Dell E153FPB Back Light problem
  • Ihfreak
    • Feb 2007
    Well I have 3 Dell E153FPB LCD's that have a back light Issue. I have tried to do some research on the Transistor problem for this specific monitor but havent really come to any real good conclusion or even the specific transistors to test. I am not afraid of doing board level work at all. Thats what I do for a living but this problem stumps me a little bit.
    I took one board and reflowed everything on the board. It seemed to work for about 2 hours then dropped out again.
    Any one got any good suggestion on this Dell aka Benq monitor?
    Dan
  • Ihfreak
    • Feb 2007
    Re: Dell E153FPB Back Light problem
    I know I could just go buy the Power/Inverter board but I dont want to spend that money on that. I could buy a new monitor for that price. I know the Benq DS-1107A is the board I need to look at but I have not Idea what Transistors to look at to replace.
    Any Help would be greatful!
    Dan
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      why dont you test them all? check the caps out too....
      • Ihfreak
        • Feb 2007
        I figured someone here has had to run into the same Power inverter board with the same problem before. I was just wondering what other people have tried so I get an idea of which ones to test. It would give me the ability to do it on my lunch hour at work where I have all the proper equipment to remove and test them. As at home I do not. I cant do them on company time thats all..
        Just trying to narrow my search down.
        Thanks.
        Dan
        • Ihfreak
          • Feb 2007
          I guess no one has ever seen this problem before?
          • brianh
            • Mar 2007
            I inherited a defective Dell E153FPb. It has a defective backlighting.
            I tested the bulbs in another LCD, and they are good, so it must be
            a problem with the inverter. I've been reading another thread on this
            site about the Dell E172fpb.
            https://www.badcaps.net/forum/showth...3&page=1&pp=20
            Both have Benq inverter boards and both are plagued with
            similar backlight failures.
            The partnumbers for the transistors are slightly different.
            The C5706 are used on my board, whereas the E172fpb uses
            C5707.
            I've temporarily removed the 4 transistors. Three measured
            Hfe=385, but one of them had an Hfe of 447 which is a bit
            on the high side. Someone suggested that high Hfe was one
            failure mode. But if so, why does the other lamp not light up?
            The symptoms are that the lamps flick on for only a fraction of second
            when the power is turned on, this is no doubt due to the initial
            high voltage spike used to start the CCFL bulbs, but there is not
            enough voltage to keep them going.
            The flashlight test shows that the display is there - just no backlight.
            I've checked the board visually and see no signs of heat related
            damage, no bulging capacitors and no bad solder joints. I've
            re-soldered the critical transformer and transistor connections,
            but it was no help.
            If I only had a schematic...
            Any suggestions?
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              replace the 5707's and the fu9 something mosfets.
              resolder all pins of the transformers and anything else that looks cracked.the 5707 subs for the 5706.
              • arneson
                • Sep 2005
                • 1267
                It's interesting that the parts stuffer eliminated C771 and 772,
                and in place of C790 and R770 theres a jump, as well as C791 and R741.
                I guess that adds up to 37 cents in design savings.
                Jim
                • brianh
                  • Mar 2007
                  Ahhh - finally I've found the problem!!!!
                  After a lot of trial and error I have the CCFL lamps back on!
                  I won't keep you in suspense any longer... The problem was a blown fuse!
                  No... not the big white one, it was a little black one labeled PF751 (see previously posted photo if you're interested - it's on the right side and looks more like a rectifier diode).
                  I can read the letters "MS 2A" on it - so I guess that means that it's a 2 amp fuse. Someone else posted a schematic for a similar Diamond View monitor, which shows a 3 amp fuse. (ref: Inverter Schematic )
                  I've jumpered the fuse with an extremely fine strand of wire, and the CCFL now comes on. I'm giving it a burn-in-test right now. So far 1/2 hour and all is well.
                  I am, however, not willing to call it "fixed" yet - after all... Why did the fuse blow in the first place?
                  Sure... I plan on putting in a proper fuse, but I don't want to re-assemble it and have it blow another fuse (or worse) in a day or two.
                  But hey... after way too many hours on this project - at least I've got something positive!
                  Any thoughts?
                  • arneson
                    • Sep 2005
                    • 1267
                    I'm working on and off on two of these that are loseing the 5707's, and two that are loseing the smaller SMC versions of those switches.
                    That's four monitors and all have lost the top tube section.
                    The bottom tubes light on all of these and it's only the tops going out.
                    My question is if it's possible that the top of the lcd screens get hotter and lessen the life of the tubes?
                    Or because the tube connections go to the top tube, that section of inverter is higher on the board and the top inverter circuit gets hotter?
                    Whichever, I have found it's likely for the upper one to short the drivers.
                    Jim
                    • Joeheth1
                      • Jan 2009
                      Any thoughts?
                      It seems that the problem that you found is one that occurs qite often with the Dell monitors. I had one with the exact same problem and found that the PF751 fuse was blown. I replaced it with a 3 amp fuse and after an 8 hour burn in it is still working. The one thing that I found was that the brightness of the monitor was a bet diminished. But as I said it is still working. Thanks for your time and input.
                      • brianh
                        • Mar 2007
                        Re: Dell E153FPB Back Light problem - and another
                        Just wanted to report back and say that the Dell E153FPb that I repaired back in August is still going strong.
                        I've been so encouraged with the success that I purchased a broken LCD monitor on Craigslist for $10 and attempted to repair it for use on another PC of mine.
                        It's a KDS "Radius" LCD monitor with exactly the same symptoms that the Dell had.
                        I poked around with it for a while, looking for a blown fuse or bad caps. I re-soldered a few, but nothing helped. But suddenly it started working! I'm not sure what I did to fix it.
                        I have only one guess as to what I did that might have fixed it.
                        While re-assembling, I noticed that the inverter was attached to the metal frame with two screws. It looked like metal chassis just might come into contact with a trace on the inverter board, so I added some extra insulation (tape).
                        The trace was the output from the step-up transformer that went to the CCFL connector.
                        Maybe that's what fixed it. I was so thrilled that it worked, that I quickly re-assembled it before I forgot how it went together.
                        That puts an end to the CRTs in my house, so I think I'll quit while I'm ahead.
                        • MegaOne302
                          • Apr 2009
                          • 94
                          I found an E153FPB last weekend on my way home, but when I plugged it in, it was DOA. After opening it up and checking things like the caps and fuses I couldn't find the problem. I totally pasted up fuse PF751 because in didn't look like a fuse; this was the first time seeing this type. The P in front means that it's a mini Pico Fuse. So Yep that was all, a bad Pico fuse PF751... I just dropped in a 2A Slow Blow from my parts box and boom, she's back to life.
                          Thanks all,
                          Joe
                          Does an idiot make a sound if no one’s there to hear them talk?
                          • MegaOne302
                            • Apr 2009
                            • 94
                            I found an E153FPB last weekend on my way home, but when I plugged it in, it was DOA. After opening it up and checking things like the caps and fuses I couldn't find the problem. I totally past up fuse PF751 because in didn't look like a fuse; this was the first time seeing this type. The P in front means that it's a mini Pico Fuse. So Yep that was all, a bad Pico fuse PF751... I just dropped in a 2A Slow Blow from my parts box and boom, she's back to life.
                            And may I ask why you put in a 3A? If the fuse blows, that's a good thing; it means it just saved the circuitry from frying or from burning down your house. So please tell me why you think it's ok to override a safety measure?
                            Here's a thinker for you.
                            If a fuse/breaker blows in your house, do you say hey, it was only a 20amp? I'm going to put a 30amp in so that never happens again… ?
                            Thank god Spring ‘s coming. lol
                            Thanks all,
                            Joe
                            • choodan007
                              • Apr 2009
                              HII somebody help me .i hav a dell E153FPf monitor itz one ic got burned i cant read that ic noumber also ,itz circuit noumber u580......plsss post that ic noumber if any one having that
                              • Bobdee
                                • Jun 2008
                                • 461
                                Hello choodan0007
                                I have the new version E153fpf board
                                (inverter/power suppy/video all on one board) in front of me, cant see a u580.
                                If you have old version, is the part on the video board, if so post board number of that board, also picture if you can that may help in cross reference,this may help you,
                                there are a few good pics of old inverter/powe supply on badcaps
                                bob
                                • choodan007
                                  • Apr 2009
                                  hii bobdee ...thanx 4 ur support tatz by wrong i mention ter circuit tatz actuallyn u 850.near to that SMT on power section .itz a 8 leged ic.
                                  • Bobdee
                                    • Jun 2008
                                    • 461
                                    Hello again
                                    Your part number is SG6841S, Its a PWM controller,
                                    A link to part may help,
                                    http://cgi.ebay.co.uk/SG6841S-High-i...3286.m63.l1177
                                    bob
                                    you might want to check that mosfet and resistor by there, mine were gone
                                    • Nama
                                      • May 2009
                                      • 127
                                      Yet another PF751 bad. Monitor has been on now for 3 hours with no problem. Thank you for you follow up Brianh. Jacob
                                      ^Learning to walk on rice paper without leaving a trace,
                                      • Bubii
                                        • Jul 2009
                                        Hi Guys! I own Dell E153FPB and it has backlight problem. It works for a few secs and than the backlights turn off. The pictuire is there but no backlight. I did change pf751 and resoldered the transformers' contacts and it worked for about 20 mins (I tought it was fixed) and now it is just the same. I know it's easier to trow it in a trash but I spent so much time on research on this s##t...It was said that the problem might be the SG6841S High-integrated Green-mode PWM Controller but before I buy it I wanna know what you suggest. Help...Help...Plz.
                                        Thanks.
                                          Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                          This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                          I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                          I am comparing them to a brand new one that I installed
                                          The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                          I going to let it run for several days before I remount back on the wall next to the...
                                          09-05-2024, 06:48 PM
                                        • multimesut
                                          Dell 2007FPB Yellow Light Problem
                                          by multimesut
                                          Hello friends,
                                          A yellow light was flashing on my monitor. It was like it was constantly cutting power. When I opened it up, I saw that the big capacitor in the high voltage line was leaking. I replaced it. When I turned it on for the first time, it had the same problem again. But then, interestingly, it got better. The yellow light was on steady. But the monitor wouldn't turn on. When I examined them with a thermal camera, I saw that the Fli5961-LF reached 50 degrees Celsius and the EM636165TS next to it reached 100 degrees Celsius and was drawing high current on the motherboard....
                                          11-13-2024, 07:00 AM
                                        • boyebaran
                                          hisense 65k560 back light problem
                                          by boyebaran
                                          hi to all
                                          tv turn on and show logo(backlight on)than backlight turn off than red led in front blinking 7 time. the tv remote control working fine (sound on no picture).backlight changed same problem
                                          in 65k560 how to remove protection of backlight? picture of inverter and sockets attached .
                                          please advise me tnx
                                          05-20-2025, 07:11 AM
                                        • SDNarcia
                                          Dell 15R-5521 keyboard problem (KBC?)
                                          by SDNarcia
                                          Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
                                          As additional information,...
                                          07-20-2024, 10:47 PM
                                        • Achille15
                                          Dell N5110 problem
                                          by Achille15
                                          so, I have this laptop Dell Inspiron N5110 with a heating problem on both CPU (I7-2680qm) and GPU (GT 525m), I tried many solutions, like changing thermal paste every month, using thermal pads on CPU and GPU, even using thermal pads on CPU nearby coils; but nothing worked, just minutes after booting the laptop shuts itself down so I thought it might be a short problem, so I decided to check what's going on, so I went online and some tutorial (general one) said to check inductors in order to find the shorted circuit, after checking (CPU removed), I found the culprit to be...
                                          03-29-2025, 04:41 PM
