NEEDED IPAD7 A2197 DIODE MESURAMENTS VCC_MAIN, VCC_BATT, VDD_BOOST
  • jolivares
    Jesus_is_Lord
    • Jun 2024
    • 6
    • chile
    I sent IPAD 7 WIFI-2019, model A2197 to a techincal service, but they did not repair it, so i am trying to fix it. The problem is the IPAD is not booting and no turn on.
    This is what i found until this moment:
    1) with battery connected, the current draw from the power supply is about 450mA from the charging port.
    2) no short circuit in lines VCC_MAIN, VCC_BATT.
    3) with the power supply, or with the battery, the 3.7V of VCC_MAIN and 1V8_ALWAYS are generated without problem.
    4) the current draw from the power supply, without battery, is about 26mA from the charging port.
    5) i haven't the diode mesurements of the main lines if power, so i dont known if i have a fuge in VCC_main or other line of principal power.
    THE VCC_MAIN DIODE THAT I MEASURED: 0.178V
    6) i dont know what other test or action i have to do to diagnostic the fault.
    I'll appreciate so much your help.
    God bless you, and thanks for this forum.
    Post data: sorry for my english, is not very well.​
  • mon2
    • 14539
    Do you see this current draw immediately or does the current draw slowly climb to this value?
    Watch this video:
    iPad pro 10.5 Won't power on. What is it this time. (youtube.com)
    • jolivares
      Jesus_is_Lord
      • Jun 2024
      • 6
      • chile
      Thanks for the response.
      the current draw is immediately.
      the other issue is the current draw from the battery connector, is about 0.8mA, rising slowly to 1mA, and then falling slowly until the original 0.8mA.
      i will watch the video now.
      • mon2
        • 14539
        If the current draw is immediate then most likely there is a shorted part on the board. Consider to use the schematic with no battery power to the board -> meter in resistance mode -> measure the resistance to ground of each and every inductor on the board. No power to the board during these tests. We are checking for a shorted / low resistance on a power rail. Alex has at least this video on ipads with shorted / defective parts.
        • mon2
          • 14539
          Must read this thread..
          https://www.badcaps.net/forum/troubl...a2197-no-power
          • jolivares
            Jesus_is_Lord
            • Jun 2024
            • 6
            • chile
            Very thanks! the post that you share was very usefull, i am reading and checking if i have something similar i my case.
            God bless you.
            • asr
              Finding replacement diode iPad Pro 3rd gen A1701
              by asr
              Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
              Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
              07-09-2024, 06:24 PM
            • unimatrix93
              TV backlight zener diode
              by unimatrix93
              Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
              So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
              Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
              The led strips has 9 6V leds.
              02-10-2025, 12:13 PM
            • NicRac
              monowheel repair,Is the diode the problem?
              by NicRac
              Hello everybody☺️ I am glad to be here and looking forward to a good discussion.
              First of all, I am new here. Therefore I will shortly introduce myself.
              I am Nico and currently I study Physics.
              In my freetime I like to build and repair stuff. Especially big battery's.
              A few years ago I got myself an electric unicycle, monowheel or however you call that.
              The battery bms was broken so I replaced and resolder that. Nothing big.
              I used this thing for some years and had a lot of fun. Unfortunately I used it last time in heavy rain. Usually everything...
              07-26-2024, 06:13 AM
            • dennis_elx33
              NO BODY MARKING Diode
              by dennis_elx33
              Hello Everyone,
              I have 1 diode on a circuit that I suspected to be faulty because the forward and reverse bias has a voltage drop reading.
              While compared to the reading of another diode from the next channel it won't read at reverse bias.
              Now the problem is; it does not have any body marking.
              So I tried to sketch the diagram and found out that it is connected to the base and collector of the C3632 transistor.
              What do you think is this diode?
              Can you please suggest what part number can i use to replace this faulty diode instead?
              Hoping that you...
              06-14-2024, 12:36 AM
            • eccerr0r
              Electric lawnmower...purpose of diode...
              by eccerr0r
              I was looking at an old battery powered electric lawnmower I picked up as the previous owner didn't want to buy a new board to replace a ruined old board. Tried to study how it was designed - it appears it has a huge 80A contactor...or rather, a 80A relay. It appears to be SPDT to control the motor. A 30A relay protects the circuitry.
              The weird thing I don't quite get is how this thing is connected. The common contact is connected to the motor. The NO contact is connected to the battery, which is expected, so when the relay is activated, the common is connected to the NO contact and...
              08-27-2022, 12:54 PM
