I just tore down one of those cheapo netbooks for kids and salvaged a useless display out of it. I took that LED stripe out of it and thought that maybe I can convert it into a desk lamp or whatever. I connected it to am ATX PSU 5V rail and it didn't o jack shit. I connected it to the 12V rail and i lit up really bright but got hot. Is it supposed to get hot? What is the correct voltage for it?
LED backlight voltage?
Re: LED backlight voltage?
Anything useful in here for you?
https://cdn.badcaps-static.com/pdfs/...5b3e53eac5.pdfPlease upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740 -
Well this ad
http://www.aliexpress.com/item/Free-...787891737.html
suggests it is one of these AT070TN07-VA
Which is one of these?
http://www.panelook.com/AT070TN07%20...view_1534.html
There is a datasheet but you have to register looks like 10v might be about right?
try with a 9v battery?Please upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740Comment
What ever you do, you need to limit the current through the LED to about 20mA for most LED. So you should use current limiting resistor or power supply with constant current source.Never stop learning
by Nagy DanielHi, I'm Daniel, and I'm new to the world of repairing motherboards.
I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
So, I generated a table with AI so I can... -
by shellybellyBack Story
I just recently purchased a RZ09-01652 Razer Blade 14 Touch v4(2016) as a project. I suspect the original motherboard had overheated and caused board damage to the vrm's for the CPU and GPU as now that motherboard works however will lockup on you often due to hardware clock issues.
So after some research and looking at options for replacement motherboards I got a replacement RZ09-01952 razer blade 14 motherboard which has the 1060 vs the 970m that was in my original motherboard. I have contacted the seller about the motherboard being bad however I doubt they will be... -
Assuming...7 Photos -
by mon2Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
Macbook AIR Model A1466 Diagnostic 09-01-2021
Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
Problems & Resolutions
1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....09-01-2021, 09:31 AM -
by ROONEY50I am repairing a laptop that has a short on it's 3.3v rail. I injected 1v on the rail and it was pulling 200mv but can't find any heat anywhere with thermal camera or alcohol. What else can I do to find what's shorted?
- Loading...
