Iiyama b2475hds died.
  • khorne55
    • Aug 2014
    • 31
    • Polska
    Re: Iiyama b2475hds died.
    voltage regulators on logic board
    903T63 - 5.16v, 3.29v, 0v
    1117-18 - fluctuating between 4.72-5.13v, 1.79v, 0v
    Ad astra per aspera
      • 31213
      you need to find out where that defective 5v supply comes from that's feeding the 1117
      • khorne55
        • Aug 2014
        • 31
        • Polska
        @stj That is a tough task but Ill do my best
        Ad astra per aspera
        • khorne55
          • Aug 2014
          • 31
          • Polska
          At one of the capacitors the voltage is fluctuating between 2 and 5v
          Ad astra per aspera
          • khorne55
            • Aug 2014
            • 31
            • Polska
            I have circled the bad capacitor also I noticed that one of the legs on the voltage regulator is missing ? At least it seems like it.
            Ad astra per aspera
            • lexwalker
              • Feb 2011
              • 307
              • Malaysia
              #26
              Jot down that capacitor value and order a replacement just in case. Is there any inductor and/or resistor before that capacitor? From the looks of things, first have to make sure the +5V rail is stable by replacing those Lelon capacitors on the power supply board. There could be ripples that the meter did not detect (will show as average RMS voltage). Then check again if there is still voltage fluctuations at this capacitor. You could also simply replace that capacitor just to test...
              • khorne55
                • Aug 2014
                • 31
                • Polska
                #27
                @lexwalker the 5v rail is 100% stable coming into the logic board however the dim line is fluctuating from 0.33v - 3.3v.
                Ad astra per aspera
                  • 31213
                  replace the cap, and about the regulator - the missing center pin is connected to the tab that is soldered down - so no problem there.
                  • khorne55
                    • Aug 2014
                    • 31
                    • Polska
                    #29
                    This ia the cap I will be getting as replacement,
                    EKZE100ELL221MF11D
                    CAP 220UF 10V ELECT KZE RAD
                    Ad astra per aspera
                    • khorne55
                      • Aug 2014
                      • 31
                      • Polska
                      #30
                      Ordered all of the caps should have them within a week as the warehouse in my town needs to import them.
                      Ad astra per aspera
                      • selldoor
                        Slow Learner
                        • Dec 2010
                        • 7870
                        #31
                        OK kze should be good assuming you have correct uf and v
                        Im still not sure its going to fix it though
                        Did you try it with vga input. nad did you do any tests on
                        the LED strings/driver circuit.
                        • khorne55
                          • Aug 2014
                          • 31
                          • Polska
                          #32
                          I did not since there is no power in the monitor anyways.
                          If by the driver circuit you mean the the second board(logic) yes I did carry out tests there, everything seems fine except for the fact that there is the fluctuating current in there at one of the pins of the voltage regulator.
                          Ad astra per aspera
                          • selldoor
                            Slow Learner
                            • Dec 2010
                            • 7870
                            #33
                            OK - I was reading this
                            http://forum.hardware.fr/hfr/Hardwar...et_57492_1.htm
                            No I meant the circuit that light up the screen - LED light
                            • khorne55
                              • Aug 2014
                              • 31
                              • Polska
                              #34
                              Interesting similar problem except with the outputs, luckily he had warranty.
                              Ad astra per aspera
                              • JD714
                                • Sep 2014
                                • andorra
                                #35
                                Hey,
                                I have opened the monitor up
                                I've got the same monitor which died too, after 3 years only...
                                I'm trying to open it up, but I didn't figure how to do so, at least without breaking something. Any help to remove the case would be very welcome!
                                Thanks in advance,
                                • Elri
                                  • Jan 2015
                                  • France
                                  #36
                                  I've exactly the same problem on the same monitor : all voltages (5, 3.3 and 1.8V) are ok, all capacitors seems to be ok but the can seems to permanantly reboot. Maybe like if a watchdog retstart the microcontroller...
                                  When rebooting, all voltages are stable (with oscilliscope) but an inrush current occurs at each start up.
                                  Seems like firmware is currupted... I'll try to replace quartz but without conviction.
                                  Did you manage to repare your screen ?
                                  Thank you,
                                  • selldoor
                                    Slow Learner
                                    • Dec 2010
                                    • 7870
                                    #37
                                    Please post pictures of both sides of your boards
                                    • Elri
                                      • Jan 2015
                                      • France
                                      #38
                                      In fact it is exactly the same pictures as at the begining of this posy, with ALL same behaviour ( including dim pin ). Did the previous member find a solution ?
                                      • killeroid15
                                        • Feb 2015
                                        #39
                                        Hey guys, I think i have the same problems as i didn't opened up the display, i bought it from someone and the first day to test it already died .... just factory reset the display and then i turned off, after that wouldn't turn on again, and no lights as well, I've pulled out the power cord then back again but nothing...
                                        Did anyone KHRONE55; JD714 or ELRI found a solution ?
                                        Thanx
                                        • chaos_prevails
                                          • Jan 2016
                                          • Belgium
                                          #40
                                          hello,
                                          has somebody an update?
                                          I found this http://www.elektroda.pl/rtvforum/topic2353592.html suggesting that the Novatek Chip has to be replaced.
                                          I have the same problem and if the chip is broken, I would need the whole video board (I don't have the tools to solder SMDs). But I don't find anyplace where to buy the video board
                                          • DqMagetz
                                            Acer Nitro 5 AN515-54. displays on the external monitor and works fine, the issue is NO display on the internal screen
                                            by DqMagetz
                                            Good day!
                                            I have a customer's laptop — Acer Nitro 5 AN515-54 (EH5VF - LA-H501P). It has a display on the external monitor and it's working fine, but the issue is NO display on the internal screen. I already replaced the eDP cable and checked the LCD connector pins.
                                            Here are the voltage readings:
                                            • Input – 19V (stable)
                                            • +LCDVDD – 3.3V briefly, then drops to 0V
                                            • EDP_HPD – 3.3V briefly, then drops to 0V
                                            • PCH_BKL_PWM – 2.2–5V briefly, then drops to 0V
                                            • EC BKOFF# – 1.8V briefly, then drops to 0V
                                            • PANEL_OD_EN – 0.3V
                                            Is it possible that the EC chip is corrupted or damag...
                                            07-12-2025, 09:37 PM
                                          • mikey5791
                                            Need help replacing led strip on Iiyama Prolite XUB2390HS monitor
                                            by mikey5791
                                            Got this working ips led monitor by the brand of
                                            Iiyama Prolite XUB2390HS presumably a 23 inch type given to me with suspected bad led backlight. To test it, i unplugged the bad flat ribbon type connector and plugged it a good flat ribbon led connector scrapped from a HP Pavillion 27cw (led strip with 60 led). Good news is the HP led strip lights up but not fully, in between there are about 15 unlit leds.(as picture attached shows).
                                            Fyi, i had not opened and removed the old bad led strip. My question is whether is it possible to cut some of the extra leds(say...
                                            09-04-2023, 03:50 AM
                                          • Madoy104
                                            Macbook Pro A1989 - No image, working fine with external monitor
                                            by Madoy104
                                            I have a MacBook Pro A1989 that was likely exposed to liquid. It doesn't display an image on the built-in screen, but the screen is backlit (you can't see the Apple logo or any other elements when held up to light). The laptop provides 20V and 1.5-2A, and it works fine when I use it with an external monitor. Currently, the connector for the display (J8500) is disconnected. I'm writing to ask for help in diagnosing the issue. I've heard that when the J8500 is exposed to liquid, the processor pin responsible for the display might short-circuit, and I'd like to know...
                                            08-15-2024, 10:01 AM
                                          • amuse619
                                            Asus G15 5980HX - 6800M - No Display on Laptop - HDMI/Display Port external monitor works fine. Fried Component.
                                            by amuse619
                                            Hello!
                                            Looks like I fried something when my EDP cable got squeezed on the hinge. I replaced the cable but still no display. Laptop works fine with external monitor connected through HDMI and Display Port-USB C port. I took it apart and I see a burnt component. Can anyone help me identify what this component is? I tried to use schematics for another G15 but it does not match on the amount of pins and size. I attached pictures. The component has a label on it - (21A29)
                                            Laptop is a Asus G15 Advantage Edition 2021 Laptop Ryzen 9 5980HX - 6800M...
                                            08-14-2024, 01:22 PM
                                          • wattage
                                            by wattage
                                            Hello Badcaps Community,
                                            07-13-2025, 04:41 PM
