AMW M177TD switches off after a while
  • _max_
    • Dec 2012
    • 46
    • Italy
    Hi friends,
    this LCD panel has affected by an annoying issue: it works normally as soon as has powered on, but unfortunately it switches off after a random time (few minutes, tens minutes max). Once powered off, it switches on but remains ON for a short time more and more.
    I thought bad caps, but unfortunately all of them look quite good despite of the age (jul 2005).
    Here there are a couple of photos of the mainboard I have got today.
    Do you have any suggestion on how to try to fix it?
  • _max_
    • Dec 2012
    • 46
    • Italy
    Re: AMW M177TD switches off after a while
    I am sorry but I made a mistake with on line pictures.
    Is it possible to edit the message?
    • paulstef
      • Dec 2013
      • 724
      Doesn't sound professional, but believe me the easiest thing to do is to heat the whole board until it does not power on anymore. Do not cook it, just heat it up with a hair dryer or heatgun without burning anything of course. 60C to 70C is ok. Then take cooling spray and spray part by part until it comes on.
      You can easily narrow down the problem to a certain area. Could be a lot of things, start with this first.
      • _max_
        • Dec 2012
        • 46
        • Italy
        Interesting. I will try soon.
        Thanks for your suggestion
        • _max_
          • Dec 2012
          • 46
          • Italy
          One question:
          what does the white glue (or silicon compound or whatelse) deposited on some components ?
          • paulstef
            • Dec 2013
            • 724
            A force exerted on the solder joints can cause them to become loose (break, crack) over time. The component that are glued are usually higher/bigger/have more mass than others. The glue helps to decrease this effect of vibration.
            Don't know how much sense it makes in a rarely moved TV set. It is very common in automotive electronic components.
              One question I have is that when it goes off, it goes into standby (like when it does not see video signal from the PC) or it acts as if the power switch is activated? We use the glue during wave soldering, some component will try to float up off the board.
              • _max_
                • Dec 2012
                • 46
                • Italy
                Thank you for your answer budm.
                Unfortunately I have not the LCD in front of me now.
                So far as I remember (but I will do a deeper check tomorrow) when the display goes off (say 10 minutes after powered on) it switches off the display (black image on the screen), even if the main led remains ON. Pressing the power button does not help if done immediately after, one has to wait for a while before powering ON the display again. Then the failure happens earlier and earlier.
                • _max_
                  • Dec 2012
                  • 46
                  • Italy
                  It looks to me that the problem is related to the inverter section.
                  The display light switches off quite soon now, the power led remains green (normally it is OFF when unplugged or orange when there is no video signal) but I can see images on the dark screen by using a torch.
                  So I have dismounted the mainboard but unfortunately I have no experience enought to find by myself the issue.
                  All the caps look quite good to me, now I am going to look for open diodes/transistors/fuses (but this sounds strange because of the display works at the very beginning).
                  Unfortunately I am unable to find the schematic diagram of this model (AMW 177TD), so I don't know which PWM/switching component could be damaged and how to check them.
                  I am quite sure that someone very experienced here by looking into photo details, can find the bug. I am still too young :-)
                  Any help would be very appreciated.
                  • wobbin
                    • Apr 2013
                    • 18
                    • United Kingdom
                    It's a bit hard to tell from the photo as I can't quite get close enough, but is the casing damaged at all on the transistor marked Q40 on the underside of the board ? If so it's where I'd be looking for a shorted or open circuit device which would certainly cause the backlight inverter to trip out.
                    It may just be my dodgy eyesight ;-)
                    Cheers
                    Robin
                    • _max_
                      • Dec 2012
                      • 46
                      • Italy
                      Thanks Robin.
                      I will check Q40 more carefully tomorrow then I will be back.
                      If was the Q40... How can I get its specs without the schematic?
                      • paulstef
                        • Dec 2013
                        • 724
                        Take a better picture of the 4 transistors including Q40. They are probably the same or complementary. We need to know what is printed on them From the code printed and knowing it's a bipolar transistor in a SOT223 package we may find out what it was.
                        • _max_
                          • Dec 2012
                          • 46
                          • Italy
                          There was dusty on that transistor.
                          Measured with an ohmmeter BCE and it reads about 0,6 kohm and 2,1 kohm direct polarisation and >10kohm inverse polarisation. All the four BJT reads exactly similar values, so it is difficult to believe that all of them are burnt.
                          On Monday I will get a better picture.
                          • Rtech
                            • Jul 2010
                            • 1095
                            The symptoms sound like intermittent failure of a Backlight,you really need a spare pair to test.I recently had the same thng on a Tv.
                            • _max_
                              • Dec 2012
                              • 46
                              • Italy
                              Do you mean another LCD panel?
                              • Rtech
                                • Jul 2010
                                • 1095
                                No, a set of working lamps to test yours.
                                • niky59
                                  • Apr 2010
                                  Hello anyone has lon wiring diagram for this monitor?
                                    • 30978
                                    could be the tubes,
                                    but i'd start by re-soldering the invertor transformers.
                                    but 9 years old is a long time
                                    if the tubes are gone, i'd fit an led replacement kit.
                                    • Hannibal_Hector
                                      Samsung UN39EH5003FXZA won't stay powered off
                                      by Hannibal_Hector
                                      Purchased a broken Samsung UN39EH5003FXZA (Version CD01) to have fun fixing. When I first acquired it, I did not connect any video signals and only plugged it into the wall. The unit booted and showed the “no signal” window and I could navigate all menus and change sources. I unplugged it, connected my over-the-air antenna to the coax, powered it on, got the unit to scan the HDTV channels, and I think then the TV self-shutdown with the melody. When I powered back up (melody), it would show the channel selected on the OSD and after a couple of seconds, it self-shutdown...
                                      03-02-2021, 07:57 PM
                                    • abajor
                                      A1990 820-01814A U1200 very hot when powered up, USB drawing > 4A
                                      by abajor
                                      I have this machine. It powers up and gets fan spin, will even shut down when I hold the power button.
                                      U1200 gets very hot under thermal camera, the next hottest region is UB000 and L7030. I'm assuming L7030 is warm due to charging.
                                      Do I have a potential dead CPU? or just a dead U1200? Not sure what to check since everything is powered up.
                                      04-11-2025, 05:02 AM
                                    • MrCreosote
                                      2 Belkin KVM switches have dim VGA output
                                      by MrCreosote
                                      When compared to a direct VGA connection, these 2 switches both output a darker image. The switches are:
                                      4-port Omniview Pro2 f1dz104t
                                      8-port Omniview either f1da108t OR f1dz108t (look and function same, OSD may be only difference.)
                                      The 4 is dimmer, the 8 is massively dimmer - both with same AC adapter and cabling.
                                      AD ADAPTER:
                                      There were issues with previous AC adapter, it failed during lightning strike that blew up TV and other stuff and tripped a 15 amp breaker in the main panel which also had a whole house Cutler Hammer surge...
                                      08-15-2023, 08:26 PM
                                    • _max_
                                      Hisense H60N5705 automatically switches off
                                      by _max_
                                      Hisense H60N5705 installed in a conference room, turns off automatically a few minutes after being switched on.
                                      Problem occurred suddenly, during a video conference. Switched on again by the remote control, it continued to work for a while and then switched off again.
                                      Power cable and HDMI cable checked.
                                      No changes by connecting the TV to another source but, even if it is left on the OSD menu, it stays on for a few minutes and then switches off.
                                      So they took the TV (a 60' which is not easy to handle) to the lab and asked me to check it.
                                      03-07-2025, 06:14 AM
                                    • MobileXT
                                      Yamaha DXR15 Powered Speaker Fault LED On
                                      by MobileXT
                                      Hello Everyone! I have a Yamaha powered speaker DXR15. The problem was the RED LED Fault indicator is steady on when I power the speaker. I did open the module and I don't see any burnt component. I Downloaded the Schematic but I don't know where to start the diagnostic. Any help would be greatly appreciated. I also attached the schematic here...
                                      01-17-2025, 12:43 AM
