Hanns-G HH251 no power
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4318
    • Italy - Milan
    #41
    Re: Hanns-G HH251 no power
    Can you make me a new photo in the area that i've marked in yellow? It seems that something is not driving the mosfet you've photographed from near, also measure the 3 pins of the little transistor near the previous, the one that has a section with "D" shape from the up.
    • selldoor
      Slow Learner
      • 7870
      #42
      Cant find a datasheet for BIT3501 looks like they can be got from BITEK.COM on application form.
      Looking at the post with the three pictures - the last two at the right hand side
      there are two solder joints that look bad - may be just the picture but better check
      • maudam
        • Dec 2013
        • 24
        • Italy
        #43
        Tonight i was unable to test but looking around for data sheet i found something.
        This is the description of bit3501:
        High Efficiency ZVS CCFL Controller
        http://www.amazon.com/Unknown-BIT3501/dp/B00DHCVY6W
        http://it.utsource.net/ic-datasheet/...1-1873408.html
        This is the link to a similar psu from delta which use same architecture.
        Pdf in attach.
        This other link is for a chinese supplier:
        http://www.dzsc.com/product/infomati...121134131.html
        • maudam
          • Dec 2013
          • 24
          • Italy
          #44
          Tomorrow i'll post pictures and other measurements.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4318
            • Italy - Milan
            #45
            Can you test JP113 well visible in third photo in post #15? In that post it seems that you shortcircuited 5.2v pin with gnd! ..
            • devriestech
              • Dec 2021
              Thank you for posting the schematic. I am using it to trouble-shoot a ViewSonic CCFL BIT3501 based Inverter PCB.
              • PantherDave
                by PantherDave
                Hi all!
                05-29-2024, 02:01 PM
              • GLISIT
                by GLISIT
                01-16-2025, 02:29 PM
              • beetle1303
                Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                by beetle1303
                I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                01-13-2025, 08:49 PM
                by sam_sam_sam
                03-31-2024, 02:12 PM
