EMachines E183HV
  • dcapper
    • Dec 2013
    • 496
    Re: EMachines E183HV
    I got a couple new A4 diodes today. I'll give them a whirl tonight. Its my mom's monitor and she kept turning it off and on. I told her to leave the power on and it will go to sleep on its own. Don't know if turning it on and off can cause it stress.
    • bammbammfran
      • Apr 2014
      • 476
      sleep or on-off shouldn't affect the inverter side anymore one way than the other.
      once you replace them
      see if swapping the plugs on the bulbs works right. it should.
      then run it a while and check that group of transistors to see if that one is running hot again
      • dcapper
        • Dec 2013
        • 496
        Well I found my problem. One CCFL is toast. Now how to find a replacement. Can someone help me? It says MKE2 on the plug. Outer edge to outer edge is 16 3/4". I've attached pics.
        EDIT: I removed the melted plastic on the end of the CCFL and soldered the wire directly to the bulb. Will that cause a problem? I turned the screen on and let it run for 10 mins and I get no hissing anymore.
        • dcapper
          • Dec 2013
          • 496
          Well so much for that. I put the bulbs in, dropped the case on it and broke the bulb. Well that sucks.
            • 31047
            hmm.
            time for an led kit!
            • dcapper
              • Dec 2013
              • 496
              Oh well. I'll wait until I find one at the landfill with a broken screen.
              • bammbammfran
                • Apr 2014
                • 476
                I figured it was a bulb
                finding an 18 inch in the landfill might be tough since 18" isn't that popular
                you can get them on ebay on the US side for 6 bucks but ship to Canada will probably be $10
                If buying them, I would get 2 or 3
                it's probably a 2.6mm one
                • dcapper
                  • Dec 2013
                  • 496
                  I just threw out an Asus with a broken screen a few weeks ago. Had I known. Hindsight is 20/20. Would a bulb work from a 19" or would it have to be a 18.5"? Found this too:
                  http://www.ebay.com/itm/221392737416...84.m1423.l2649
                  • bammbammfran
                    • Apr 2014
                    • 476
                    Double check your length of the actual glass.
                    that ad says 414mm and I thought that you said yours were 16.75" which would be more like 425
                    a standard format 19" I believe is around 15.5
                    shorter can work in a pinch but you will have to reroute the wires straight off of the bulb instead of 90degrees out of the bulb and you may have to trim the silicone caps
                    • dcapper
                      • Dec 2013
                      • 496
                      Mine's an 18.5. Bulb measures outer edge to outer edge is 16 3/4"
                      • bammbammfran
                        • Apr 2014
                        • 476
                        an old style 19" wide screen is close to that if you are measuring the screen
                        You should measure the actual bulb
                        • dcapper
                          • Dec 2013
                          • 496
                          I edited it after you posted. The bulb measures outer edge to outer edge is 16 3/4" including connector.
                          • bammbammfran
                            • Apr 2014
                            • 476
                            ok, so you must have a wide screen and the 19 wide screen should work
                            FYI: when ordering bulbs, you measure the actual glass of the bulb
                            • dcapper
                              • Dec 2013
                              • 496
                              It is a wide screen. Great! Thanks for all the help!
                                • 31047
                                that's the same company i keep linking with the led kits.
                                same price too.
                                http://www.ebay.com/itm/221401270173
                                • dcapper
                                  • Dec 2013
                                  • 496
                                  So if I buy one of those kits, do I just modify the plug?
                                    • 31047
                                    no, they come with a new invertor.
                                    btw - what is your tube-length in mm?
                                    if you scroll down the ebay page there are some install info's
                                    • dcapper
                                      • Dec 2013
                                      • 496
                                      I think the link you posted is mine.
                                        • 31047
                                        what link?
                                        the last post i did?
                                        no - same seller, different item.
                                        go to the sellers "shop" and look at the led conversion kits for tv/monitor
                                        • bammbammfran
                                          • Apr 2014
                                          • 476
                                          I never did one of these, but, it looks like you will have to do a bit of rewiring to use an led kit
                                          It does not plug into the plugs that your bulbs already use
                                            ACER eMachines PT.NCAE2.071 eMachines EL1850 E5800 Specification for Upgrade or Repair
                                            This specification for the ACER eMachines PT.NCAE2.071 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the eMachines PT.NCAE2.071 boardview and eMachines PT.NCAE2.071 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-12-2024, 03:36 PM
                                          • x_orange90_x
                                            TCL 50S535 bad tcon or panel issue?
                                            by x_orange90_x
                                            Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                            03-29-2025, 11:02 PM
                                          • advant
                                            by advant
                                            02-03-2020, 12:25 AM
                                          • Hakuu
                                            by Hakuu
                                            Hi There,
                                            More Details
                                            TV Model - LG OLED77G1PUA
                                            07-12-2023, 02:37 PM
                                          • Daren87
                                            Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                            by Daren87
                                            I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                            08-13-2023, 03:25 PM
