually was anticipating an explosion . But the filament just gave way.
                                        You never realize what a help a good bright worklight is until it blows out oh well I'll finish the TV tomorrow when I get another bulb.
                                        • Tr0ll
                                          by Tr0ll
                                          Original T-con:
                                          First replacement T-con:
                                          10-07-2023, 07:48 PM
                                        • JJAAMM
                                          by JJAAMM
                                          Problem
                                          07-06-2023, 06:01 AM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
                                          I ordered a supposedly β€˜new' Tcon board this time, and
                                          06-09-2024, 10:28 AM
                                        • CyberPhoenix
                                          Issue with picture quality of Sony bravia TV
                                          by CyberPhoenix
                                          Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                                          01-22-2024, 02:08 AM
