Viewsonic VX2235WM........ 10 Seconds to black
  • Agent24
    I see dead caps
    • Oct 2007
    • 4976
    • New Zealand
    Re: Viewsonic VX2235WM........ 10 Seconds to black
    Originally posted by Robert Ashton
    The vendor I bought them from has a 99% approval rating.......
    That means nothing, the people who would know they are fakes wouldn't buy them, and the people who would buy them wouldn't know, so they'd be happy.
    Who did you buy them from?
    Should I replace them, or just deal with it?
    If they are in fact fakes, then yes, I would replace them with decent ones.
    -David VanHorn
    • Robert Ashton
      • May 2014
      • 34
      Hmmm, some place on Amazon called ProCapacitors.........
      http://www.amazon.com/Westinghouse-L...A2PDKTU4E5NRKK
      • bammbammfran
        • Apr 2014
        • 476
        Fakes? How can you tell?
        Well, that sucks
        what as the ebay item number for the caps ?
        They may be an off brand and not technically a fake ?
        They do not look like a top 3 or 4 name brand from what I can tell
        The p605s possibly could even be a knockoff, I have gotten AO products that I could see were that way (thinner metal and slightly smaller body) but they had the logo !
        I bought bulbs from ccflwarehouse. They are just a bit more pricy than overseas but they get here quicker. they also have the plug and wires, but it doesn't say how long the wires are.. their prewired sets are way up there in price.
        I have also bought from a US ebay seller, but I do not see their ID anymore ?
        • bammbammfran
          • Apr 2014
          • 476
          that seller is on ebay too
          http://www.ebay.com/sch/simoncapacit...p2047675.l2562
          • c_hegge
            • Sep 2009
            • 5219
            Sanyo never use + shaped vents, it's always a K. I don't know what that one with the Y-shaped vent is supposed to be. Nichicon never use that vent shape, and the font is wrong for Chemi-con.
            The rubycon and nichicons might actually be geniune. They look close enough to the real deal.
            They might work OK for now, but the real problem is that they might fail again in a few years time when genuine capacitors would still be holding up fine.
            • Lumberjack777
              • Dec 2010
              • 464
              #26
              In other words. And this is a good lesson for noobies.... When you buy a socalled "kit" from some unknown person. With unknown quality capacitors. You are entirely at the mercy of their choice of what to throw at you. Most of the time, it will be the cheapest bulk caps they can get their hands on. Immitations and fakes are common place.
              If you really want a high quality, lasting repair; buy like Panasonic FM or FR from a reputable dealer like Digikey, Mouser, or Farnell.
                • 31077
                i use these people.
                but the post takes time.
                http://stores.ebay.com/lcd-led-parts
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 4976
                  • New Zealand
                  #28
                  Or buy from the Badcaps store itself
                  -David VanHorn
                  • Robert Ashton
                    • May 2014
                    • 34
                    To be honest I did check all those sites but the product index filters confused the hell out of me..... I kept getting zero results.
                    I did go back to Digikey and searched for the caps on my board with the filters set at Panasonic-FM-Capacitance-VoltageRating
                    Can you check my list and tell me if these caps are what I need?
                    D-Key part # P1927-ND 22uf 50v
                    D-Key part # P12387-ND 330uf 25v
                    D-Key part # P12383-ND 220uf 25v
                    D-Key part # P12366-ND 1000uf 16v
                    D-Key part # P12379-ND 1000uf 25v
                    D-Key part # P12357-ND 2220uf 10v
                    If it's that easy I could kick myself for buying that fake cap kit
                    Thank You
                    • c_hegge
                      • Sep 2009
                      • 5219
                      That first part number doesn't show any results in capacitors, but the rest of those would do fine.
                      • selldoor
                        Slow Learner
                        • Dec 2010
                        • 7870
                        #31
                        He means D-Key part # P12927-ND 22uf 50v which is a panasonic FM so should be good.
                        I personally would go for the FR 5000 hours v 2000 hours for a 1 cent more
                        • bammbammfran
                          • Apr 2014
                          • 476
                          don't order those yet
                          I looked at one and it is going to be a bit tight due to the size
                          I have to look at the rest
                          • bammbammfran
                            • Apr 2014
                            • 476
                            First off, the ones you put in there should be good for a while and you should probably tend to the bulbs and see if that is successful before considering redoing the caps
                            What I would use
                            2200x10 -493-1502-ND
                            1000x10 -493-1497-ND
                            22x50 -P14452-ND
                            P12387 is ok for the 330x25
                            on the 1000x25 and the 220x25, I would bump up to 35 volts since there is 22-24 volts being used on this section
                            The 1000x25 you picked out are 12.5 mm and the one will be too tight against the 3R3 black coil, so you should stick to the 10mm ones on the upright one
                            if you want to stick to 25 volts use
                            1000x25 10mmx22mm -1189-1245-ND
                            220x25 upped to 220x35v -1189-1305-ND
                            on the 1000x25-- what I would do to get them up it to 35v and get things to fit would be to use one of each of these two
                            680x35 10mmx22mm P14514-ND (for the upright 1000x25) and1200x35 12.5x27 P14446-ND for the one that is laying down
                            BEFORE you get any, check to see if 2mm of extra height on the caps will fit inside the case since the originals a 20mm tall
                            • Lumberjack777
                              • Dec 2010
                              • 464
                              #34
                              Ha ha - Looks like you have the filters figured out; and yes it takes a little longer.
                              I guess the others have checked your caps and given suggestions.
                              Don't be too hard on yourself.....once I wanted to "save money" on a quantity of some small Rubycons, so I bought from some guy on Ebay.
                              They looked just fine until I examined them with a magnifying glass. What was supposed to say Rubycon, actually said Rubyoon
                                • 31077
                                what, not Rudycon?!!
                                • Robert Ashton
                                  • May 2014
                                  • 34
                                  Wow Bammbammfran
                                  Thanks for all the help! That must have taken some time and I sure appreciate it
                                  I agree about not messing with the caps right now....... I ordered a set of cclf's from cclf warehouse last night.
                                  I ordered a set that is supposed to be a kit for my exact monitor, It was kind of expensive but I was drained searching and searching for cclf bulbs.......
                                  Thanks Again : )
                                    • 31077
                                    Thanks Again : )
                                    should have looked at the link i posted,
                                    dirt cheap or even led conversions.
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 4976
                                      • New Zealand
                                      #38
                                      Just out of interest, which set did you buy? I have a monitor which may be a rebranding of this one, would be interesting to see prices\spec etc.
                                      -David VanHorn
                                      • Robert Ashton
                                        • May 2014
                                        • 34
                                        Sorry my friend,
                                        But I don't think I could trust any Ebay vender anymore........
                                        • Robert Ashton
                                          • May 2014
                                          • 34
                                          It is called "Item# SMRK1" there are no spec's I can find but it is supposed to be a direct replacement for the VX2235WM....... so i bought it. $29.99
                                          Maybe I messed up, I don't know......
                                          • ChIck3n
                                            Dell u2311h 20000 seconds to black issue
                                            by ChIck3n
                                            So I've had this monitor for probably a decade now, and it's finally starting to fail. Began with a little sporadic flickering, then eventually started going black (power LED stays blue, can still see image on screen with flashlight). A power on/off fixes it for a bit, but then it happens again. Once it got to the point I was dealing with this every few minutes, I opened it up and just replaced all the caps (minus the big one) on the power board with new Panasonic ones. All the old caps tested fine on an ESR meter, and this worked for 5 days. But the screen just went black again today, so...
                                            09-09-2024, 11:44 AM
                                          • DrankinSAW
                                            LG 37LG5020 and the tale of 2 seconds to black.
                                            by DrankinSAW
                                            I bought an LG 37LG5020 with a very strange issue.. it turns on, the display looks fine, but still, after 2 seconds, the TV shuts the backlight off..
                                            However, if i leave it plugged in for 20-40min.. the time it takes to shutdown the backlight, doubles (to 4 seconds)..
                                            I bought a new inverter, set to arrive on December 13th
                                            11-22-2023, 01:10 PM
                                            HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                                            This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                                            09-12-2024, 02:00 PM
                                            MSI Cubi N 8GL-063DE/N4000/4GB/W10P/Black N4000 Specification for Upgrade or Repair
                                            This specification for the MSI Cubi N 8GL-063DE/N4000/4GB/W10P/Black can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Cubi N 8GL-063DE/N4000/4GB/W10P/Black boardview and Cubi N 8GL-063DE/N4000/4GB/W10P/Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                            09-12-2024, 01:58 PM
                                            Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                            This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-07-2024, 05:00 AM
