Acer AL1916W, can't find the problem
  • Phoenix83
    • Jan 2014
    • 53
    • Slovakia
    #41
    Re: Acer AL1916W, can't find the problem
    Here's the pics ot the logic board. There are more, and at the maximum resolution that my camera supports.
    [img=http://img217.imagevenue.com/loc972/th_458773854_P1110925_122_972lo.JPG]
    [img=http://img146.imagevenue.com/loc23/th_458859613_P1110926_122_23lo.JPG]
    [img=http://img234.imagevenue.com/loc593/th_458941898_P1110927_122_593lo.JPG]
    [img=http://img221.imagevenue.com/loc1190/th_459020857_P1110928_122_1190lo.JPG]
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4367
      • Italy - Milan
      #42
      how do you have connected the blon signal, 5v and resistor? It's strange, are them firmly connected?
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4367
        • Italy - Milan
        #43
        I was reading a recent post and found that placing a 1k only resistor to BL_ON maybe not good, in fact i was unsure about it, i followed others.. sorry.. in that post has come out that a right resistor is around 33k, you can use a trimmer (i don't know trimmer values, maybe 33k??), 1k can damage your chip maybe, and 820ohm more.. or use a 3v battery between 2 pins.
        • Rtech
          • Jul 2010
          • 1095
          #44
          I have used a 1K resistor many times with no problem at all.as I am sure many others have, and one post saying it is wrong, is not proof that that is the case.
            @1K with 5VSTBY, the maximum allowed current will be only 5mA, the B-E junction of the transistor or the LED inside the Opto can take more than that. 33K will be way to high and may not be enough to bias on the transistor or light up LED.
            • Phoenix83
              • Jan 2014
              • 53
              • Slovakia
              #46
              Hi
              I solded one wire with resistor directly to the pin9 and other wire to the pin15. Then I touched the resistor with the wire for a second. It seems the backlight works. Now I have to somehow find out a problem on the main board. Probably I start with the transistors. Maybe one of SMD is bad. Hope the scaler is OK. But first I have to find the SM.
              • selldoor
                Slow Learner
                • 7870
                #47
                You will be very very lucky if you find a sm.
                We often get to this point and a new board is the only solution. It is often impossible to identify those small transistors and hard to find a faulty one unless it is burnt. Takes lots of time and sometimes you can pick up a board cheaply.
                • Phoenix83
                  • Jan 2014
                  • 53
                  • Slovakia
                  #48
                  I sent inquiry about this manual, directly to the Acer service center. They will certainly have it. We'll see the response...
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4367
                    • Italy - Milan
                    #49
                    I don't have saw it? I have already get the service manual on electrotanya at address
                    , but i think you'll for sure end to search for another main board. Unfortunately SM don't say all the truth i think, it's strange it don't tell about a service menu, so try to power up the monitor with power+ another button pressed, this can show the service menu. it's a desperate try since your monitor seems stuck in a non working state, seen the leds all lit, your firmware can be corrupt and you can try to search firmware data and reflash it if your monitor recognizes it but when never you'll find it?
                    • Phoenix83
                      • Jan 2014
                      • 53
                      • Slovakia
                      #50
                      I'll try to measure all transistors, if I can find out the types... But not now, now I'm going to the pub to take some beers with friends.
                      • viziks
                        • Mar 2012
                        • 33
                        • India
                        #51
                        Originally posted by Phoenix83
                        Hi everybody.
                        Have in my hands monitor AL1916W, but is broken. Both leds (green and amber) lighting at the same time and that's all. I changed the Electrolytic capacitors on the power board. Seems it works, because on the connector to the logic board I measured all the tensions, but slightly different. On the PCB is written +13,8V I measured 14,08 and is written +5V measured 4,97V. I don't know if it can be the problem, don't think so. On the logical board measured 3,29V on both Voltage regulators ABF646 (U6, U7) marked with red circle on the pic. I do not know whether to be both 3.3 V, or one of them is wrong. I have the service manual but for a different model and there is one 3,3V and the other one 1,8V...
                        Also the inverter transformer is too noisy. I need to build a tester to check it out.
                        I'm sorry for my english
                        Hello guys! If both led's are lit there is almost 99% chance that main board is defective
                        Before making any electronic tests in Inverter section for "No Display" problem confirm that you can switch on/off using power button.Only if power button operates the power led should you troubleshoot the inverter section .
                        If no power led glows then troubleshoot only power section or main board.
                        • Phoenix83
                          • Jan 2014
                          • 53
                          • Slovakia
                          #52
                          Hi everybody.
                          Whereas it is probably a problem in the mainboard, so I ordered this:
                          http://www.ebay.com/itm/LVDS-NTA93A-...tem337d84db25]
                          has anyone have experience with this?
                          I hope it'll work.
                          • selldoor
                            Slow Learner
                            • 7870
                            #53
                            I hope it'll work.
                            So do I
                            - This is the tricky bit
                            " Pls confirm the port that whether is suitable to your machine or not before you buy it."
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4367
                              • Italy - Milan
                              #54
                              What is tricky? he has swapped "the" with "that"..
                                09-06-2024, 05:27 AM
                              • fmajbour
                                Acer Nitro 5 model A515-51 keyboard problem
                                by fmajbour
                                I have ACER Nitro 5 model AN515-51 main board model LA-E911P Rev 1A after replacing the mainboard keyboard stop working properly.
                                Some keys not working like Q,Z,C and some keys show deferent chr$ if i press K i will get I press D for F4 key etc...
                                i have tried all software issues like drivers test the keyboard on Windows 10 and Windows 11 and Linux with same problem.
                                I have check the keyboard connector on the mainboard every thing looks ok.
                                Then i replaced the keyboard with new one ......same problem exact same keys problem.
                                I need your advice if anyone face...
                                11-13-2023, 09:50 PM
                              • ahmarzo
                                Acer TMX314-51 laptop battery problem
                                by ahmarzo
                                I have acer laptop tmx314-51 with part no 6050A3020501.
                                The laptop is working fine on adapter and battery is also charging and when adapter is disconnected in on state the laptop gives backup on battery and gives good backup.
                                But when laptop is powered on through battery only the laptop does not power on and there is 0 voltage on battery connector.
                                I have not not tried another battery as it is not available locally could this be a battery problem.have checked discharging mosfet and there is no shorting to ground on any pin of battery connector.
                                The schematic is not available...
                                04-11-2025, 09:14 AM
                                Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                09-07-2024, 05:00 AM
                                Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
