I've read the posts about 2 seconds and then black, often referring to LG1934's. Mine will stay on for anywhere from 5 to 20 minutes, will suddenly start to flicker slightly, dim and then go black. If I turn off the monitor power for a few minutes, then turn it back on, I have a screen for another 5-20 minutes. It feels like caps that are heating up, breaking down and then quitting. Any suggestions on where to start looking for bad caps? Power supply card? The monitor is about 5 years old, and I've ordered a replacement, but would like to repair this one for another computer, when the replacement arrives.
LG1934S Heat Problem?
Re: LG1934S Heat Problem?
Hi, welcome to BadCaps.
Look for swollen caps on the power/inverter board.
Also listen carefully for arcing noises that may point to a bad CCFL connection or a bad
solder joint.
Feel free to post pics and ask for further help, there are a lot of seasoned monitor repairers here.36 Monitors, 3 TVs, 4 Laptops, 1 motherboard, 1 Printer, 1 iMac, 2 hard drive docks and one IP Phone repaired so far.... -
Just by listening to your symptoms it sounds like a ccfl is going bad. Or bad wiring, or something in the inverter section.
You can try a diagnosis technique I learned from budm out here. Take a hair dryer and heat up different sections of the power board to see if it shuts off faster. But I wouldn't really superheat anything. Just a litle warmer and see if it shuts off faster.
I'm suspecting you have a bad ccfl; in which case the hair dryer won't speed up anything. The only way I can think to test that is to plug in a spare known good ccfl into each connector until you find one that stays on past 25 to 30 minutes. That would be your bad ccfl.
Unless anybody has any better suggestionsComment
Thanks for the replies. I just received notification that the new monitor will arrive tomorrow, so I'll work on this one this weekend and post what I find. Unfortunately, if it turns out to be a bad ccfl, it'll probably end up in the recycle bin, as I don't have a good one to test it against. Since it's been running for 5 years, I doubt anything has gone wrong with the wiring but a I suppose a cold solder joint could be showing up now. Anyway, I'll post what I find.Comment
This is an example of what happen to the caps when heated up, this monitor backlights start working after the caps are heated up, the ESR goes down.
https://www.badcaps.net/forum/showth...ghlight=AL2416
This is what happens due to poor wiring at the lamp's ends, common problem.
http://s807.photobucket.com/user/bud...?sort=3&page=1Never stop learning
Well, I had it all apart, and there were no obvious signs of heated or expanded caps, All the components look as they should. I put it under power for a few minutes and there wasn't any arcing, or sound of any kind. A close inspection of the solder joints showed quite a few that were gray and suspicious. Overall soldering quality is typical of Chinese hand soldering. I re-soldered a large number of joints that looked suspicious and put it back together. When I turned it on, it ran for 2 1/2 hours, making me think I blundered onto it, but then it failed again-- same symptoms. I didn't use the hair dryer approach because the space I had to work in didn't strike me as safe enough to work in with the panel attached. That might have turned it up, as I've had some success with heat guns in the past on computer boards. So, I'm giving it up. I have a refurbed 22" Samsung as a replacement and it's working fine. Thanks for the suggestions, the pdf service manual was a help in the disassembly/assembly.Comment
by DanPokaI bought this p2210f dell monitor to fix. Schematic is the same as p2210.
This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...-
by ttmi100xGreetings everyone,
I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
Upon closer inspection...6 Photos-
by AskicHello to all,
I have a problem with monitor that is delivered together with CCTV system.
The monitor appears to be completely dead, there is no LED power diode and it doesn't react to pressed power button.
I have disconnect display and check many components on the power supply part of the board. There is no anything obvious and monitor is about 3 years old. There are no bulged caps. When measuring voltages on the output connector to VGA board I can measure stable 14.5 V on 12V pins and stable 5.07V on 5V pins. So I assumed that this part of the board is OK....-
by CptChronicI have an intermittent display problem with my monitor, when I plug in the HDMI cable to my (or any) laptop, you see the connection screen shrink on the laptop as it usually would before displaying on the monitor but 95% of the time the monitor display stays black.
Before it cut out all together, tapping the monitor control button a fair few times would make the screen display, and everything work fine.
But now it never does it. Not sure what's going on, hoping someone can help. I'm capable of stripping the thing down and soldering in new parts if needed, or programming...-
04-24-2023, 04:33 PM -
by Rick_1234Good evening, gentlemen.
Things I tried
- Bought a new AC adapter thinking that was the problem but the problem...-
- Loading...
