Poate e mai bine, sa scriem in engleza, ca si alti sa inteleaga.
This chip is available and by replacing it, it will just work? No need for flashing or anything like that?
With the A series, the monitor is working, just won't detect the input signal. If there is another issue, than most likely, a firmware update won't fix it.
The outcome is not good, I messed up the traces, when I have tried removing the IC. I had to heat it way to much, to be able to remove it.
I had to scrap that board and I have put the monitor away for a while.
Not to long ago, I have found a controller board kit on aliexpress, that connected to the Samsung LCD it will make it work.
This is a diy job, because the board(s) won't fit in the metal cage. There are (more)buttons then the original Samsung one. http://www.aliexpress.com/item/HDMI-...366904776.html
There is another kit, that has even more features, but I just need it as a monitor.
I have plugged everything in and it's working great. It needs a 12V power supply, though. The original Samsung won't work. I don't know, how many amps it needs yet.
Most likely, I will use stand-offs and install the main board against the back cover. The inverter, I will just tape it to the LCD and the button board, I still have to figure out how to mount it.
