E171FPB vertical line issue
  • Welchs101
    • Sep 2008
    • 979
    i have a dell E171FPB which powers on fine but when on has a "greenish" veritical line on the screen....see enclosed picture
    any ideas? is this a cap issue? my gut tells me its not.
  • Welchs101
    • Sep 2008
    • 979
    Re: E171FPB vertical line issue
    no one has any comments?
    my gut was to trash it......
    • 1supertech
      • Apr 2012
      • 384
      Clean & check lvds cable if line is still there it's possible bad screen
      • rounin
        MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
        by rounin
        I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck β€” hoping someone here can shed some light.
        πŸ›  Original Issue
        The machine initially wouldn't negotiate 20V over USB-C β€” stuck at 5V.
        ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
        04-19-2025, 01:18 AM
      • almarhum
        To fix laptop screen vertical line by working on its EDP cable
        by almarhum
        Has one here really gone through fixing laptop screen vertical line(s) by repairing/replacing its Embedded DisplayPort (EDP) cable, so would recount and share the complete steps of the process here now?
        As most, if not all, believe the laptop screen vertical line(s) caused by defective Embedded DisplayPort (EDP) cable which slipped and passed through either laptop screen hinge but post here is asking help to elaborate definitively the useful, real knowledge of repairing in the most complete, correct way, esp. can decide/determine whether the cable can still be fixed or must be re...
        05-07-2024, 02:12 PM
      • mrsith
        Samsung UE58TU7100K - no picture, vertical line
        by mrsith
        Hi.
        Got UE58TU7100K with no picture - backlight comes on though. Figured out that's a perfect candidate for cut tape method.
        This model has just one LVDS tape coming off main board - and two panel boards underneath the LCD screen are connected to each other via small tape. Like curved screens. I've tried to disconnect half of the screen (5he side without LVDS connector on it, obviously), no joy.
        Disconnected the tape (main board side). Applied a small piece of tape, covering first ~4-5 pins. Powered the TV on - got picture. In negative, but that's...
        02-07-2023, 11:18 AM
      • Technomancer
        Nintendo 2DS SD Card Reader issue. Problem on the clock line?
        by Technomancer
        I have a 2DS that I am working on that has a problem reading SD cards. It knows that card is in the slot (which, means the detect pin is working anyway) but it says it can’t read the card.
        Here is what I have done so far:
        -Tried SD card in another 2DS and on PC, works great.
        -Tried piggybacking another SD card slot (just so I didn’t have to take the other one off), same issue.
        -Compared voltage drop readings from a working 2DS to the faulty one. All reads are very close except one, the 7th pin from the left, with the pins closest to you, which I believe...
        06-07-2022, 09:01 PM
      • bdalkiran
        55EC930V white vertical line appeared (need help)
        by bdalkiran
        Dear All,
        I have 7yrs old LG OLED 55EC930v. One day a white line appeared on mid of the screen. 10mins later it was disappeared. When turned on tv again it was appeared again. Currently when power on tv is clicking sound relay, LG logo illuminates, 3 seconds later clicking sound relay and tv goes off. Screen is black during this on off period. When trying with service remote(pwr on) , clicking sound, white vertical line appears on screen(drawing line from up to down) and clicking sound then tv goes off. Please see video below.
        Please advice how to proceed and what is the...
        01-13-2023, 04:16 PM
