LG W2243S close to dead...
  • Teodule
    • Feb 2011
    • 34
    • France
    Hi guys
    I have this time a nearly dead LGW2243S monitor on my desk. I also got it from the local dump (it is my supermarket!!!). The monitor started a splash screen in japanese for 2 seconds and returned to standby.
    First symptom was a smoky smell. I have opened the case and reconnected the mains. The guilty capacitor is C515. Now the screen does not even show the splash screen, it tries to light up the CCFL for half a second and returns to standby. CCFL Transformer seems to be OK. Fuses are OK. Chemical caps look prima facie OK. I have the service manual from a previous thread about the same monitor but it doesn't help me right now.
    No ideas so far. Do you have a guess?
    Any suggestion is welcome. Thank you
    Re: LG W2243S close to dead...
    We need good clear pictures of the boards (top and bottom sides of the board)
    • Teodule
      • Feb 2011
      • 34
      • France
      There are pretty good pictures of a similar monitor in the following posting:
      https://www.badcaps.net/forum/showthread.php?t=34868
      I'll make a closeup picture of the smoking capacitor C515 ("N3 3KV SEC") although there isn't much to see. I will add the top and bottom side of the power supply board. I don't believe that the tiny data processing board has anything to do with the problem.
      I have downloaded the service manual from the previous posting. Unfortunately the schematics appear to refer to another board (different references, for instance no capacitor C515)
      • Teodule
        • Feb 2011
        • 34
        • France
        Here are my pictures. I'll keep you informed of the progression...
        • jetadm123
          • 2169
          N3 3KV is a 3pf 3kv ceramic capacitor. Try measuring the resistance across it to see if it's shorted.
          • Agent24
            I see dead caps
            • Oct 2007
            • 5081
            • New Zealand
            Replace the capacitor.
            -David VanHorn
            • Teodule
              • Feb 2011
              • 34
              • France
              No C515 is not shorted. I have tried the inverter test with an 11W CFL lamp and nothing happens not the faintest photon from the CFL tube. Secondary winding resistance for the inverter transformer is 765 ohm. Transformer seems to be OK.
              • Agent24
                I see dead caps
                • Oct 2007
                • 5081
                • New Zealand
                If the capacitor has smoked then it is damaged. It may have shorted, then burnt, and is now open circuit.
                You still need to replace it. Good components don't emit smoke.
                -David VanHorn
                • jetadm123
                  • 2169
                  Did you actually see C515 smoke? If yes, then replace it as suggested by Agent24. You'll have a very tough time finding a 3pf 3kv cap. Also, check the two large mosfets mounted on the vertical board (next to the inverter transformer) for shorts.
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 5081
                    • New Zealand
                    Finding a replacement capacitor would not be that hard... RS Components or Farnell should have them, if not there's always eBay eg: http://www.ebay.com/itm/25pc-Ceramic...-/130996084471
                    -David VanHorn
                    • mxslick
                      Motocross Racer
                      • Oct 2010
                      • 19
                      Look closely at the underside of the board in the area of the cap (lower left part of the full size pic, near the word "Danger") you can see a burned spot on or near the traces. :
                      There's either some junk on the board that is causing a short, or something leading off that trace which is shorted.
                      • Teodule
                        • Feb 2011
                        • 34
                        • France
                        Thanks a lot or your replies.
                        @ mxslick: it looks as if you had taken a picture of my board :-) . Actually C515 smoked "gently" not much, but you are right, Agent24, good components don't smoke'. Thus I need to find a replacement. May be I can get one from another "donor" monitor or I'll by one at Conrads as soon as I am back home in Munich. There is very little chance to get one in the place I an now.
                        I guess the MOSFETs on the additional board are U501 and u502. Do you think a shorted C515 killed the MOSFETs?
                        I have connected the the boards (not the panel) and powered them. There is a faint start of the lamos and simultaneously I hear one tick coming from the power and inverter board.
                        Have a nice Easter Sunday.
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 5081
                          • New Zealand
                          That is your board
                          I did not notice the burnt area that mxslick did, as the attachments were downloading very slowly the other day, and I must have given up.
                          He is right, C515 may be fine, you may just have had burnt glue or some other stuff on the PCB. Scrape the burnt area and clean off any carbon as it's conductive and may be causing the problems.
                          -David VanHorn
                          • Teodule
                            • Feb 2011
                            • 34
                            • France
                            Uhhh Well C515 is to be changed anyway because of his smoking capacity....I will clean indeed the area from possibly conductive (carbon) traces. I have also removed the white glue on the components side as it is known for becoming conductive when aging.
                            Does anyone have the actual schematics for this monitor ? The service manual exhibits obviously a different revision than the one I have).
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 5081
                              • New Zealand
                              Finding the schematics can be a pain. The PSUs in LCD monitors are usually supplied by a different company, so the schematics can be hard to track down.
                              If you search the PSU model number, you may find other LCDs that it was used in, then download their manuals and see if they have the PSU schematic.
                              -David VanHorn
                              • Teodule
                                • Feb 2011
                                • 34
                                • France
                                I wanted to thank you guys. 3 years later. I took the monitor out of the basement....ans started from the scratch the repair procedure. Then I discovered my own thread.
                                I have cleaned the carbon residues and I have now the following behaviour: Splash screen (LG) appears. The inverter transformer whistles faintly A vertical part of the display (20 %) is not properly addressed (no image, vertical lines). Splash screen disappears after 2 seconds then a black screen. 5 seconds later there are 2 horizontal lines of look like smileys dancing in the middle of the screen for about 2 seconds. Then blank screen.
                                I connect now the VGA input to my laptop. The latter doesn't recognise the monitor as plug-and-play. No image is displayed. Now the red power LED blinks slowly.
                                I will post tomorrow pictures and, if possible a short video of the phenomenon.
                                • Teodule
                                  • Feb 2011
                                  • 34
                                  • France
                                  And this is the end of the story: one of the CCFL is dead , one end is black and broken, see attached picture, therefore the 2 seconds to blank. If I find a replacement I'll give it a try. But the CCFLs break just by looking at them....
                                  • keepread
                                    Dell monitor PSU vs Dell laptop PSU
                                    by keepread
                                    Hi there!
                                    Someone gave me their old monitor, it's Dell S2715ht.
                                    The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                                    Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                                    10-30-2025, 04:45 PM
                                  • wattage
                                    AOC AG493UCX 49-inch monitor - Firmware request
                                    by wattage
                                    Hello Badcaps Community,
                                    The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                                    07-13-2025, 04:41 PM
                                  • ant3202
                                    HP 27es - LED monitor - Monitor Flashing On - Off
                                    by ant3202
                                    Hi Everyone
                                    Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                                    https://www.badcaps.net/forum/troubl...lashing-on-off
                                    The monitor is HP 27es LED Monitor
                                    https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                                    The monitor will randomly blackout and display no signal and will recover again.
                                    Sometimes need to power and off again to restore the display but...
                                    03-20-2025, 07:30 PM
                                  • Rick_1234
                                    LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                                    by Rick_1234
                                    Good evening, gentlemen.
                                    I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                                    To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                                    https://drive.google.com/file/d/1L6S...ew?usp=sharing
                                    Things I tried
                                    - Bought a new AC adapter thinking that was the problem but the problem...
                                    06-22-2024, 04:44 PM
                                    by momaka
                                    03-15-2023, 10:17 PM
