I am repairing a laptop that has a short on it's 3.3v rail. I injected 1v on the rail and it was pulling 200mv but can't find any heat anywhere with thermal camera or alcohol. What else can I do to find what's shorted?
Voltage Injection on 3.3v rail
3.3v coil - 25 ohms
5v coil - OL
The other 3 coils on the board are showing
250 ohms
45.3 ohms
4000 mega ohms
I'm assuming the 3v is shorted maybe?
When I power the laptop on, it shows as dead. No CPU heat, no picture and no fan. However I noticed the 3.3v and 5v coils are showing the right voltages.
No 3.3v is showing on the BIOS chip pin 8
Voltages on the other 3 coils are showing 0vComment
You have 3.3v and 5v on coil, but also 3.3v and 5v ldo from pmic. What is resistance of ldo 3.3v and 5v to ground? Oh, you are all over the forum... I see that laptom has common fault on usbc connector, have you check if voltage reach board without battery?Comment
To be honest, I wouldn't know where to find the LDO. That's a new term for me.
I am aware this particular model has lots of problems with the USB-C connector. It's pulling only 5v through the USB-C charger but will check if it's reaching the board without battery and get back to you ππ»Comment
As example of ldo in attach, it is useful to check what pmic you have and if it have ldo 3v3 on power button, sometimes with addition to 5v ok and they are working ok. Be systematic in repair, so do nor just repair on first sight. If is usbc data lines is broken, the pd controler not let charger to switch to 19v, nor enable batt charging... so, changeing pd controler before check continuity pin-to-pin endpin it may not solve the problem. Check on every mosfet if not shorted also, it is routine check like checking rails...Comment
I think this is the pmic and on testing, I think it might be faulty. However, I cannot find ANY identification on the chip. I've cleaned it etc but still no ID. I've attached a picture and the schematic and wondered if you could find the chip on the schematic so I can order one ππ»
Attached FilesPremium supporters get full download access and other benefits.
1 PhotoComment
You can't see how many pins she has, most likely one of these.I think this is the pmic and on testing, I think it might be faulty. However, I cannot find ANY identification on the chip. I've cleaned it etc but still no ID. I've attached a picture and the schematic and wondered if you could find the chip on the schematic so I can order one ππ»
"I think this is the pmic and on testing"... why you think that? So, say, if turn it is not: "I think it might be faulty"... please explain why you think that ic is faulty? ?................. on picture is sot23 package nearby, so that little chip is not likely to be pmic. Ldo is about 150mA I guess, so must be ic with ground plane... search on schematic for ldo, and pwrbtn, then find this ic on mb...Comment
by User 4574Hi everyone .
I have model g712l And In stuck.
Originally this laptop has a short on main Power rail . ThΓ© main short is gone, i have found 2 pea16b mosfets Next to the SN51285ARUKR shorted , and the Chip Intself was Also shorted , i have removed them and main Power rail IS not shorted anymore , but right Now im still eating for this parts And in checking rest of the board . But pin 14 od the SN51285ARUKR when this chip od removed is shorted to ground Its +5VSUS has 6ohms , And that can not be , i have check mosfets All over the board And i have found ONLY one tahat Γs shorted its...Bad cap0%0Shorted internal layer in thΓ© motherboard0%006-21-2026, 07:50 AM -
I have an Asus TUF F15 (TUF506HC) on my bench. Originally it had a broken display, so I replaced the panel with one taken from a Lenovo Legion, which uses the same 40-pin connector.
After replacing the screen, it still remained black. Later I discovered that the display power fuse was blown. After replacing the fuse, the display started working again and now shows the image correctly; everything appears to function normally.
However, the problem is that the laptop no longer detects the dedicated GPU (RTX 3050). It does not appear in Device... -
Iβm troubleshooting a PlayStation 3 Slim CECH-2001B, motherboard DYN-001, and Iβm stuck at a fairly deep VRM-level issue.
Iβll try to provide as much structured information as possible.
π§ Initial problem
Console behavior:- Press power β green light for ~1β3 seconds
- Then shutdown with beep and blinking red
- Fan barely starts spinning
This looks like a typical early power fault / YLOD-type shutdown, but Iβm debugging at board level.
π Measurements and observations
π Power rails- 12V rail: stable, no drop during
03-23-2026, 09:32 PM -
by Mita99Hi,
Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no... -
by DJbapt59Hello everyone,
I recently picked up a laptop that was about to be thrown away to try to repair it. I've tested quite a few things, but I don't know where to look anymore. Could you please help me?
Brand: Asus Vivobook
Motherboard reference: x421da, Rev 2
Context:
The person who gave it to me mentioned it might have been exposed to water, but they weren't sure. After opening it up, I couldn't find any signs of water damage or oxidation on the motherboard.
The first thing I did was to connect the PC to a power supply: 19V stable and... - Loading...
