ViewSonic VX2235wm won't turn on, help please!
  • r3m1x
    • Oct 2011
    • 28
    I was recently using my monitor and suddenly it just turned off and i can't power it on anymore even when i press the power button. i opened it up and i took some snap shots of the electronics or close-ups of the caps. there is cap that i saw that seems to be blown it has a black dot on it, but i am posting the images so that people with more experience can help me fix the situation if possible. thank you very much guys. attached are the images to the monitor.
  • R_J
    • 9535
    Re: ViewSonic VX2235wm won't turn on, help please!
    There are at least two caps. bad, I circled them. there may be other problems as well, have you checked any voltages?
    Try replacing those two and see if it fixes it.
    • r3m1x
      • Oct 2011
      • 28
      thanks. i will try to change those. hopefully these are the ones with the problems. i haven't checked any voltages. how do you check them?
      • selldoor
        Slow Learner
        • 7870
        Is this the same set you fixed in oct 2011 - I am surprised it has lasted so long. You were advised at the time that the caps you used were not good enough - did you go back and change them ALL as suggested by at least two experienced members, If not , you are now paying the price for that and you need to change them now with something decent like panasonic FR series though FM and even FC will do if you cant get the sizes in FR and FM.
        Probably no point checking voltages until caps are replaced.
          master hoarder
          • May 2008
          • 12170
          • Bulgaria
          Don't change just the two bulged caps - change all of them. Why? Because suitable replacement caps are easiest found online (local stores usually only have "general purpose" caps, which are inadequate for this application and won't last long - hence it's not suggested to use them). So, if you are going to buy caps online and pay for shipping, you might as well get replacements for every capacitor in your monitor's power supply (except for the tiny ones and big 400V cap - that one usually does not need replacing).
          Better yet, if you have more monitors like this one or other LCD monitors that have bad caps (hint: check model numbers with badcaps.net search engine), then get some extra caps.
          You are not necessarily limited to Panasonic FC, FR, and FM, but they are nearly universal caps when it comes to monitors and are of very high quality, which is why selldoor usually suggests them.
          Other choices that could work in LCD monitors are:
          Rubycon ZL, ZLJ, ZLG, ZLK
          Chemicon KY, KZE,
          Nichicon PW, PS, PM, HE, HD, HV
          **AVOID eBay for caps**
          (Or if you are really set on buying caps from eBay, first post a link to the listing here before buying anything. There are just too many fakes and these fake caps don't last worth a squat either.)
          • wattage
            AOC AG493UCX 49-inch monitor - Firmware request
            by wattage
            Hello Badcaps Community,
            The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
            07-13-2025, 04:41 PM
          • ant3202
            HP 27es - LED monitor - Monitor Flashing On - Off
            by ant3202
            Hi Everyone
            Lately I am experiencing the deja-vu incident on one of the led monitor like this.
            https://www.badcaps.net/forum/troubl...lashing-on-off
            The monitor is HP 27es LED Monitor
            https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
            The monitor will randomly blackout and display no signal and will recover again.
            Sometimes need to power and off again to restore the display but...
            03-20-2025, 07:30 PM
          • pajdek
            Lenovo Y700-17ISK turn on and off
            by pajdek
            Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
            09-20-2023, 02:49 AM
          • sew333
            Pc shutdown, monitor flickered with no signal after 10 seconds
            by sew333
            My pc:
            10850K stock 4800mhz stock Kraken X73 good temps
            2x16 GB DDR4 GSKILL 3000mhz XMP
            Seasonic Tx-850 Ultra Titanium
            Gigabyte Rtx 3090 Gaming OC
            Aorus Z490 Pro Gaming
            1 TB SSD
            4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
            Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
            Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
            Power...
            02-22-2022, 10:27 AM
          • matthewmcconaughey
            I need help with my friend Sony GDM-FW900 24” CRT
            by matthewmcconaughey
            Hello, Badcaps is my last resort. I am the first owner of the monitor. I reached almost every repair store in my area, but no one even wanted to hear about troubleshooting an old CRT monitor. At this point, I have been trying to figure it out by myself, but I have no idea where to start or look for.
            I wish to know how to think and locate a failing component. I will put all my efforts to learn and contribute.
            1. It started with a bright and greenish picture upon starting a cold monitor.
            2. About 2 years ago, only on the cold boot, the screen started to occasionally flash with
            05-16-2023, 03:15 PM
