Testing the c5707 transistors
  • playman
    • Jan 2011
    • 252
    Hi there
    Could some one tell me how to test those C5707 transistors correctly with a DMM?
    I've tried searching the net and this page for a definitive answer but no luck.
    I've seen few way's how to test them, in-circuit, out of circuit, using Ohm on DMM, using diode
    testing on DMM, and so on, but none of them really answer my question if they are broken or not, so now
    I'm wondering if some one would be so kind to teach me how I can do this correctly.
  • mancaveman
    • Aug 2012
    • 8
    • Hungary
    Re: Testing the c5707 transistors
    Not sure if it fits your scenario or not but these were used in the PSU/Inverter boards of several BenQ/Dell/HP monitors where they were usually shorted due to bad solder joints on the transformers and ballast caps.
    I'd probably move on to checking other components if I couldn't find a short between the transistor's pins. (A beep in continuity check or less than 2 ohm resistance in 200ohm range if your DMM doesn't have continuity check)
    There shouldn't be a short between any 2 pins of the transistor. (only exception being between the center pin and the tab)
    If there's no short and you really want to check that it's operating within tolerance you could use a DMM with transistor gain measurement function or a component analyzer to check the hFE and compare it to the datasheet value I guess but at that point the issue is probably elsewhere.
      Check for cold solder joints (you can see ring developed around the pin) around the transformer pins, transistors, capacitors. Also check the tuning caps (the grey or white caps sitting between the two transistors)
      http://s807.photobucket.com/user/bud...?sort=3&page=1
      • playman
        • Jan 2011
        • 252
        Thanks for the reply guy's
        Still some questions remain.
        I have a c5707 I took from a Medion LCD pc display.
        The readings I have are.
        Using 200Ohm setting
        Black probe on first pin red probe on second pin = No reading (shows just 1 on screen, after little googling that tells me it's open circuit)
        Black probe on first pin red probe on third pin = No reading (same as above)
        Black probe on second pin red probe on third pin = No reading (same as above)
        This is the same reading I get from all 4 c5707 transistors.
        So I guess that means that the c5707's are okay and there is something else that is causing black screen, right?.
        Am I right to assume that if I get any reading on the DMM beside "open circuit" the c5707 (or any other transistor) is broken?
        I did replace the 16v 1000uf capacitor (circlet in picture) as it was bulked, but that did nothing for me.
        I did not notice any cold solder points, but I'm going to try and resolder them.
        I guess I need a Capacitor tester to check out those tuning capacitors right?
        I did take a picture of the board.
          Did you check that black fuse PF701 sitting between the caps? That fuse feed the B+ to the inverter circuit. It should show <1 Ohm on 200 Ohms scale on the meter.
          • playman
            • Jan 2011
            • 252
            Yeah I did test it earlier and it gives me 0.8 Ohm connected to the PCB.
            • R_J
              • 9580
              To check the transistor, put meter on diode test, put red probe on base (B) of transistor and black on collector (C or center pin) you should read about .6 or 600 dependson the meter, then put the black probe on the emiter (E) and it should read around .6 or 600, then reverse the leads and do the same check, that should read like an open, then check between emiter and collector, either way the probes are should check open.
              You need to be on diode test or a good transistor will read open.
              As above check for poor solder connections, you may need a magnifier to see the poor connections.
              • playman
                • Jan 2011
                • 252
                Red probe on (B) Black probe on (C) = 745-750
                Red probe on (B) Black probe on (E) = 745-750
                I tested all four c5707's and they ranged from 745 to 750
                Reverse on that gave me open.
                Red/Black (E) Red/Black (C) gave me open on all of them
                Is 750 okay number?
                What number range is safe?
                Does this work with all transistors also?
                Is this the best way to check them?
                I checked the board with magnifier and saw no poor connections, but I'm going to
                resolder just in case.
                When I resolder, is it enough to just melt the connection or ad a little more tin to the connection or even remove the old tin and replace it with a fresh one?
                  750 (0.75V) represents the Vf (forward bias voltage which is 0.6v~0.7V range) of the P-N junction, so they are correct. I would also use Ohm mode to check the leakage resistance between E and C using 2K scale.
                  • playman
                    • Jan 2011
                    • 252
                    Using the 2k Ohm gave me open circuit, even tried 2000k which also gave me open circuit.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4427
                      • Italy - Milan
                      5707 often fails in couple, you have to check even in circuit if there's a short between 2 pins, if yes replace also the other 5707 even if seems good. "that is causing black screen" black with or whitout image (use a lamp by side of screen to see)? with or whitout the backlight (see in a dark room)?
                      • playman
                        • Jan 2011
                        • 252
                        Okay I just tested them in circuit.
                        200Ohm
                        Black probe on pin(B) red probe on pin(C) = No reading (open circuit) on all four
                        Black probe on pin(B) red probe on pin(E) = No reading (open circuit) on all four
                        Black probe on pin(C) red probe on pin(E) = 107.3 on all four
                        Diode test
                        Red probe on (B) Black probe on (C) = 706 on all four
                        Red probe on (B) Black probe on (E) = 706 on all four
                        Black probe on (B) Red probe on (C) = 1185 on all four
                        Black probe on (B) Red probe on (E) = 1475 on all four
                        Black (E) Red (C) = 1390 on 2 of them 1402 on the last 2
                        Red (E) Black (C) = 160 on all four
                        Are those readings correct?
                        The screen is just black, when I put a light on the screen I'm able to make some sight on what the screen is projecting, as in, there is no
                        light in the screen to light up the screen.
                        • ecking767
                          • Oct 2009
                          • 492
                          200Ohm
                          Diode test
                          normally a transistor will short out or read open on diode test on your meter. on eBay, there are some transistor testers you can buy. This little device work great and it will give you an better idea what going on with the components you are testing.
                          those reading for that transistor maybe OK. I can't say for sure I don't have a one new
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4427
                            • Italy - Milan
                            "Are those readings correct?" them seems to be correct, for the 160 seems a bit low, but since your testing on post #8 them are good, just to be clear, you don't have to test in circuit, it's only easier to do..
                            "when I put a light on the screen I'm able to make some sight on what the screen is projecting.." backlight is not working, on the under side of the board there is a chip with 14/16 pins, how is labeled?
                            • playman
                              • Jan 2011
                              • 252
                              Thank you ecking767 I'll look into that.
                              This is a big jungle out there, here are few I found
                              http://www.ebay.com/itm/Transistor-T...item19e21c8b66
                              http://www.ebay.com/itm/Peak-atlas-D...item3f1f6efb03
                              http://www.ebay.com/itm/Transistor-T...item19e734f236
                              http://www.ebay.com/itm/Mega328-Tran...item1c3f58273d
                              Should I get the MK-168 or the atlas one, they kinda look
                              the nicest but are also the expensive ones.
                              Okay thanks, it is quicker and easier to test them in circuit, I just
                              have to know what I'm looking for
                              Could that be the TL1451A?
                              http://pdf1.alldatasheet.com/datashe...I/TL1451A.html
                              • R_J
                                • 9580
                                If you suspect the transistors are bad, why don't you just replace them, they are cheep.
                                • playman
                                  • Jan 2011
                                  • 252
                                  It's not that I suspect them really, but they have a history of going bad.
                                  It's just that I wanted to know how to measure them correctly, so I can be sure
                                  that they are okay or bad.
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4427
                                    • Italy - Milan
                                    "Okay thanks, it is quicker and easier to test them in circuit"
                                    This is valid only for this particular board configuration eh!
                                    The datasheet of TL1451 doesn't tell what pins does, from a very similar service manual schematic (DELL E173FP) i can tell you that you can try to power on (with 5707 mounted) with, in order, pin 15 or if doesn't work pin 1 of that chip connected to gnd, this we hope will disable protection, this only for testing purpose! If the monitor works you must dismount the panel, verify that ccfl lamps are with black ends and then change those blacks with new ones.
                                    • playman
                                      • Jan 2011
                                      • 252
                                      And you just had to burst my bubble
                                      If I buy the transistor checker I have to unsolder them anyway.
                                      The strangest thing happened, I was going to try that out, but I decided to test the screen
                                      before I did that for some reason. Lo and behold the screen turns on and shows me the "Check Video Cable" popup message.
                                      But some strange things are happening, the VGA and DVI ports don't work and the screen is just blank, I put a "carpet"
                                      over it and noticed that there was light, so the lamps work at least now.
                                      And if I press the menu button I get the menu but it doesn't stay on, it just shows for 1 sec then disappears, if I hold the
                                      button the menu stays until I release the button.
                                      What could be causing those 2 symptoms?
                                      And how come the screen works now and not before?
                                      All I did was re-flowing some joints for good measure, could that be it?
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4427
                                        • Italy - Milan
                                        It seem the mcu gone crazy, that is a chip on the video input board, but all this happenings seems a bit strange. Continue testing it until you can be sure that the backlight works, if yes and if you dont receive any other hints consider to buy another video input board.
                                        • DynaxSC
                                          ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
                                          by DynaxSC
                                          I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
                                          Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
                                          Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
                                          The behaviour is also really very strange, i.e.:
                                          • The disk shows always up in BIOS - so it is recognized, so far so good
                                          • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
                                          02-23-2025, 01:33 PM
                                        • acedogblast
                                          [Marantz SR5012] Center channel keeps going into ASO/Overcurrent protection.
                                          by acedogblast
                                          First off I would like to thank this community as it has provided me with great information that has helped me greatly on my repair for this Marantz SR5012 AV receiver. I am creating this new thread as the other 2 that I have created here has had their original question/problem solved and I plan that this is the final thread on my repair. Please note that this is my first time repairing audio amplifiers so I may not be aware of common issues and things to know.
                                          Lets start at what I have done so far. Random speaker popping on all channels is fixed by replacing the 2 large filter...
                                          03-01-2023, 08:24 PM
                                        • hikomalek
                                          TV LG39LN575S, no backlight power, EAX64905301(2.2), MAP3202
                                          by hikomalek
                                          I would be really grateful for your suggestion how to repair a no backlight power on TV LG39LN575S. There is a visible menu on a screen when I use external torch (so logic board and panel works correctly), there is just no backlight.
                                          I have connected a logic board which is turning on power board and disconnected LED backlight cable.
                                          Power board:
                                          REV2.0 2013.03.28
                                          PCB: EAX64905301(2.2)
                                          LGIT PCB P/N: 3PCR00184A
                                          IC LED driver MAP3202
                                          MAP3202 voltages:
                                          (1) EN = 2.75V
                                          (2) VCC = 12.05V
                                          (3) GATE = 0 V...
                                          07-25-2024, 10:30 AM
                                        • Francesc V.
                                          Onkyo A8200 - Not the right voltages in some transistors
                                          by Francesc V.
                                          Hi:
                                          I am trying to repair this amplifier that I've bought as faulty. I've found some transistors damaged, the ones where I am drawing a red circle.
                                          With the final transistors not yet installed (the expensive ones), I've started to measure some voltages:
                                          Where I am supposed to have 1.12V (base Q524/Q523) I am reading -42V..................both channels don't seem ok.
                                          Where I am supposed to have -1.12V (base Q526/Q525) I am reading -44V..................both channels don't seem ok.
                                          I removed and tested Q514,Q516 & Q513,Q515 but the analyzer...
                                          04-19-2025, 07:17 AM
                                        • Bob Wong
                                          MSI Crosshair 15 A11UEK. Need help with Transistors!!!
                                          by Bob Wong
                                          Welcome badcaps, repairing a Crosshair 15, in need of transistor specifics. Received a broken laptop that's was perfect for repair, threw away the looser transistors in a haste... Should and could have salvaged them.
                                          In any case, I will be posting all my discoveries to this forum as a thanks in advance. Thanks in advance lol.
                                          P.S. If anyone is familiar with such things, as in, If anyone knows that MSI uses one or one of a few types of transistors when marked with a number please let me know how I can find more specifics before I start throwing hail marys.
                                          03-15-2025, 02:02 PM
