LCM-22w2...another story...
  • xtremeskier97
    • Sep 2014
    • 22
    Re: LCM-22w2...another story...
    I dont have a digital micrometer so I have no idea of thickness. Its under 3mm, but dont know exact. How do I measure length when itsvgot the silicone ends still on?
    • Rtech
      • Jul 2010
      • 1095
      One of the ways that you can measure length, is to measure the GLASS part ONLY and add 5MM to account for the sillicone ends.You then get the nearest to that,ENSURING that you err on the shorter side,so that it will not be too big to fit in the screen itself.
      • xtremeskier97
        • Sep 2014
        • 22
        Bought a digital caliper. They are indeed 2.4mmx480mm
        • Rtech
          • Jul 2010
          • 1095
          So now all you have to do is get some ??...and of course fit them,taking a lot of care as the break very easily.
          • diif
            • Feb 2014
            • 6978
            • England
            http://www.aliexpress.com/item/20pcs...666082988.html
            A little more expensive than just 1, but you'd have spares if you broke it
            I have used this seller and my 5 CCLF turned up in bubblewrap in a piece of plastic tube all intact.
            • xtremeskier97
              • Sep 2014
              • 22
              CCFLwarehouse.com has been completely useless in my opinion. They sell an assembly. ..that THEY put together in house, that uses the 2 bulb silicone end caps but they won't sell me the end caps separately! BUT, they said they'd repair it for for over $70!! Yeah right!
              The assemblies they sell http://www.ccflwarehouse.com/ccbaasfor22c1.html
              Uses 2.4 X 485 mm CCFLs. I remeasured mine and I come up with 18 7/8" (about 482mm), so the 485 mm bulbs would not work, correct?
              It'd all be fine and dandy if I could find the silicone end caps, or something that would work in their place. Then I could just buy the bulbs and reuse my wiring, as all the wiring looks perfect.
              Thoughts?
              • Lumberjack777
                • 464
                #27
                Do you have any white silicone caulk? Because it's the same thing. Whenever I need a white silicone end cap; I just go out to the garage and grab my caulking gun
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  #28
                  ccflwarehouse have end caps for sale on their website ! http://www.ccflwarehouse.com/unsiendca.html
                  If yours aren't damaged you can just reuse them. You just have to carefully feed the wire through the hole.
                  I had a burnt end cap the other day and wondered what to do. https://www.badcaps.net/forum/showthread.php?t=40642
                  I went to the local auto store and got some RTV silicone gasket as it's rated for a higher temperature than normal silicone.
                  • xtremeskier97
                    • Sep 2014
                    • 22
                    They told me that those caps that they sell are only for single CCFL setups. Mine is dual CCFLs. Also, mine were damaged when taking them off.
                    If the RTV silicone gasket or silicone caulk will work, then I'll use that.
                    It just sucks that they sell that whole upper and lower assembly for $32 (4 CCFLs all wired up and ready to go) and just 2 bulbs is going to cost $20.
                    It would be really nice if that assembly they sold that is made with 2.4x485mm bulbs would work.
                      by momaka
                      03-15-2023, 10:17 PM
                    • ant3202
                      HP 27es - LED monitor - Monitor Flashing On - Off
                      by ant3202
                      Hi Everyone
                      Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                      https://www.badcaps.net/forum/troubl...lashing-on-off
                      The monitor is HP 27es LED Monitor
                      https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                      The monitor will randomly blackout and display no signal and will recover again.
                      Sometimes need to power and off again to restore the display but...
                      03-20-2025, 07:30 PM
                    • Rick_1234
                      LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                      by Rick_1234
                      Good evening, gentlemen.
                      I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                      To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                      https://drive.google.com/file/d/1L6S...ew?usp=sharing
                      Things I tried
                      - Bought a new AC adapter thinking that was the problem but the problem...
                      06-22-2024, 04:44 PM
                      Wise Wing F199 19'' LCD monitor - recapped
                      by momaka
                      Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                      I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                      When I saw the Craigslist post, I wasn't...
                      08-24-2020, 10:58 AM
                    • sew333
                      Pc shutdown, monitor flickered with no signal after 10 seconds
                      by sew333
                      My pc:
                      10850K stock 4800mhz stock Kraken X73 good temps
                      2x16 GB DDR4 GSKILL 3000mhz XMP
                      Seasonic Tx-850 Ultra Titanium
                      Gigabyte Rtx 3090 Gaming OC
                      Aorus Z490 Pro Gaming
                      1 TB SSD
                      4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
                      Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
                      Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
                      Power...
                      02-22-2022, 10:27 AM
