la2405wg 24" Monitor
  • Kel
    • Feb 2012
    • 3
    I found 3 bad capcitors in this monitor and as I removed and was laying them out in order I accidentally knocked them on the ground... so does anyone know if C122 and C123 are both the 680uf 35 v. cap or is one of them a 470 uf 35w? I plan to replace all the caps, but stopped removing them after this mishap... the other cap removed was C124.
    Kel
  • selldoor
    Slow Learner
    • 7870
    Re: la2405wg 24" Monitor
    please update your profile with country and mains voltage,
    post a good clear picture of your board using manage attachements and stte the board number and revision.
    • Kel
      • Feb 2012
      • 3
      Here's 3 pics that may help.
      • benhadad
        • Aug 2013
        I have the same board (120v)
        C123- 35v 680uf
        C122- 35v 680uf
        C124- 35v 470uf
        C125- 35v 470uf
        • jason123
          • Oct 2015
          • 1046
          I know this is an ancient post - but has the replacement of the capacitor fixed the issue? I have a similar power board - it buzzes when turns on, but only when the lower ccfl is connected. I am going through the circuit, and I don't see bad caps - ESRs are low in 60 mOhm range and no direct shorts. All resistors are close to their labeled value. Any help is appreciated. Thank you
          • R_J
            • 9529
            Does the backlight come on at all for even a second? try connecting the ccfl to the other plug, Check the resistance readings on the transformer secondaries and compair them to each other, they should be close to the same 900+ Ω
            • jason123
              • Oct 2015
              • 1046
              Hi R_J,
              Yes, the backlight comes on... then off.. cyclical in a sense while buzzing loud. The transformers secondary on the top transformer is 471 Ohm, the bottom is 477 Ohm
              I didn't have exact size caps, so temporarily I replaced the 2 caps in the photo. Didn't make a difference.
              Swapping the top / bottom CCFL cables, I can only do that one at a time. It seem, the buzzing is coming from the CCFL itself and not the board. Could the CCFL be buzzing?
              One other thing to note, the on-screen menus that come up, they seem to disappear immediately. not sure if it's because both CCFLs are not fully functional?
              • jason123
                • Oct 2015
                • 1046
                So I opened up the panel, something I was trying to avoid, and sure enough the lower CCFLs are cracked
                Roughly they're 540 mm. Not sure if it's worth replacing or trashing the monitor. I see there are some CCFL out of China, but there are a lot of LED conversion kits. Has anyone used these? Is this the recommended path? Do I have to replace the 2 Upper CCFL with LED as well?
                  master hoarder
                  • May 2008
                  • 12168
                  • Bulgaria
                  I think member stj has used (and recommends) the LED conversion kits, and he says they are good.
                  I myself don't have any experience with them. I ordered replacement a single CCFL for a monitor once out of CCFLwarehouse, and it worked fine. However, I bought a discount CCFL (to save on costs), so it came with no connectors or wires - I had to reuse the ones from the old tube. Not the prettiest job, but it worked.
                  That said, if you do LED conversion, yes, you DO need to replace both the top and the bottom lamps with the new LED ones. The old CCFL inverter won't work with just the top lamps connected.
                  • jason123
                    • Oct 2015
                    • 1046
                    Thank you. I ordered a set of CCFLs... I'll put in the update once I get them.
                      by momaka
                      03-15-2023, 10:17 PM
                    • ant3202
                      HP 27es - LED monitor - Monitor Flashing On - Off
                      by ant3202
                      Hi Everyone
                      Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                      https://www.badcaps.net/forum/troubl...lashing-on-off
                      The monitor is HP 27es LED Monitor
                      https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                      The monitor will randomly blackout and display no signal and will recover again.
                      Sometimes need to power and off again to restore the display but...
                      03-20-2025, 07:30 PM
                    • Rick_1234
                      LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                      by Rick_1234
                      Good evening, gentlemen.
                      I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                      To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                      https://drive.google.com/file/d/1L6S...ew?usp=sharing
                      Things I tried
                      - Bought a new AC adapter thinking that was the problem but the problem...
                      06-22-2024, 04:44 PM
                      Wise Wing F199 19'' LCD monitor - recapped
                      by momaka
                      Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                      I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                      When I saw the Craigslist post, I wasn't...
                      08-24-2020, 10:58 AM
                    • sew333
                      Pc shutdown, monitor flickered with no signal after 10 seconds
                      by sew333
                      My pc:
                      10850K stock 4800mhz stock Kraken X73 good temps
                      2x16 GB DDR4 GSKILL 3000mhz XMP
                      Seasonic Tx-850 Ultra Titanium
                      Gigabyte Rtx 3090 Gaming OC
                      Aorus Z490 Pro Gaming
                      1 TB SSD
                      4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
                      Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
                      Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
                      Power...
                      02-22-2022, 10:27 AM
