BenQ G2420HD white screen
  • Grundell
    • May 2013
    • 14
    Hi guys,
    This is the my first post on these forums, I have a good grasp of electrical theory. Problem is I don't to do PCB work very often and I'm quite rusty at the moment. I really would like to gain a bit more exp. troubleshooting and repairing at a component lvl. In saying that it leads me to my first issue.
    I have a G2420HD BenQ PC monitor that I use with DVI-D (single link). Today I was using my PC as per usual when all of a sudden the video image disappeared and all I was left with was a white screen. I believe this to be the back-lighting only. So I rebooted as you do, only to be met with the same blank white screen. My mate and I who consider ourselves to be quite PC-savvy started troubleshooting, ruling out the GFX card by testing my PC on his monitor with success. So I have pulled the monitor apart and have discovered 3 things of note. A mainboard, a smaller video board and the ribbon cable that connects the LCD screen to the video board.
    I have inspected the capacitors and no bulging or electrolyte leakage is evident. All solder joints look solid with minimal frosting (likely machine joints), and no blackening of any joints is evident. Does anyone have any exp. with this kind of repair. As I would like to start multimeter testing from the right point. I can take pictures of the components if necessary.
    Cheers
  • smason
    • 1652
    Re: BenQ G2420HD white screen
    Hi, and welcome.
    White screen is usually a Tcon board problem, and often just a fuse.
    Look for a surface mount fuse on the t-con board.
    If you post some pictures, we can point it out if you're having trouble finding it.
    • Grundell
      • May 2013
      • 14
      Thank you for the quick reply, I suspected the fuse but thought there would be no back-light if it was blown. There is a ceramic fuse on the large (T-con) board with soldered end caps. Is this the one you are referring to?
      • smason
        • 1652
        You are correct if you mean the fuse on the inverter/power board, if it was blown you'd have no backlights.
        The Tcon is the board connected to the LCD panel, not the one with the inverters/power supply, or the video logic/VGA connector.
        • Grundell
          • May 2013
          • 14
          The T-con board has no visible fuses, the following pictures are of the T-con board and the mainboard with the power supply.
          • wobbin
            • Apr 2013
            • 18
            • United Kingdom
            That's the main board rather than the TCON.
            You'll probably find the TCON hiding under a metal screening cover on the back of the LCD panel - it'll be where that big flat ribbon cable is connecting to.
            HTH
            • Grundell
              • May 2013
              • 14
              Here are some photos of the T-con, I can't see any fuses but there is a circular battery of some description. I assume holds the settings for your monitor.
              Last edited by Grundell; 05-27-2013, 11:51 AM. Reason: found the fuse, it's very small. Would testing the continuity of the fuse be ok whilst installed on the TCON?
              • smason
                • 1652
                The pic is a bit hard to see, but see the red circle, does that say F1?
                • Grundell
                  • May 2013
                  • 14
                  It sure does, can I test it's continuity whilst installed without causing anymore damage?
                  • Grundell
                    • May 2013
                    • 14
                    bump
                      Just measure the voltage of both ends of the fuse against chassis ground to see what you read.
                      • smason
                        • 1652
                        Yes, with the power disconnected, or what Budm said, whichever is easiest for you.
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          Continuity is a poor way to test a fuse. There is no industry standard wrt to what is "continuous" on multimeters. Some multimeters consider something "continuous" if the reading is less than 1800 ohms.
                          A good fuse should measure less than 1.0 ohms.
                          --- begin sig file ---
                          --- end sig file ---
                          • Grundell
                            • May 2013
                            • 14
                            Well it's good and bad haha. With the ribbon cable disconnected and no PWR F1 is definitely 'OL' (open), so the fuse is KIA. Just want to confirm that this blown fuse is responsible for the all white screen and no image. If someone could provide a brief description for my peace of mind that would be fantastic.
                            Moving fwd to repair, where can i get a part no. and specs for this specific fuse? Considering it is a "fuse for ants."
                              Looking like this?
                              http://s807.photobucket.com/user/bud...ml?sort=3&o=20
                              Also read my guides under my signature.
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                Yes a blown fuse is causing your white screen. A fuse can blow because something is shorted on the tcon board or it died from age/thermal stress.
                                A clear focused picture of F1 helps us help you.
                                • Grundell
                                  • May 2013
                                  • 14
                                  Is there any recommendations for troubleshooting to determine which cap would have shorted to blow the fuse, or is it best to replace the fuse and give it the benefit of the doubt?
                                  • Grundell
                                    • May 2013
                                    • 14
                                    This is the best pic I can get at this stage.
                                    • Lumberjack777
                                      • 464
                                      With that photo all I can tell is that it's white.
                                      Can you get a magnifying glass and read some info from it?
                                      It might have a "W" or an "M" or some capital letter.
                                      • Grundell
                                        • May 2013
                                        • 14
                                        I don't have a magnifying glass, I can't make out a letter on the fuse. I will try to get better pictures for you. Is there any other way to work out what fuse it is from schematics etc. My main concern however is that the new fuse will blow straight away. Should I bridge the fuse to test if it works, or should I do voltage checks on the TCON before I replace the fuse?
                                        Debug Information
