Diode help needed
  • CraigR
    • Dec 2013
    • 959
    Diode help needed
    Not sure where to post this but I need some help fining info or the actual part number for a diode I found to be bad. I'm working on an arcade monitor chassis and the board is a JW-RODO-888A and I found a bad diode in this cluster of 4 but I would like to replace all 4 and the only numbers on it are 20D then under that is a "4" then under that is "3B" I can't find anything and even went on live help at digikey. Any help is appreciated!
  • SteveNielsen
    Retired Tech
    • 2327
    Re: Diode help needed
    You got a pic?
    • junktv
      • Nov 2010
      • 3063
      Live help is never any help.
      • CraigR
        • Dec 2013
        • 959
        Originally posted by SteveNielsen
        You got a pic?
        It's just your standard looking one like this"stock" picture.
          • 30962
          what monitor is it?
          • CraigR
            • Dec 2013
            • 959
            It's an odd one I have never run into before there is a sticker on the tube that says Pentranic and A89PNT30X
            • SteveNielsen
              Retired Tech
              • 2327
              Should be moved to appropriate forum?
                • 30962
                pentranic - thought so.
                like this?
                does this schematic match up with the parts?
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  circle them on the pic.
                  4 in a group near the ac input are just common diodes.i would use 1n5408 as i stock those.
                  thats a 3a 1kv gp.
                  replace all 4.
                  a89 crt is 35"!
                  thats a bigassed video game!
                    • 30962
                    probably a "candy cab" japanese unit.
                    • jolivares
                      NEEDED IPAD7 A2197 DIODE MESURAMENTS VCC_MAIN, VCC_BATT, VDD_BOOST
                      by jolivares
                      I sent IPAD 7 WIFI-2019, model A2197 to a techincal service, but they did not repair it, so i am trying to fix it. The problem is the IPAD is not booting and no turn on.
                      This is what i found until this moment:
                      1) with battery connected, the current draw from the power supply is about 450mA from the charging port.
                      2) no short circuit in lines VCC_MAIN, VCC_BATT.
                      3) with the power supply, or with the battery, the 3.7V of VCC_MAIN and 1V8_ALWAYS are generated without problem.
                      4) the current draw from the power supply, without battery, is about 26mA from the charging...
                      07-15-2024, 09:24 AM
                    • bohaboha
                      Buying some single smd led diode for tv repair, your advice needed
                      by bohaboha
                      I'm thinking of buying some single smd led diode for tv repair to have under hand there is so many, 2835 k-6000k 9v.6v, 3v white etc but don't know which to have if you advise me which Should I buy and which is most usual and bäst to have under hand. thank you
                      03-28-2024, 02:00 PM
                    • asr
                      Finding replacement diode iPad Pro 3rd gen A1701
                      by asr
                      Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
                      Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
                      07-09-2024, 06:24 PM
                    • unimatrix93
                      TV backlight zener diode
                      by unimatrix93
                      Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                      So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                      Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                      The led strips has 9 6V leds.
                      02-10-2025, 12:13 PM
                    • NicRac
                      monowheel repair,Is the diode the problem?
                      by NicRac
                      Hello everybody☺️ I am glad to be here and looking forward to a good discussion.
                      First of all, I am new here. Therefore I will shortly introduce myself.
                      I am Nico and currently I study Physics.
                      In my freetime I like to build and repair stuff. Especially big battery's.
                      A few years ago I got myself an electric unicycle, monowheel or however you call that.
                      The battery bms was broken so I replaced and resolder that. Nothing big.
                      I used this thing for some years and had a lot of fun. Unfortunately I used it last time in heavy rain. Usually everything...
                      07-26-2024, 06:13 AM
