Onkyo A8200 - Not the right voltages in some transistors
  • Francesc V.
    Tempus fugit
    • Nov 2022
    • 231
    • Catalonia
    Hi:
    I am trying to repair this amplifier that I've bought as faulty. I've found some transistors damaged, the ones where I am drawing a red circle.
    With the final transistors not yet installed (the expensive ones), I've started to measure some voltages:
    Where I am supposed to have 1.12V (base Q524/Q523) I am reading -42V..................both channels don't seem ok.
    Where I am supposed to have -1.12V (base Q526/Q525) I am reading -44V..................both channels don't seem ok.
    I removed and tested Q514,Q516 & Q513,Q515 but the analyzer tell the they are fine.
    Potenciometer bias seem ok (R530 & R529)
    Maybe readings are correct and notes in the service manual aren't.........but I don't think so, as long as Q524 gets really hot without any load.
    What might be causing this anomaly? I've attached the service manual for the whole picture.
  • Francesc V.
    Tempus fugit
    • Nov 2022
    • 231
    • Catalonia
    Not sure if I am going in the right direction, but my problem is this -41V I am reading in one of the legs of C515, which is base of Q523.
    By removing Q515 from the circuit, this -41V turns into milivolts.
    Vbe in "removed Q515", measured from R525 and R535 is 1.3V which tells me that transistor is switched on and that's the reason I am having the wrong voltage above.
    In addition, Vbe in Q513 is 0.2mV which tells me that that transistor is closed.
    So, not sure if both transistors should be on and both voltages will make that in Q523,Q525 bases I would have +- 1.12V
    Or......... both transistors should be off.......
    Which part of the circuit should continue to investigate?????
    Click image for larger version  Name:	IMG_20250420_113722_118.jpg Views:	0 Size:	2.61 MB ID:	3619053
    • Francesc V.
      Tempus fugit
      • Nov 2022
      • 231
      • Catalonia
      I've realized that I was checking voltages with transistors removed from the PCB.............so as long as transistors are in the PCB, voltages come to normal.
      So it was normal to have +-30 V in the bases..........when final transistors are there, voltage decreases to +-1V
      • Capacitorial
        Powersupply has all the voltages - Monitor still no power
        by Capacitorial
        Hello guys,
        I have a Philips 240B7QPJEB. The monitor seems completely dead.
        I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
        On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
        The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
        The weird thing is, that the Power LED is powered over the TCON board.
        On The TCON...
        12-28-2024, 02:12 PM
      • redbaron1007
        Onkyo HT-R510 turns on and then immediatly off
        by redbaron1007
        I picked up an Onkyo HT-R510 that when I plug it in and press the power button will turn on and then a couple of seconds later turn itself off. When it turns on you can hear the relay click and then immediately click again and shut the power to the system off. I spent about 5 hours today trying to troubleshoot it and I did make some progress that may not actually tell me anything. It's still not really working and I'm not quite sure where to go next.
        Here's everything I've done so far.
        The first thing I did was open it up and check for any burn marks exploded parts...
        11-14-2021, 09:55 PM
      • gjgib
        Help reading schematic voltages input/output
        by gjgib
        Hello, this might be embarassing since I consider it a dumb question but keeps me kinda stuck sometimes in my journey.
        I want to know if there is any post in this forum which explains my questions. A) When, where and how do I know when X voltage line is input or output. Example:
        I'm battling with this IC to understand it's voltages. It's from non-turning-on Lenovo Ideapad 3 15iil05 - NM-D461.
        I see some lines like +5VL / +5VALW / V9B+ / +3VALW being okay and some others like 1.8VALW / +0.6VS / +2.5V_DDR. I just know that some of them are bad or missing,...
        05-06-2024, 08:11 PM
      • MotherTeresa
        Onkyo TX-NR5007 (NR3007 NR1007) NAND DUMP for DZKB4 DSP
        by MotherTeresa
        Hi.
        I'm looking for a DSP NAND DUMP for the Onkyo TX-NR5007 that works with the DZKB4 chip. Can anyone help?
        Regards.
        09-20-2025, 12:09 PM
      • RossMoodley1967
        HISENSE LCD LED TV MODEL HX40N2176F LED DRIVER SN51DP IC PINOUT AND VOLTAGES
        by RossMoodley1967
        Hello
        Need to know the voltages that will be present on SN51DP ic when tv is in standby and when powered on.
        Just to elaborate on the problem with the tv 1.set came in with flash of HISENSE logo on screen then back into standby.2. Now tv when plugged in red standby light present to quickly changes to blue but no backlights.3.Then an hour ago i checked again , came on standby and stayed until i pressed the power button which changed to power on (blue)4.As far as the led driver circuit goes voltage at output in standby was 38v , power on led light up voltages rise 58v-68v...
        03-01-2024, 06:07 AM
