Hyvision by Megavision MV220 LCD monitor goes blank after 0.5-1 second
  • bobioni
    • Jul 2014
    • 16
    I believe I have a bad capacitor based on its appearance and the aforementioned title. When installing the new capacitor, I realize the capacitor terminals are different lengths to differentiate positive from negative. Can you tell me which terminal goes to the ballast side and vice versa? Below is a link to the exact inverter board
    https://www.badcaps.net/forum/attach...4&d=1389598177
    Last edited by bobioni; 07-21-2014, 07:46 PM. Reason: wrong pic attached originally
    • 31011
    Re: Hyvision by Megavision MV220 LCD monitor goes blank after 0.5-1 second
    forget the wire length, the negative side is marked on the plastic sleeve.
    • bobioni
      • Jul 2014
      • 16
      I have already identified the positive & the negative capacitor terminals. On the surface of the inverter board are now two holes from which the old capacitor was desoldered & removed. The interior hole (closest to the ballast/transformer) has a blue ring around it, whereas the exterior ring (closest to the edge of the inverter board) DOES NOT have any colored ring around it. Which of these holes is for positive & which is for negative?
      • selldoor
        Slow Learner
        • 7870
        You put it in the same way as the old one came out?
        The Blue Ceramic caps do not have polarity.
        As you can see in YOUR picture the stripe on the side
        faces the edge of the board so just put the new one in the same way.
        copy off YOUR picture?
        • bobioni
          • Jul 2014
          • 16
          That pic is what the inverter board should look like. That pic was borrowed from a post in January 2014; a member who had an identical problem. My capacitor had burst/exploded and was non-recognizable. I'll take your advice and line it up as in the picture, but from an educational perspective, I'd still like to know the positive/negative relationship with respect to the holes in the inverter board as requested earlier.
          • selldoor
            Slow Learner
            • 7870
            Post pictures of the top and bottom of your board
            • bobioni
              • Jul 2014
              • 16
              Attached is a pic of my inverter board (top & bottom) with the capacitor removed. The arrow points to the inverter board hole with a blue ring around it. Which capacitor lead goes to the hole with a blue ring, positive or negative?
              Last edited by bobioni; 07-22-2014, 09:18 AM. Reason: member requested top and bottom pic
              • addytzu123
                • Mar 2013
                • 54
                • ROMANIA
                The top hole is for negative lead and the one where your arrow points is positive.
                As you can see, from the bottom, the positive lead of the capacitor is linked to pin 17 of the FAN7311 , wich is Vin.
                In a transistor circuit protected by a fuse, the transistor will always blow to protect the fuse.
                • selldoor
                  Slow Learner
                  • 7870
                  That is correct - however if you had posted the picture with the query it could have been answered straight away.
                  See the white box where the cap is positioned, it has a broad white line down one side- That line indicates which side is negative.
                  • bobioni
                    • Jul 2014
                    • 16
                    Thanks to all for providing this micro-electronic beginner the needed insight. I will update status upon completion.
                    • bobioni
                      • Jul 2014
                      • 16
                      Okay, I replaced the inverter board capacitor; unfortunately, the same "2 seconds to black" exists. With the monitor on & a flashlight in hand, I can in fact see the Windows log in desktop , confirming the "2 seconds to black". I was able to secure a known-working inverter board and replaced the "faulty inverter board"; same result, "2 seconds to black". Is it accurate to assume at this point, that the CCFL bulb(s) are suspect?
                        • 31011
                        or the wires on them.
                        • bobioni
                          • Jul 2014
                          • 16
                          Okay. The wires are intact. Does anyone know a good source for CCFL bulbs? Is it also possible to substitute LED lights for the CCFL bulbs in the event the CCFL bulbs might not be available?
                          • lexwalker
                            • Feb 2011
                            • 307
                            • Malaysia
                            If that 2 seconds to black still exist then there could be other factors causing it. Have you checked the resistance of both transformers on the secondary/output side? Also do check for failed MOSFETs (which looks like I.Cs).
                            • bobioni
                              • Jul 2014
                              • 16
                              Being a beginning knowledge seeker, I'm not quite certain what MOSFETs are. Are the MOSFETs as well as the transformers located on the inverter board? If so, I did mention that I swapped out the questionable inverter board for a known working inverter board. The known working inverter board was removed from a TV which I watched yesterday; so I know the inverter board functions.
                              • lexwalker
                                • Feb 2011
                                • 307
                                • Malaysia
                                Whoops! My bad... Missed this part...
                                Yups, there is the possibility of bad CCFLs in that LCD panel. Anyway, are both inverter boards the same one? If the inverter board is different (and driving lamps of different specifications) then it could also produce that 2 seconds to black. However if both are the same inverter boards, then a very high likelihood that one (or more) lamps are bad. You can test which lamps by hooking both panels up on that single inverter board (by swapping the lamp connections between both panels), though a large table will be required to accomodate them...
                                  • 31011
                                  yes to both questions.
                                  http://stores.ebay.com/lcd-led-parts
                                  • bobioni
                                    • Jul 2014
                                    • 16
                                    Yes, both inverter boards are MV179; thanks for confirming my suspicions regarding a bad CCFL; will proceed to test lamps today.
                                    Last edited by bobioni; 08-03-2014, 07:33 AM. Reason: Was trying to quote another member, but don't know how
                                      • 31011
                                      make a note of the tube diameter,
                                      and the total length including the metal frame it sits in,
                                      you will need that info to order new tubes/led kit
                                      • bobioni
                                        • Jul 2014
                                        • 16
                                        "Anyway, are both inverter boards the same one? If the inverter board is different (and driving lamps of different specifications) then it could also produce that 2 seconds to black," to answer lexwalker (sorry, haven't figured out yet how to quote another forum member)
                                          by momaka
                                          03-15-2023, 10:17 PM
                                        • RetroComputingGrotto
                                          Hanns.G Hi221 Monitor - Works For A Second & Then Blank Display
                                          by RetroComputingGrotto
                                          I've got a Hanns.G Hi221 Monitor that works for a moment and then the display goes off but the power LED indicator remains on. If you power it off and back on again it does the same thing, it comes on and then the display goes blank. From a cold start it takes 10 seconds or so before the display goes blank but if you turn it off and then back on again after it already being on it goes blank a lot quicker so I'm assuming something is getting hot which is causing the display to go off.
                                          I've uploaded a video of it happening on YouTube:
                                          I've taken the monitor...
                                          01-11-2024, 05:37 AM
                                        • wattage
                                          AOC AG493UCX 49-inch monitor - Firmware request
                                          by wattage
                                          Hello Badcaps Community,
                                          The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                                          07-13-2025, 04:41 PM
                                        • ant3202
                                          HP 27es - LED monitor - Monitor Flashing On - Off
                                          by ant3202
                                          Hi Everyone
                                          Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                                          https://www.badcaps.net/forum/troubl...lashing-on-off
                                          The monitor is HP 27es LED Monitor
                                          https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                                          The monitor will randomly blackout and display no signal and will recover again.
                                          Sometimes need to power and off again to restore the display but...
                                          03-20-2025, 07:30 PM
                                        • Rick_1234
                                          LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                                          by Rick_1234
                                          Good evening, gentlemen.
                                          I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                                          To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                                          https://drive.google.com/file/d/1L6S...ew?usp=sharing
                                          Things I tried
                                          - Bought a new AC adapter thinking that was the problem but the problem...
                                          06-22-2024, 04:44 PM
