TDK XAD341LR EA02341X E168066 Inverter pinout?
  • sequille
    • 33
    I need to replace it with a generic Chinese one for which i need the enable and dim control pins.
    Assuming Black is GND and Red is VCC. Power out of the logic board, without the broken inverter connected:
    Code:
    Function	Color		Signal cable		No signal cable
    VCC		Red		11.97			7.15
    ???		Brown		11.97			7.15
    ???		Green		0.07			-4.78
    GND		Black
    ???		Yellow		-0.04			-4.90
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: TDK XAD341LR EA02341X E168066 Inverter pinout?
    Post pictures of both the inverter socket and the chinese job - did the ad where you bought it not have a picture with the connectors labelled - quite afew do.
    • sequille
      • 33
      I have the pinout for the chinese one, it's printed on the PCB. No info on the original TDK one, nothing printed on the logic board either. I thought someone would be able to figure it out from the voltages.
      • sequille
        • 33
        I figured it out, it was: GND, DIM, ENA, VCC, VCC. GND was yellow, if you can believe this...
        • caseyjay_48
          Sony KDL-46BX450 Inverter Troubleshoot Logic
          by caseyjay_48
          I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
          I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
          09-23-2022, 08:08 PM
        • x_orange90_x
          Vizio E55-E1 bad backlights or bad inverter?
          by x_orange90_x
          I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
          I don't know how exactly to test the inverter itself. Is it...
          01-29-2025, 09:24 PM
        • korben_dallas
          Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
          by korben_dallas
          Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
          I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
          I'm new to soldering but the only feasible way to fix this issue is to do something myself.
          MY QUESTION:
          I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
          02-14-2024, 12:23 AM
        • Gentian
          APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
          by Gentian
          I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
          It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
          03-06-2023, 07:07 AM
        • valvashon
          Insignia NS-LCD19-09 (PS OK, Inverter problem?)
          by valvashon
          For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
          History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
          01-04-2024, 01:44 PM
