Asus VS278Q-P image issues
  • tibimakai
    • Jan 2012
    • 3680
    I have picked up this monitor, which has this weird issue on the screen.
    I haven't opened it up yet, because I would like to get some opinions on this before I make my decision, on what to do with it.
    I have picked it up from Ebay. The seller it was claiming that it doesn't turn on, and to my surprise, it works great, but has this issue.
    Now if it's fixable, then I go ahead, but if you guys will tell me that is a panel issue, or something that is not fixable, then I will let the seller.
    It happens on all inputs, 2x HDMI and VGA. If there is no video signal(blue screen), then I can't see those artifacts, so I'm thinking that it could be a cable not plugged in properly, or some main board issue.
    Here are some pictures:
  • tibimakai
    • Jan 2012
    • 3680
    Re: Asus VS278Q-P image issues
    No ideas what this could be, or what can I try to narrow down the problem?
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4476
      • Italy - Milan
      It's probably a scaler chip problem, if you don't have another monitor with same panel interface the only method to know is to get another video board.
      Anyway if you find Tarzan ask it to him...
      • tibimakai
        • Jan 2012
        • 3680
        I'm trying it on my laptop, but I will try it on my other PC too, to see if it works the same there too.
        Right now, I have managed to adjust the Intel HD 4000 settings and the monitor setting and the artifacts are all gone.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4476
          • Italy - Milan
          Settings??
            • 31214
            probably means he changed the input resolution.
            hopefully to the one native to the panel.
            • tibimakai
              • Jan 2012
              • 3680
              I have found a setting in the monitor, which fixed the problem. I have never heard of this setting before, Trace free. I have reduced it to minimum, and those artifacts are all gone.
              Not bad, for $57. 1ms, 27" LED, 2x HDMI+ VGA+Display port, speakers monitor.
              Thank you for your help.
              • bajdik
                Intermittent Power Issue on Asus X553MA – CPU Voltage Drops ftom 0.89V to 0V
                by bajdik
                I have a problem with an Asus X553MA motherboard. Sometimes the system works fine, but other times the CPU voltage drops to 0V. In most cases, the laptop reboots after a few seconds due to the voltage drop.
                Occasionally, it shows the ASUS logo or boots into the BIOS. Sometimes it can stay in the BIOS for hours without issue.
                I checked the board with a thermal camera, but I couldn't find any overheating or leaking capacitors.
                Unfortunately, I don’t have access to the schematic.
                It seems to me that when I bend the board, something changes.
                Could this...
                08-13-2025, 07:26 AM
              • MakNCheese
                ASUS Zephyrus GA401I Severe Lag, Suspect Motherboard/Power Issue - Need Help Diagnosing
                by MakNCheese
                I'm having a serious issue with my ASUS Zephyrus GA401I (4 years old, worked perfectly until recently). The system is lagging heavily, even in the BIOS, and is charging extremely slowly (a few percent in hours), making it nearly unusable. I suspect a motherboard or power delivery issue.
                Symptoms:
                • Severe lag across the system, including BIOS navigation.
                • Slow boot times and unresponsive performance in Windows.
                • Battery charges very slowly (e.g., ~5% in 2–3 hours).
                • No error messages or BSODs, just extreme sluggishness.
                What I've Tried:
                • Replaced
                06-04-2025, 12:48 AM
              • ZixuTech
                Asus F1502Z BIOS issue? CPU gets hot but no other response. No blinking light
                by ZixuTech
                Hey guys, I got this model which stays black screen but CPU heats up. All voltages on board seems oK.
                Perhaps BIOS issue?
                Brand: Asus
                Model: F1502Z
                SN: R4N0CV11S622169
                Board: X1403ZA 2.2
                I have flashed this BIOS for test purposes and it lights up the ASUS but blank SN. https://www.badcaps.net/forum/troubl...21#post3593121
                Can you clean and enter SN for me please....
                03-31-2025, 05:04 PM
              • DynaxSC
                by DynaxSC
                06-14-2024, 03:49 PM
              • wishes2022
                ASUS UX3405CA bios issue(request)
                by wishes2022
                Hi buys,
                I have one ASUS ux3405ca bios file. but it can not extracted . I using extaract tools is AMI PFAT Extract,
                the tools is older version. ASUS Zenbook 14 UX3405CA, Core Ultra 9. me 18.1.15.2383
                can anyone help to share one extract tools ? bios from asus official website
                Thanks...
                08-10-2025, 10:36 PM
