Hanns-G HH251 with bad CCFL
  • MarcoTheRipper
    • Sep 2013
    • Italia
    Hi guys!
    just had this display going bad the other day.
    The screen powered up, 2 seconds of light then it goes all black (but the status LED stays on green).
    Opened it up, the secondary is good it delivers steady +5.2 and +12v (actually a bit low on the 12 volts.....it is somewere near 11.9 but at least they're steady).
    I then tried the 4 CCFL. The top couple seems good as with these plugged in only, the display still lights up, while the lower couple doesn't. I tried plugging the 2 non working CCFLs in the other inverter and the result is the same, so to me it seems the problem must reside in the lamps themselves.
    I unmounted all the LCD part of the display and found out that the lamps are broken near the electrode.
    I'm now searching on the net for a replacement and I have no idea where to look for.
    Do you know where to find suitable CCFLs for this panel in Europe?
    The panel is an Hannstar TN Film with model numbero HSD250MUW2-A
    Thanks!
    Best Regards,
    Marco.
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4476
    • Italy - Milan
    Re: Hanns-G HH251 with bad CCFL
    Try Calpedel.it in Italy, they has many sizes..
    • maudam
      • Dec 2013
      • 24
      • Italy
      I have your monitor too with a possible trouble on power.
      If your monitor is actually open, can you please verify that with power cord connected, but with monitor off, the +12v are active or there is only 5.2v active ?
      It will help me troubleshoot my problem.
      Thanks in advance
      For original spare parts try this:
      http://shop.teknema.it
      Another link with generic parts:
      http://it.eetgroup.com
      and let me know where you will find the parts, in case i need it.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4476
        • Italy - Milan
        maudam hear me, i don't think 12v is your problem, make the test that members has suggested, with the 1k resistor, if you want you can put a 1k resistor also from 5,2v to pson even with psu detached from the rest, you will see 12v appear..
          Marco is the second person that has bad CCFL beside this one: https://www.badcaps.net/forum/showthread.php?t=22967
          • ttmi100x
            HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
            by ttmi100x
            Greetings everyone,
            I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
            The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
            Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
            Upon closer inspection...
            07-31-2024, 06:36 PM
          • angelos
            Sinotec LCD TV Model ST-42KC42F "CCFL lamps not switching on"
            by angelos
            Hi Guys,
            It's been a while that i have been active on the forum, sorry for that. My primary job has been keeping me quite busy.
            The above set starts up with sound working just fine but the CCFL lamps (Inverter) runs for one second and switches off.
            My 24V supply is steady and the ON/OFF pin to the inverter is at +5V.
            The only thing i see is the PWM signal pin is at +5V without any square wave being emitted. Is this normal? as far as i can remember there needs to be a square wave pulse there. Am i right?
            I will now measure with my oscilloscope probe on...
            06-11-2023, 02:14 AM
          • mikey5791
            Help on Samsung Syncmaster T220 dead ccfl lamp
            by mikey5791
            This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
            Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
            10-18-2020, 03:17 AM
          • caseyjay_48
            Sony KDL-46BX450 Inverter Troubleshoot Logic
            by caseyjay_48
            I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
            I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
            09-23-2022, 08:08 PM
          • cruiser_
            bn44-00264c - CCFL emulation
            by cruiser_
            hi there,
            I am fixing a SAMSUNG le40b530p7w. It has 2/3 lamps which are acting up. This leads to the inverter (bn44-00264c) shutting off entire backlight after several minutes. I ruled out inverter issue - the PFC_OUT voltage is stable 390V, so are 13V & 5.3V. ICs are getting the power etc. When the backlight is shut off, these voltages stay.
            I do not want to disable protect feature completely, but rather 'emulate' these fussy CCFLs.
            I tried to replace the CCFLs with capacitors - tried 22pf, 47pf, 47*2pf.
            unfortunately the backlight goes...
            11-11-2021, 10:19 AM
