HP LP3065c dark shadow
  • onastvar
    • Mar 2013
    • 9
    • usa
    I have HP LP3065c 30" monitor, where suddenly the other day, a top part of the screen has a dark shadow, please see attached (image shows monitor turned on, with solid white background). Monitor is over 5 years old. Out of warranty. Could this be fixed, is it worth fixing? Thanks.
  • selldoor
    Slow Learner
    • 7870
    Re: HP LP3065c dark shadow
    It looks like a bulb is out - unusual for it to stay on at all I have assumed it is not led. Perhaps first thing to try woul be open it up an swap the lamp cables over if that is
    possible
    Welcome to the forum-
    We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back (in the same orientation) and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
    Examples of what is needed
    https://www.badcaps.net/forum/attach...7&d=1280167246
    https://www.badcaps.net/forum/attach...6&d=1280167246
    https://www.badcaps.net/forum/attach...4&d=1280167246
    It will be useful if you can say a bit about yourself - skills tools etc.
    • klkmalik
      seeking Tips
      • Nov 2011
      • 68
      • UAE
      They have two reason , (1) top of CCFL fault, (2)also picture is dim with dark possible Tcon board. but before u must check power section is ok.
      • onastvar
        • Mar 2013
        • 9
        • usa
        Also, I've recently noticed, if I turn the monitor on, there's no dark shadow, after 2 seconds it appears on the top part of the screen. If I turn if off and on again same thing happens, dark shadow comes on after 2 seconds.
        Thanks! I'm not sure if it's possible to swap lamp cables. I took pictures the best I could. Please advise if anything else I should check?
        • selldoor
          Slow Learner
          • 7870
          Ok Then try unplugging one bulb at a time - unlikely that it will all stay on but you might discover if it is one bulb or more that is the problem.
          Do you have any spare bulbs on anything you could substitute
          Could you make up a tester bulb
          https://www.badcaps.net/forum/showth...ght=test+lamps
          • onastvar
            • Mar 2013
            • 9
            • usa
            If the bulb happens to be the issue, how hard is it to replace it?
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4478
              • Italy - Milan
              Hi, you've waited much time! It sounds like a 2 sec. to black sympthom so it can be some on the circuit for the upper part of the screen (lamps only) or more probably a faulty lamp that unlike most other cases it let the bottom part to stay on, this is quite obvious because we can see from the photo that there are 2 big chips on inverter so i think 2 separate feedback circuits, now you can post here the marking of those chips (bigger chips on photo 5) so we can maybe tell you how to disable the protection and see if the lamps stands on, after it we can also experiment if the lamp can be salvaged fro some time. Bye..
              P.S.: you asked "is it worth fixing?", think that i was driving crazy for a 15", yes it is worth..
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4478
                • Italy - Milan
                i assume that the upper side of monitor is the upper side in photo 5.. ?
                after, to answer to your question, yes changing a lamp can be a very difficult task.. this is why i suggested to trim the prot. and retard the lamp change, but i think i will need the schematic or at least further pictures of the inv. board.
                • onastvar
                  • Mar 2013
                  • 9
                  • usa
                  Davi, thanks for your help!
                  I gave the monitor to tv/monitor repair guy, who told me we have to change power supply (PSU type/no.: Liteon PA-3171-2-LF Rev:B) He also said part wasn't available from his suppliers.
                  I really would like to fix this monitor, any suggestions where to get he Power Supply?
                    by momaka
                    03-15-2023, 10:17 PM
                  • wattage
                    AOC AG493UCX 49-inch monitor - Firmware request
                    by wattage
                    Hello Badcaps Community,
                    The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                    07-13-2025, 04:41 PM
                  • kalemaroni
                    MAG274QRF-QD 27" gaming monitor half backlight shadow
                    by kalemaroni
                    A customer called me up and said that half the screen was like a shadow - presumably the backlight has partially gone. I've never done a repair like this on a monitor, only circuit board based repair on Macbooks etc - is it something that's doable or generally not?
                    04-23-2024, 03:52 PM
                  • ant3202
                    HP 27es - LED monitor - Monitor Flashing On - Off
                    by ant3202
                    Hi Everyone
                    Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                    https://www.badcaps.net/forum/troubl...lashing-on-off
                    The monitor is HP 27es LED Monitor
                    https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                    The monitor will randomly blackout and display no signal and will recover again.
                    Sometimes need to power and off again to restore the display but...
                    03-20-2025, 07:30 PM
                    Wise Wing F199 19'' LCD monitor - recapped
                    by momaka
                    Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                    I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                    When I saw the Craigslist post, I wasn't...
                    08-24-2020, 10:58 AM
