HP-L1506 keeps blowing internal fuse
  • techfixit
    • Feb 2014
    • 44
    • Ireland
    Hi, I'm looking for some help in trying to diagnose why the fuse keeps blowing in a HP monitor.. 3 monitors to be exact I got them from a local business who were throwing them out because they no longer worked. I've plugged them in to test and all three show no signs of power or lights
    I decided to strip them down and investigate and I've discovered the main fuse has blown on all 3. Knowing that fuses generally don't blow for no apparent reason i inspected the boards for other obvious faults and discovered the main filter cap had failed (leaking brown gunge). I replaced the main caps with the exact same spec cap and also fitted a new fuse. Plugged in the display and FLASH.. fuse blows immediately!!!
    To simplify things i've focused my attention on just one monitor for now as fixing one should help me solve the problem with the other two. So far I've tested the bridge rectifier, Mosfet and all of the other filter caps which have all tested good.. at least to my limited knowledge and understanding
    Could someone please point me in the right direction here as what to test and how to go about doing it please.
    Re: HP-L1506 keeps blowing internal fuse
    What resistance do you read between the two outer pins of the bridge rectifier?
    Same question for the two inner pins?
    Something is/are badly shorted out to make the fuses turn black like that inside.
    "I've tested the bridge rectifier, Mosfet and all of the other filter caps which have all tested good.. at least to my limited knowledge and understanding" What are the resistance readings of those parts?
    • techfixit
      • Feb 2014
      • 44
      • Ireland
      bridge rectifier:
      Tested out of circuit, meter set to diode test mode: Pin out 1234 = +~~-
      black probe to 1, red to 2 reading: .524
      reverse probes 1 to 2 reading: 0L
      pins 2 and 3 have no reading either way
      pins 3 to 4, black to 3 red to 4 reading: .532
      reverse probes, 3 to 4 reading: 0L
      MOSFET:
      Tested out of circuit. Pinout: 123 = GDS
      black probe to 1 red to 2: .17
      black probe to 1 red to 3: .17
      black probe to 2 red to 3: .000
      black probe to 2 red to 1: .17
      black probe to 3 red to 1: .17
      black probe to 3 red to 2: .000
      Reversing probes produces same results
      Main Caps:
      470uf 35v - .03
      470uf 35v - .03
      1000uf 25v - .05
      1000uf 16v - .02
      220uf 10v - .06
      1000uf 10v - .04
      68uv 450v - 1.2
      Tested in circuit using an ESR meter
      EDIT: Thought i should note the burnt fuse pictured is a regular 2A/250V glass fuse i put in to test after replacing the main filter cap. The original fuse is a T2AH/250V ceramic fuse. Would this make a difference?
        • 31090
        that fet is obviously shorted.
        • techfixit
          • Feb 2014
          • 44
          • Ireland
          What should a good reading look like?
            • 31090
            well not 000 that's for sure.
            • Agent24
              I see dead caps
              • Oct 2007
              • 4981
              • New Zealand
              Yeah that FET sounds pretty stuffed to me. And it seems like it's shorted through the gate as well so you will probably find damage to the drive circuitry too.
              I suggest you use the series lightbulb trick\dim bulb tester when repairing these to stop blowing more fuses and possibly damaging replacement parts if you don't get all the faulty parts replaced first time.
              You can use glass fuses instead of ceramic - in terms of operation there is no difference assuming they are the same rating. Ceramic have higher breaking capacity (That is what the H in the T2AH means) and are safer when they blow hard. Glass ones can rupture.
              Note that the T in T2AH means Time-Delay or Slow-Blow. You do need this type to stop the fuse blowing on inrush current when the primary capacitor(s) first charge up.
              -David VanHorn
              • techfixit
                • Feb 2014
                • 44
                • Ireland
                Are there any components i can test while i'm waiting on my replacement mosfets to hopefully rule out further damage along the circuit? I'll knock up a dim bulb tester in the mean time and grab some slow-blow fuses. Thanks for everyones input so far, really appreciate the help
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 4981
                  • New Zealand
                  You could check any snubber components for the FET and make sure they're not blown too. Failure of those could have been what caused the FET to die in the first place.
                  Also if you can upload a photo of the track side of the board that will help us understand the circuit better. If you upload to the forum itself it is better too. External linked images have a habit of eventually disappearing, which is annoying for anyone referring to the thread in the future.
                  -David VanHorn
                    The IC that drives the MOSFET should also be replaced.
                    • techfixit
                      • Feb 2014
                      • 44
                      • Ireland
                      Is that IC601 your referring to?
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 4981
                        • New Zealand
                        Going by its proximity to the FET, most likely. What is the part number of IC601?
                        -David VanHorn
                        • techfixit
                          • Feb 2014
                          • 44
                          • Ireland
                          Can you elaborate on snubber components? Would the mosfet failing have caused the main filter cap to dry out or did the mosfet fail because the filter cap did? Sorry about the pics.. I'll upload directly from now on
                          • techfixit
                            • Feb 2014
                            • 44
                            • Ireland
                            IC601 part number is:
                            1200AP40
                            CPDM
                            0601G
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 4981
                              • New Zealand
                              The snubber components will be in parallel with the primary transformer winding the FET switches. Look for a highspeed diode, high voltage capacitor (1kV or more) and maybe some resistor(s).
                              The attached BenQ schematic is very similar to yours. D603, C603 and R603 make the snubber network. In your case it looks like C603 is actually C614.
                              Check those components for open circuit.
                              It's very possible that a failed primary capacitor will blow the FET. The other way around is not so likely.
                              1200AP40
                              CPDM
                              0601G
                              I found and attached the datasheet. Make sure you get the right version (ends in 40) otherwise it will be the wrong frequency.
                              -David VanHorn
                              • techfixit
                                • Feb 2014
                                • 44
                                • Ireland
                                Some good news to report. I changed the failed Mosfets on all 3 boards and 2 of the monitors are working perfectly now
                                The third monitor is turning on but then immediately switches off and restarts as soon as the test image appears. I've got 318v at the main filter cap and i've checked all the other filter caps with an ESR meter and all of those tested good.
                                Has anyone got any suggestions?
                                  • 31090
                                  try swapping the boards around to narrow it down.
                                  see if all the power boards are good.
                                  • techfixit
                                    • Feb 2014
                                    • 44
                                    • Ireland
                                    Sorry should have mentioned i tested the non working board with all 3 lcd's and same result
                                      • 31090
                                      how about a foto of the board.
                                      • techfixit
                                        • Feb 2014
                                        • 44
                                        • Ireland
                                        It's the same board in the previous pics i posted
                                        • Dannyx
                                          UC3842 Power Adapter Blowing Fuse
                                          by Dannyx
                                          Good day folks......wow this new layout is weird. It's like I woke up one day and I'm no longer on Planet Earth or something
                                          Anyway....got this here power brick from a USB to SATA adapter which keeps blowing the fuse after I almost repaired it. The reason I even bother to fix a power brick (wall wart, whatever) in the first place is because this thing was really convenient to use: I'd just plug it and that's it. It's a dual output supply, for both 12v and 5v, which although I COULD easily obtain with a DC-DC converter from a standard 12v adapter, I thought I should crack open the...
                                          12-05-2023, 12:06 PM
                                        • Tips
                                          Samsung PD27AOQ (BN44-00506B) constantly blowing internal fuse.
                                          by Tips
                                          Looking for some assistance please.
                                          Trying to repair a PD27AOQ samsung power board.
                                          Initially had the typical problem of cm806 capacitor blown, additionally thermistor NT801s blown.
                                          Replaced the ceramic capacitor, str60252s, bridge rectifier, thermistor and fuse.
                                          Testing it the fuse blows immediately power is turned on.
                                          diodes dm852 and dm853 test as shorted when in the board but fine when removed.
                                          any assistance, guidance would be appreciated.
                                          04-11-2024, 11:24 AM
                                        • RogerH58
                                          Samsung 46" TV LE46B530 blowing fuse
                                          by RogerH58
                                          I am a newbie and not very experienced so bear with me if i struggle sometimes with technical language - but I'll do my best. I searched "Samsung" and the model number on the forum but didn't find anything I could understand!
                                          I'm not an electronics guy - just picked up stuff over the years through my flight-simming hobby.
                                          I have the above mentioned 46" tv as the monitor for my flight-sim setup. Recently it went "crack" and stopped working. No standdby light and no response. I assumed a fuse had blown and after investigation...
                                          06-10-2023, 10:27 AM
                                        • corrize
                                          A funny fuse story – Lumix LX100 II
                                          by corrize
                                          Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                          I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                          The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                          There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                          And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                          10-19-2023, 09:58 AM
                                        • Bootleg1
                                          Samsung UN65KS9800FXZA T-con fuse blowing
                                          by Bootleg1
                                          Hi all, so i was watching tv acreen went black and no sound. Traced problem to blown tcon fuse. Replaced and it blows replaced again samething. So my tcon fuse keeps blowing. I bought a new board havent installed yet infear its just going to keep blowing the fuse. If i only connect the right side ribbon cable the fuse doesnt blow but as soon as i connect the left cable my tcon fuse instantly blows and no picture. The right side picture works clear as day and left side picture is grey (picture attatched) im hoping its a bad tcon board itself or a cable or anything and not the panel. Thank you for...
                                          02-04-2020, 01:05 AM
