Dell E153FPB Back Light problem
  • EGuevarae
    replied
    Re: Dell E153FPB Back Light problem
    Originally posted by freakytiki4u
    Im having trouble uploading better pics due to size. Not sure how to make them the right size. lol
    Try Fotosizer. You drop in an image, specify a new size either in percentage of the original or in pixels, and it resizes it either replacing your original or saving it to another place (or the same place with another name). It is what I sometimes use when I have to meet size (either in Kb or in pixel dimensions) reqs.
    Eduardo
  • freakytiki4u
    replied
    I downlaoded the trial but it watermarks. lol, anyway I could email the pics to ya?
  • PlainBill
    replied
    I use Hamrick Software's Vueprint. (http://www.hamrick.com/upg.html) It makes cropping and reducing resolution of pictures easy. I'm sure there are other products that work as well or better; it's the one I'm familiar with.
    PlainBill
  • freakytiki4u
    replied
  • PlainBill
    replied
    I have a Dell E173FPs. Symptoms: Green power light just flashes quickly. No picture at all. I found 2 swollen caps and replaced them, still same thing. Green light just flashes quickly. The Power and Inverter board is model # IP-35135A (photo attached.) Anyone have any ideas what may cause this? I am looking for cold solder joints in the meantime. I have found it a good idea to just go ahead and resolder the transformers anyway as cold solder joints are so common. Srry if this is considered hijacking the thread.
    Suspect shorted transistors in the inverter. A picture (larger if possible) of the bottom of the board will help us identify them. I'm curious, please post the picture even if you locate them yourself.
    PlainBill
  • freakytiki4u
    replied
  • Bobdee
    replied
    Originally posted by Geordieboy
    I have just aquired an E153FPb which was showing a green light but no display. After reading this thread I tried the fuse PF751 and that has brought the backlights on. However there is no display. Enthused by moving a stage forward I did a bit more googling to see if I could find any similar experiences and came across the folowing:- http://www.elbase.ru/files/cd/monito.../BENQ%20FP531/ This is an index of Benq technical sheets, diagrams and fault finding flowchart for the Benq FP531. The E153FPb is based on the Benq FP531 (denoted by the b). There are some variations depending on the LCD manufacturer (eg. LG, AU) This may prove useful to anyone visiting here in the future. I am currently trying to source the components I need locally and if the thread is still running when I've got them I will leave an update.
    Welcome Geordieboy
    Badcaps does not close Threads its always glad to recieve new Info at any time
    Look forward to your update
    bob
  • Geordieboy
    replied
  • EGuevarae
    replied
    Congratulations!!!
    I second that. And for helping us, you can help all of the members & readers just posting your experiences. Your experience here might provide advice to new members, or not so new members that had not fixed this particular model. I guess that would be enough.
  • PlainBill
    replied
    Thank you for the info. I tested and found bad transistors. I ordered a few kits from Ebay and after repair the Monitor is working just fine. A friend gave me 2 more 19" monitors and I have also repaired them. I found several cold solder joints too and fixed those also. Thanks to all of you who helped and if I can ever do anything for you just ask. I will try my best.
    Congratulations!!!
  • freakytiki4u
    replied
  • Bobdee
    replied
    What is the proper way to test the Transistors? I noticed they have 3 legs each. I tested with my Ohm meter and there are differences but I would like to know specifically what Im looking for and how to properly test to determine defective ones.
    Testing out of circuit with MM set on Diode Check
    Red probe on B and Black on C, Should read about 600
    Red probe on B and Black on E, Should read about 600
    Testing for shorts between pins set MM to Buzzer and check
    B + C
    B + E
    C + E
    Probes both ways
  • EGuevarae
    replied
    Check this page.
  • freakytiki4u
    replied
  • freakytiki4u
    replied
    Originally posted by eguevarae
    Just remember to resolder transformer points and all other cold solder areas that you come across, or either the 07's will fry again ...
    Will do and thank you for the info
  • EGuevarae
    replied
    Thank you very much, I found the kits on Ebay and have a few on the way. I appreciate the continued quick replies. You guys really do rock!
  • freakytiki4u
    replied
    Originally posted by Bobdee
    They are either C5707s or 6s
    Read the front of one, (you may need magnifying glass)
    You can replace 7s with 6s if doing all four, but there are plenty of both on ebay (type in search box 2SC5607)
    You can get kits with 4 transistors + 2 fets fu9024n and a 2 or 3 amp p/fuse
  • Bobdee
    replied
    If I want to order the 4 transistors on Inverter = Q739, Q740, Q759, Q760
    for replacement, what would I ask for?
  • freakytiki4u
    replied
    Thank you very much for the quick reply. I will resolder and check with Ohm Meter tomorrow.
  • freakytiki4u
    replied
    Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
    by sam_sam_sam
    This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
    I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
    I am comparing them to a brand new one that I installed
    The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
    I going to let it run for several days before I remount back on the wall next to the...
    09-05-2024, 06:48 PM
  • multimesut
    Dell 2007FPB Yellow Light Problem
    by multimesut
    Hello friends,
    A yellow light was flashing on my monitor. It was like it was constantly cutting power. When I opened it up, I saw that the big capacitor in the high voltage line was leaking. I replaced it. When I turned it on for the first time, it had the same problem again. But then, interestingly, it got better. The yellow light was on steady. But the monitor wouldn't turn on. When I examined them with a thermal camera, I saw that the Fli5961-LF reached 50 degrees Celsius and the EM636165TS next to it reached 100 degrees Celsius and was drawing high current on the motherboard....
    11-13-2024, 07:00 AM
  • boyebaran
    hisense 65k560 back light problem
    by boyebaran
    hi to all
    tv turn on and show logo(backlight on)than backlight turn off than red led in front blinking 7 time. the tv remote control working fine (sound on no picture).backlight changed same problem
    in 65k560 how to remove protection of backlight? picture of inverter and sockets attached .
    please advise me tnx
    05-20-2025, 07:11 AM
  • SDNarcia
    Dell 15R-5521 keyboard problem (KBC?)
    by SDNarcia
    Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
    As additional information,...
    07-20-2024, 10:47 PM
  • Achille15
    Dell N5110 problem
    by Achille15
    so, I have this laptop Dell Inspiron N5110 with a heating problem on both CPU (I7-2680qm) and GPU (GT 525m), I tried many solutions, like changing thermal paste every month, using thermal pads on CPU and GPU, even using thermal pads on CPU nearby coils; but nothing worked, just minutes after booting the laptop shuts itself down so I thought it might be a short problem, so I decided to check what's going on, so I went online and some tutorial (general one) said to check inductors in order to find the shorted circuit, after checking (CPU removed), I found the culprit to be...
    03-29-2025, 04:41 PM
