Samsung S24C230BL DVI problem
  • tibimakai
    • Jan 2012
    • 3680
    I have picked up this monitor from Ebay, with a description that it will turn on and off.
    I have tested it and found out, that on the VGA input works great, but on the DVI input, the DVI logo flashes for a second and it keeps repeating this on and off over and over.
    I have tried different PC, different cable(though the same type from monoprice).
    It could be that the cable is missing some pins maybe?
    The monitor did not come with power adapter, or any other cable.
    I have "repaired" other monitors, which required firmware update, specially the A and B series, but this is the C series and there in no firmware available for this model.
    Any input would be appreciated.
  • tibimakai
    • Jan 2012
    • 3680
    Re: Samsung S24C230BL DVI problem
    Nobody has any idea, what could be?
    • tibimakai
      • Jan 2012
      • 3680
      Nobody?
      • Pauldesign
        • Apr 2013
        • 49
        • South Africa
        If you can, alternative try a DVI to VGA adapter and use your normal VGA cable and see if the DVI port works to rule out the possibility of the faulty DVI cable.
        The Samsung video boards i've seen usually have a single chip; meaning the DVI and VGA share the same chipset and what differentiate the signals is the embedded firmware on the chip.
        • tibimakai
          • Jan 2012
          • 3680
          The problem with the adapter is, that it has those four pins next to the big flat one and the monitor doesn't have those four holes.
          • vinceroger69
            • Mar 2012
            • 6714
            theres two adaptors? dvi-i and dvi-d one has those 4 pins one doesnt? just a thaught.
            • tibimakai
              • Jan 2012
              • 3680
              There is one without, but I'm looking around Amazon and reviewers say, that they don't work, I don't understand why.
              I'm still looking for one.
              • vinceroger69
                • Mar 2012
                • 6714
                these active type do work but not cheap
                http://www.amazon.co.uk/StarTech-com.../dp/B00C93JQXS
                • bammbammfran
                  • Apr 2014
                  • 476
                  did you try restarting the computer while the monitor is on and the dvi is connected to see if the computer boot screen shows up at all.
                  If you are running a computer that can run two screens, does your computer recognize the monitor in the display settings ?
                  If your computer only has this screen, if the computer is running and if it has sound and the dvi is not connected yet, does it beep when you plug in the dvi ?
                  • tibimakai
                    • Jan 2012
                    • 3680
                    Thanks guys, I will look into that adapter and those tests too.
                    I haven't tried two monitors at the same time yet. Good point.
                    I haven't heard any beep, but I will try again.
                    • tibimakai
                      • Jan 2012
                      • 3680
                      Boot screen doesn't show up at all.
                      I have tried it, with dual monitors and Windows recognizes two monitors.
                      When I plug in DVI, it beeps.
                      If I try switching the monitor's input, it just switches back and forth between analog and DVI.
                      • R_J
                        • 9560
                        This might help http://nvidia.custhelp.com/app/answe...i-and-dvi-d%3F
                        Looks like the dvi-D on the monitor is digital in only, so as long as the video card outputs the digital signal it should work. thats why most adaptors don't work because they convert the dvi-I analog signal only to vga. or vga to dvi-I.
                        • tibimakai
                          • Jan 2012
                          • 3680
                          My PC in the garage, it's an old Asus PC with a Sapphire X1650 Pro 512MB, that can drive two displays simultaneously. Output is Dual Link DVI-D output.
                          http://www.sapphiretech.com/presenta...&pid=123&lid=1
                          I'm thinking, that it couldn't have a corrupt firmware, as the A and B series monitors?
                            Update the firmware. common problem on these. I have an S24A350 on my desk right now that had a similar issue (flashing on and off.) New firmware fixed it right away. The firmware can be updated over a VGA cable from a Windows PC. Download the software from the Samsung website.
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              ive just had a quick look too tom for the firmware i cant find it either only the device driver one? tibimakai has looked too as per post one have you saw a download link?
                              • bammbammfran
                                • Apr 2014
                                • 476
                                Looks like you may be having issues on the main board. possibly a bad transistor or diode or inductor coil right next to the dvi input.
                                Will have to open it up and post some good pictures of it
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  I have repaired already three monitors myself, with the firmware update. I will be getting another one, in a couple of days, which is an A model.
                                  I have even tried the A firmware on it and it said that the latest firmware it's already installed.
                                  To me it seems like the same situation, but there is no firmware for this monitor.
                                  It looks like, it is a Canadian model monitor.
                                  I will have to open it up then.
                                    Try checking the protection diodes on the signal pins of the DVI to see if any one of them shorted out.
                                    • tibimakai
                                      • Jan 2012
                                      • 3680
                                      I have come back to this monitor and now it won't even boot up at all. It's dead.
                                      I have tried different power adapter and it's still dead.
                                      I have the monitor apart and I would even buy another board, but nobody sells anything for this monitor.(BN41-10423M)
                                      Samsung parts, sells an empty EEPROM IC(GD25Q40BSIGY).
                                      The EEPROM has to be pre-programmed, or I can just replace it, with a blank one and when it will boot up, the software will be loaded into it?
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        Somewhere, I have read, that by removing the EEPROMM, the EEPROM will be reset.
                                        So, I did it.
                                        Now it turns on, but only the backlight it's visible, no image.
                                        It seems like it turns on and off, with the power button, it senses the laptop when I plug in the VGA cable(screen blacks out for a couple of seconds), Windows recognizes it.
                                        There is anything else, that I can do?
                                        • CptChronic
                                          Samsung LU32J590UQUXEN Monitor display problem
                                          by CptChronic
                                          I have an intermittent display problem with my monitor, when I plug in the HDMI cable to my (or any) laptop, you see the connection screen shrink on the laptop as it usually would before displaying on the monitor but 95% of the time the monitor display stays black.
                                          Before it cut out all together, tapping the monitor control button a fair few times would make the screen display, and everything work fine.
                                          But now it never does it. Not sure what's going on, hoping someone can help. I'm capable of stripping the thing down and soldering in new parts if needed, or programming...
                                          04-24-2023, 04:33 PM
                                          09-07-2024, 05:50 AM
                                        • Mirenia
                                          Samsung UEMU6199U - no Standby - bad Firmware?
                                          by Mirenia
                                          I've got a Samsung UEMU6199U which has no Standby LED and no reaction if try turning it on.
                                          Voltages on the power supply board is okay. Backlight test is also okay.
                                          I read about a corrupt firmware on IC1604 on some models, did a dump of this IC and turns out: First sectors are empty.
                                          So I think my TV has exactly this issue.
                                          Can someone please fix the dump?
                                          And how do you do that?
                                          As I understand you fill in the empty sectors and leave the rest as it is. But where do you get the "information" of what you...
                                          05-12-2025, 06:13 AM
                                        • wattage
                                          AOC AG493UCX 49-inch monitor - Firmware request
                                          by wattage
                                          Hello Badcaps Community,
                                          The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                                          07-13-2025, 04:41 PM
                                        • soso technician
                                          LG monitor ips226v-pnx firmware need
                                          by soso technician
                                          hi...lg monitor is dead...it seems to have corrupted firmware...because it is assembled in my country it may have different model name around globe...i will send pictures of mainboard,lables and dump firmware that i extracted from faulty board with name old.bin...if you have exact board (its common on diferent lg monitores) please share it...thank you.
                                          ips226v
                                          EAX63330406(0)
                                          110527 D.ZH
                                          it has 25X20BW eeprom...
                                          03-21-2025, 06:01 AM
