Resistor question
+ More Options
Posts
  • 1supertech
    • Apr 2012
    • 384
    Re: Resistor question
    Originally posted by Davi.p
    test in ohm R903/4/5
    Ok I found them meter set at 20k
    R903 3.29 K
    R904 3.29k
    R905 3.2k
      Post 25.
      Originally posted by 1supertech
      q207
      b&c 0.02
      c&e 0.00
      b&e 0.02
      q206
      b&c 0.01
      c&e 0.00
      b&e 0.02
      q203
      g&s 0.00
      g&d 0.02
      d&s 0.02
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4281
        • Italy - Milan
        #63
        supertech read what budm said, you have to dismount the 3 inverter transistors and retry..
        • 1supertech
          • Apr 2012
          • 384
          Q206
          B&C 0.L
          C&E 26.32
          E&B 26.55
          Q207
          B&C 0.L
          C&E 25.31
          E&B 25.92
          Q203
          G&D 0.L
          D&S 11.82
          S&G 0L
          I have no idea if these reading are any good but my dca55 shows no shorts
          numbers of each q203,q207,q206 readings were fluctuating I just picked the number it stayed on the longest.
          maybe I need a better multimeter .
          • selldoor
            Slow Learner
            • Dec 2010
            • 7870
            #65
            you need to say if the results are ohms kohms, volts or what
            also can you read the part numbers (numbers off the parts, not the board numbers
            • 1supertech
              • Apr 2012
              • 384
              Post 64 is all in ohms
              Q203 PU401 OR BE6A11
              Q207 D1805
              Q205 D1805
              • selldoor
                Slow Learner
                • Dec 2010
                • 7870
                #67
                The 3 resistors MAY be ok but you may have your zero s mixed up.
                They have on them 334 so should be 330kohms not 3.3kohms??
                I suppose you had better check them again but at least they are not open.
                I have been trying to get my head round something for a while - In your first post you say this monitor is an Acer 1906 and I have been looking at threads on that monitor to try and help us. Many things did not make sense and I am now wondering if your set it really an acer 1916 as there are very few hits showing this power supply with a 1906.
                I still think the 3 Qs are bad (less than 30ohms) If one of them is a double diode can you test it as a diode. ( Reversing the leads and advising the result
                in both directions)
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4281
                  • Italy - Milan
                  #68
                  the 3 resistors are marked "332", the 3 Q are transistor for sure because them are on the inverter area, i'm not usual testing them in ohm so i don't know if them are good..
                  • 1supertech
                    • Apr 2012
                    • 384
                    SELLDOOR, and everyone thank you very much for trying to help me with this but I learned allot from you but I going to give up on this board. I buy non working monitors from recyclers maybe I will run into a Acer1906 with a cracked screen.
                    • selldoor
                      Slow Learner
                      • Dec 2010
                      • 7870
                      #70
                      Ok - Sorry we couldnt fix it - better luck with the next one.
                        "Q206
                        B&C 0.L
                        C&E 26.32
                        E&B 26.55
                        Q207
                        B&C 0.L
                        C&E 25.31
                        E&B 25.92
                        Q203
                        G&D 0.L
                        D&S 11.82
                        S&G 0L"
                        "Post 64 is all in ohms
                        Q207 D1805
                        Q205 D1805"
                        That means they are bad.
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4281
                          • Italy - Milan
                          #72
                          You will never grow up if you give up at theese very basic steps, the next step is very easy, remove those 3 q , power up and see if led remains on.
                            We are getting close to the source of the problem based on the resistance readings of those transistors.
                            • TinkerTron
                              Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                              by TinkerTron
                              Hey everyone,
                              I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                              Instead, here's what's been bugging me so far:
                              The schematic...
                              03-06-2025, 02:03 PM
                            • artvandalai
                              What resistor ohm will work better to repair this waterpik?
                              by artvandalai
                              The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                              01-05-2025, 04:10 PM
                            • chth96
                              Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
                              by chth96
                              I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
                              Since then, This AC/DC adaptor have been out of order.
                              But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
                              After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
                              And Is there any possibility that it will suddenly explode as well as to be out...
                              12-03-2023, 04:40 AM
                            • flat-earther
                              Hoover FM216LI cordless vacuum refuses to charge
                              by flat-earther
                              I have a Hoover FM216LI cordless vacuum which isn't charging its internal battery.
                              I opened up the unit, and it has 6x Samsung ICR18650-22P cells connected in series.
                              5 cells were at about 3.3-3.1V. one was at 2.4V, so I assumed this cell was bad that's why the vacuum wasn't charging so I replaced it with another 18650, but after that the problem still persists, the vacuum turns on a bit and then cuts out since the batteries are empty.
                              So I think the over discharged battery wasn't the culprit, it was a symptom of the unit not being able to charge its batteries....
                              06-06-2025, 03:14 AM
                            • badcap111
                              Xiaomi mi 9T missing resistor
                              by badcap111
                              Hi, while trying to replace a broken screen connector on the motherboard, I knocked off a resistor next to the connector, and the resistor vanished. I have tried to find out the value of the resistor by looking at the schematics, but I cannot find the value. The ID of the resistor, or what you should call it, is R6400.
                              I don't know if the resistor is necessary for the phone to function, and the connector is still not soldered on to motherboard. I have contacted Xiaomi and asked them if they know the value, but they want a proof of purchase, which I don't have.
                              Is...
                              08-07-2023, 10:42 AM
