Hanns-G HH251 no power
  • maudam
    • Dec 2013
    • 24
    • Italy
    i have a dead hanns-g HH251 25" lcd display.
    During last months, the display suddenly power off and on again after some seconds with any apparent cause.
    In a couple of cases this power off went on for some minutes.
    Now the display won't power up.
    With some tests, i found the same problem at this thread but i'm not sure that only the fuse is broken.
    https://www.badcaps.net/forum/showthread.php?t=22967
    The smd fuse F102 (Marked with Y letter) seems broken, but i wasn't able to find this fuse or any oher info at any place.
    The board output should be:
    5,2V 3.1 A
    12V 0.7 A
    so the 5.2 line protected by F102 should be 3.1A but the same fuse is on F101 that should be a 12v 0.7A
    12V line is not active. Maybe the monitor have to power up before 12v are activated ?
    All the caps seems good. No leaks at any place.
    Please help me troubleshoot.
    Images on thread https://www.badcaps.net/forum/showthread.php?t=22967 are equal to my board so i'm not reposting.
    If you need i can post other pictures.
  • selldoor
    Slow Learner
    • 7870
    Re: Hanns-G HH251 no power
    I really dont think you can expect us to waste our time switching between threads to look at boards which are not yours.
    Suggest you try it with a 5a 12v fuse, but as long as the voltage is above what it needs to carry it is ok for a test, until you find out what it should be. Members generally solder in a pico fuse as they are easier to come by but you could wire in an automotive fuse if you are careful to solder it well and keep it well insulated.
    Also a fuse cant "seem" to be broken it either is or it isnt
    • maudam
      • Dec 2013
      • 24
      • Italy
      Hi selldoor,
      thanks for your answer and sorry for the pictures.
      About the fuse, do you think a 250V 3A fuse is good for test or i risk to burn all ?
      • selldoor
        Slow Learner
        • 7870
        If you have nothing else it would do for a test - at 3A it is a bit low and likely to blow but
        should not damage anything else - If it is a glass one shield it when you first try and do not
        look at it, just in case it explodes.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4477
          • Italy - Milan
          If the board says "12V 0.7 A" why to put a 5 or 3 Amp? For me is enough 1A.
          • maudam
            • Dec 2013
            • 24
            • Italy
            davi it is for 5.2V 3.1A.
            I'm going to try it.
            • maudam
              • Dec 2013
              • 24
              • Italy
              I have just tried.
              The fuse is bypassed with the external fuse 250V 3a but the monitor won't power on.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4477
                • Italy - Milan
                It was better if the picture was more closer to the interesting part, we cannot see where you have placed wires.. apart this if you now are able to see 5v on the output connector the next step is to control the voltage regulators on mainboard.
                • selldoor
                  Slow Learner
                  • 7870
                  OK - doesnt power on can mean a lot of things.
                  Can you test the voltage across the BIG cap It will be HIGH voltage so careful.
                  Put your meter on 600vDC and place a probe on each leg of the capacitor.
                  • maudam
                    • Dec 2013
                    • 24
                    • Italy
                    Well.
                    290V on C100 (bigger cap)
                    29V on C203 (near transformers)
                    0V on C105 (brown cap just up to external connector)
                    No 12v on pin 10 of external connector
                    5v ok on pins for external connector
                    Fuse F100 ok
                    Davi can you tell me which are voltage regulators and how check them ?
                    • selldoor
                      Slow Learner
                      • 7870
                      Does the screen flash at all?
                      • maudam
                        • Dec 2013
                        • 24
                        • Italy
                        Nothing. Completely off as the power led.
                        • selldoor
                          Slow Learner
                          • 7870
                          Ok - Still not sure how you have connected the fuse are you getting 5 v on both sides of it. Which pin is connected to C105?
                          The voltage regulators are on the main board if you can post a good clear picture of it.
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4477
                            • Italy - Milan
                            I think 12v rail must be always present, from what i can see, because OUTPUT connector (not external) has too few contacts for a control pin, so you need to check voltage on central pin of all the three legs diodes on heatsinks and if you don't find 12v switch off and test with diode tester that diode.
                            • maudam
                              • Dec 2013
                              • 24
                              • Italy
                              For the fuse, i made a bridge on pin 5 of external connector, that is directly connected with pins 4 and 6 and one side of broken F102, and JP104 that is directly connected to the other side of broken F102.
                              In attached pictures you can see more details.
                              • maudam
                                • Dec 2013
                                • 24
                                • Italy
                                davi, i'm going to do it now
                                • maudam
                                  • Dec 2013
                                  • 24
                                  • Italy
                                  All transistor in picture marked with yellow circle is ~20V on central pin.
                                  Transistor with circle red and yellow is 0V on central pin.
                                  By the way, external connector have some pins marked:
                                  brt
                                  inv_on
                                  ps_on
                                  Could be a control pin for 12v ?
                                  • maudam
                                    • Dec 2013
                                    • 24
                                    • Italy
                                    Transistor readings
                                    • selldoor
                                      Slow Learner
                                      • 7870
                                      Ok what you could try is disconnect the main board and with a 1k or .5k resistor
                                      connect the 5v pin to the InvOn and see of the back light stay on.
                                      I think brt is the same as dim so you may need to bridge that also using a resistor.
                                      If there is voltage at that cap between the inverter transformers there should be power there and it may only need a signal to switch them on.
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4477
                                        • Italy - Milan
                                        Your last pics are much nicer and i can see better, your psu is probably OK, PS_ON is a return signal from ma.bo. and need to hook it to get 12v to work. We need a picture of the main board so we can mark where to measure.
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • beetle1303
                                          Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                          by beetle1303
                                          I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                          On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                          01-13-2025, 08:49 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
