Broken Dell Ultrasharp U2410
  • docmarcus
    • Jun 2014
    • uk
    Re: Broken Dell Ultrasharp U2410
    Originally posted by elagil
    I can report that the tubes I ordered were perfectly packaged. They work just fine though being slightly too wide but they are quite flexible.
    Hi mate, did it work after replacing or is the socket still charring up? i have the same problem and i can't find a socket replacement...
    regards
    • bammbammfran
      • Apr 2014
      • 476
      Are you looking for the plug on the bulb side or on the inverter side ?
      Can you post some good pictures of both
      and if you have the lcd panel number , that might also help
      ALSO do yours show signs of discoloring or melting ??
      • docmarcus
        • Jun 2014
        • uk
        to be honest I haven't checked the inverter side at all. the bulb pin was charred badly, I've cleaned it up with a brass wire brush. the rubber mount (on the bulb) did not like the arcing over time. I've tried cleaning with dental floss. arcing sound was there worked well for 10 minutes, then back where it was.
        I suspect that the arc discharge eroded the rubber mount reducing the contact surface. I will try applying a mechanical pre-load to press it on the tube pin.
        so annoying I can't test with the screen open
        no discolouring, no melting, just charring. I'll take some picture next time I'll open it
        if this doesn't work now I don't know if a new tube will sort it out or I'll need to replace the rubber socket as well.
        m
        • docmarcus
          • Jun 2014
          • uk
          Ok it was easy, the problem was not the lamp but the rubber socket. The contact was bad and the arcing made it worst over time (bigger hole for the pin). I did not have a soldering iron handy so I wrapped the pin in aluminum foil, now it works a joy. Solder blob would have been nicer though.
          M
          • elagil
            • Oct 2013
            • 44
            I also ended up wrapping one end of the tube in copper wire to widen it a little. That made perfect contact.
            • ld1984
              • Dec 2014
              • mn
              #26
              thank you at all
              i resolved the problem! i had the same problem and i find a bad contact on the pin to ccfl lamp, i have cleaned and i make a solder of tin on the pin
              the monitor is perfect
              i attach a photo of the rubber support of the pin
              • dandaman2234
                • Jul 2015
                • 6
                #27
                Had exactly the same problem recently.
                Managed to get a broken U2410f, the problem being that the screen would stay on for a few seconds and soon after would turn off. In order turn back on I'd have to disconnect it from the mains and reconnect but then again it would turn off after only a few seconds.
                On closer inspection I found that the backlight was causing the problem.
                I dissembled the entire unit and found that the cause of the issue was a charred CCFL tube + the plastic around the connector for the tube had melted, which seems to short the bulb out (of the electronics controlling its power supply).
                I ordered two CCFL tubes from CCFL Warehouse in the US (I'm from the UK), fitted both new tubes (second one was to replace one bulb I accidentally broke on entering the unit).
                The monitor is now working as normal, although there is a slight hum from the capacitors on the power board, simply due to age.
                Replacing the CCFL's is the solution.
                Cheers.
                • epistol
                  • Nov 2015
                  • France
                  #28
                  I too have had the same problem with the backlit of a DELL U2410f (the screen going black after 2s) but without this thread I would not have found it. There was only a tiny black trace near a CCFL tube connection. I manage to widen the hole over the conductive rubber connector, to get rid of possible burned material, I placed a small copper wire around the end of the CCFL tube to increase its diameter and that's it.
                  The monitor is working fine.
                  Thanks again to this useful forum.
                  • Colours18
                    • Jan 2016
                    Cheers.
                    What Size of CCFL tube did you order? thanks
                    • retrology
                      • Apr 2016
                      • usa
                      #30
                      I tried sending you a direct message but was unable to do so so I will post my question to you here. I noticed that you took the lcd screen completely off to get access to the tubes. My lcd screen is cracked and needs to be replaced. I already found a replacement screen. My question to you is do I have to completely disassemble the monitor to replace the lcd screen? Does removal and installation of screen require soldering? Can you refer me to any links or documentation that illustrates the procedure for accomplishing this? I am replacing screen with part number LM240WU4-SLB1. Any help will be immensely helpful. Thanks.
                      • badkond
                        • Nov 2016
                        • germany
                        #31
                        I would need help how to get to the backlight/bulbs - how to remove the last metal cover. I removed already all electronics, but there must be trick how to remove that cover.
                        • badkond
                          • Nov 2016
                          • germany
                          #32
                          @retrology:
                          as far as I can/could see/sag, no soldering is needed, just screwing, and connecting connectors.
                          How to open the monitor you can find on youtube ...
                          • TheQuentincc
                            Dell XPS 9300 (LA-H811P) internal display only shows Dell logo then nothing (everything else works)
                            by TheQuentincc
                            I have a Dell XPS 9300 that's working perfectly fine with an external display plugged, from windows the internal display isn't detected. At boot I can see the Dell logo then when it should display the boot/bios or whatever the screen goes black (no backlight, no image using a flashlight). I tried unplugging everything on the motherboard except the eDP cable but it didn't helped (so it's not the lid sensor). LCDVDD/backlight power are powered down when this happen, PANEL_BKEN_EC and ENVDD_PCH are also down to 0v. It's weird, it almost feels like the motherboard is shutting down the display...
                            06-26-2025, 01:44 PM
                          • Stanley1843
                            Dell Inspiron 15 3520 - AC Adapter shows "Not Installed - Not Charging
                            by Stanley1843
                            I bought a used Dell Inspiron 15 3520 laptop and the battery isn't charging. When I go to the BIOS setting it shows that the battery health is "excellent" but on the AC Adapter shows "not installed". I checked the pins from the power connector on the motherboard and I didn't found a short on the PS_ID pin. It dould be the charger (I don't know if this is the original) or what I have to check?...
                            09-27-2025, 08:44 PM
                          • Bowline
                            by Bowline
                            06-11-2025, 10:13 AM
                          • Akhlz001
                            by Akhlz001
                            09-20-2025, 07:15 PM
                          • master3112
                            by master3112
                            07-29-2025, 01:55 PM
