Emachines E19T5W bad caps
  • spleenharvester
    • Mar 2010
    • 903
    Power board is a Mirage Electronics PI-190DTLB.
    Was told it would power and just flash on and off. In actuality monitor appears to power up but only display bright bands of colour. Upon opening the control board looks OK but there are 7 obviously bad Xunda caps. Some browning on the PCB near the step-up transformers too.
    Does anyone know if this board was made in any revision without Xunda caps? It's such an old monitor it's not really worth the time/money/effort of recapping the board, and even if it were I only have a 12W soldering iron to work with.
    Cheers
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
  • spleenharvester
    • Mar 2010
    • 903
    Re: Emachines E19T5W bad caps
    Okay so I just pulled the Xunda caps clean out with my bare hands, without any damage left to the PCB pads (these solder joints are pretty terrible). The PCB holes are clear for new caps.
    How difficult would it be to just fit and solder new caps with a 12W iron? Could I get away with it without flux? The joints look small enough to be doable.
    Cheers
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      12W no flux you will be lucky to melt non leaded solder. I guess try one and see how it goes. Pre heat the board with a hair dryer might help.
      Was it connected to a pc when it had the colour bands, if not, that could have been what it does as self test prior to attaching a vga cable.
      • spleenharvester
        • Mar 2010
        • 903
        I suppose - I'd rather just avoid flux if possible. Hate the fumes from that stuff.
        Nah, this was a very definite monitor failure - I used to own this monitor myself. There were (seemingly of random-width) purple-brownish bands all over the monitor. The PSU caps were in pretty bad state so it could just be that, but I'm sort of worried the control board has bitten the dust too.
        • spleenharvester
          • Mar 2010
          • 903
          https://www.badcaps.net/forum/showthread.php?t=15337
          Someone here had a similar problem and had to recap both the control board and PSU. It would cost the best part of £13 to do that over here. Tempted to just scrap the LCD as it's old and probably barely worth that much anyway.
            master hoarder
            • May 2008
            • 12175
            It's worth it, IMO, if you have a use for the monitor or can give it to someone who can use it. Good quality caps will get you more years of useful lifetime than you care for.
            If not, then probably better to pass it down on Freecycle.
            • spleenharvester
              • Mar 2010
              • 903
              In the end I gutted it for the LCD and skip'd the rest of it. Just isn't worth the time and cost when I can get a known reliable monitor brand for not much more than that cost.
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
              • Dani_2024
                by Dani_2024
                10-28-2024, 05:06 PM
              • black6host
                Replacement caps for Samson Resolv studio monitor 65A Amp board.
                by black6host
                Good day!
                I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
                I'm going to replace the caps and I'll be the first...
                02-06-2024, 08:22 PM
              • Noodneek
                Replacing all the caps on the BenQ SW2700pt's power board didn't help...
                by Noodneek
                My 3.5 years old monitor (BenQ SW2700pt) started to black out for 1-2 sec every minute or so, it was doing this even with PC disconnected from it. I searched online and read that it's probably aging capacitors and there's a workaround to lower the brightness.
                I lowered it from 100 to 65% and it indeed helped, but after a couple of months the issue returned... I continued to lower the brightness, but it helped only for a couple of hours at most, then I needed to lower it further... Turning the monitor off and waiting for it to cool down also helped for a short time, after which it...
                08-30-2024, 12:52 PM
