Dell 2405fpw - Backlight problem
  • Denz
    • Mar 2013
    • 12
    • United Kingdom
    I have casually been reading posts on this site for about a year hoping that “one day” I'll have enough knowledge to fix my Dell 2405fpw. The monitor turns on (power button lights) but nothing shows up until I use a flash-light and see that the “please connect input“ default error screen is bouncing around. So the back-light needs more power.
    I was hoping it was the usual capacitor problem but after changing all of them the monitor would only have a brief flash. I would also hear a click/buzz sound which sounded like someone was flicking a switch on and then off from the TDK inverter circuit board. The sound may have also originated from the CCFLs.
    On the power board, I replaced the big capacitor because it was leaking and the smaller ones were bulging. I also replaced mosfet and resistor near the fuse as it was causing other posters problems due to their capacitors leaking.
    The power-board is outputting 21.3 V when it is switched on and 21.7 V on standby.
    TDK board
    While tracing the current, I found that it stops just before the transformers at the surface resistor/fuse (F1, F2 & F101). I'm not too sure what those little white components are but one has a much different reading than the other two;
    F1: 0.3 Ohms
    F2: 78.8 Ohms
    F101: 0.4 Ohms
    I also tested the output while the monitor was switched on and got 21.3V for all three of the components.
    For some reason I'm unable to get a reading from more than 1 leg of the transformer.
    The output voltage to the TDK inverter board (while monitor is switched on) is:
    Black: 0
    Brown: 0
    Red: 21.7V
    Orange: 21.7V
    Yellow: 21.7V
    Green: 1.4V
    Blue: 3.2V
    The output voltage to the Benq logic board:
    White: 3.2V
    Black: 3.2 V
    Brown: 1.4V
    Red: 0
    Orange: 0
    Yellow: 3.2V
    Green: 6.6V
    Blue: 0
    Purple: 0
    White: 0
    Am I right in thinking the power board is good and I should be diverting my attention to the other boards ?
    Does anyone have any suggestions/tips how I could test the inverter board more vigorously and what components are more likely to fail ?
    If the monitor flashes for a split second, would this mean the CCFLs could be still alive and intact ?
    Sorry if this post is a little disjointed, I wrote this over months so I wouldn't forget.
    Thank you in advance for all your help, the threads on here have already been very helpful but sadly I have come to a grinding halt so any suggestions are welcome.
  • selldoor
    Slow Learner
    • 7870
    Re: Dell 2405fpw - Backlight problem
    F2 is a fuse and it has blown
    If it has a K on it - flash has blanked it it may be 1.5a
    There is no standard marking but I have seen a few from different sources with k=1.5. They tend to be a bit expensive and having to buy 10 makes it moreso.
    Some mebers use small pico fuses and solder them in first as from some sources
    they can be a bit cheaper.
    Cpc seem to have a FREE postage promotion on at the moment
    http://cpc.farnell.com/cooper-bussma...-bb45-00001003
    might do - they have others as well you will need to get the right physical size
    - it is often easier to solder the new one piggyback on top of the old one - less chance of damage to the fuse and the board.
    • Denz
      • Mar 2013
      • 12
      • United Kingdom
      Thank you Selldoor, I've removed the fuse and yes, it's broken. I've googled SMDs and and yes the "k" stands for 1.5 amp.
      A even bigger thank you goes for the CPC free delivery link. That will save me a fair amount of money since I usually order components from RS.
      Fingers crossed, this solves the issue unless the power supply has blown something else.
      Thanks once again for your guidance
      • selldoor
        Slow Learner
        • 7870
        Good - I hope it works for you. Dont worry about voltage on the main transformer - you cant measure it with a standard multimeter. Dont try and measure voltage on any inverter transformers they can be 2000v and will blow your meter and you!!.
        When you get the fuses we can look at the rest. Just one query where you have ~21v
        that is ok if its meant to be 20 but not good if its meant to be 24v
        • (*steve*)
          • Mar 2013
          • 15
          Black: 0
          Brown: 0
          Red: 21.7V
          Orange: 21.7V
          Yellow: 21.7V
          Green: 1.4V
          Blue: 3.2V
          White: 3.2V
          Black: 3.2 V
          Brown: 1.4V
          Red: 0
          Orange: 0
          Yellow: 3.2V
          Green: 6.6V
          Blue: 0
          Purple: 0
          White: 0
          Thanks Denz. I can't help you with your problem. But you've helped me with mine.
          Seldor also helped by making me realize that F701 and F702 on the power board are fuses.
          Thanks guys.
          • Denz
            • Mar 2013
            • 12
            • United Kingdom
            Glad the data helped you out. If you need more readings for confirmation, I'll be happy to post it once I get my fuses delivered.
            • Denz
              • Mar 2013
              • 12
              • United Kingdom
              I've just replaced the fuse and after I switched the screen on it blew again.
              I clean the board by spraying some isopropyl alcohol and found a dirty looking component C31 which I assume is some kind of surface capacitor ? It looked like it had been soldiered by myself (messy) and had some yellow residue beside it. I'm not fully sure if it has exploded or it's just dirt.
              I've only got a cheap £30 multimeter so it's unable to test capacitors. Is it possible to test capacitors with a basic multimeter ? I'm going to have to remove another capacitor from the board to compare the results. I usually just replace the standard capacitors with spare capacitors lying around but in this case I'm not going to have a surface mount one.
              Does anyone else have any other ideas of what could be disturbing the F2 fuse ?
              Sorry about the photos, it's really hard for my camera to focus on the miniature components.
              Thanks for your help
                Please do the resistance testing of the MOSFET, start with Q106. We are looking for low resistance reading between pin 1 and 5 (or 6, 7, 8 since they are tied together), do the same for the MOSFETs and report the readings.
                • Denz
                  • Mar 2013
                  • 12
                  • United Kingdom
                  Hi, I'm unsure if I've numbered the pins correctly. I assumed the pin number starts with the dot/indent. The 5,6,7,8 pins are all linked according to my continuity test. I've attached my version of the pin numbering system just in case it is wrong.
                  From pin 1 to pin 5 (diode/continuity test mode)
                  Mosfet model - 4512C AA5MV
                  Q106 - 531 ohms
                  Q105 - 532 ohms
                  Q6 - 532 ohms
                  Q7 - 533 ohms
                  Q4 - 532 ohms
                  Q5 - 530 ohms
                  Thanks for the help
                  • Denz
                    • Mar 2013
                    • 12
                    • United Kingdom
                    I decided to reattempt measuring the resistance using the Ohms function on the multimeter since the diode function try was wrong.
                    I could only get a reading if I set the multimeter to 200M Ohms which was probably why I ignored it in my first try. I'm not entirely sure I've used the correct setting ?
                    From pin 1 to pin 5 (200 M Ohms setting)
                    Q106 - 1.2 M ohms
                    Q105 - 1.2 M ohms
                    Q6 - 1.2 M ohms
                    Q7 - 1.2 M ohms
                    Q4 - 1.2 M ohms
                    Q5 - 1.2 M ohms
                    It seems like all of those Mosfets are working. There is still that suspicious looking ceramic capacitor near the broken fuse and between Q6 & Q7 which does not look good so I am going to remove and test it.
                    Is it possible for a ceramic capacitor to take out a fuse or am I barking up the wrong tree ?
                    There are no markings on these capacitors so I'm probably have to sieve through the internet and this forum for some clues.
                    • selldoor
                      Slow Learner
                      • 7870
                      There will be few clues - I think you can only test them for short with the meter you have.
                      You could also test on ohms from each side of the fuse to ground.
                        OK, I just look at the spec sheet of the AF4512, it is dual MOSFET's (P and N channels), so you need to take the reading between pin 3 and 5 also.
                        • Denz
                          • Mar 2013
                          • 12
                          • United Kingdom
                          From pin 3 to pin 5 (200 M Ohms setting)
                          Q106 – 1.1 M ohms
                          Q105 – 1.1 M ohms
                          Q6 – 1.0 M ohms (tested many times)
                          Q7 – 1.1 M ohms
                          Q4 – 1.1 M ohms
                          Q5 – 1.1 M ohms
                          I tested the SMD ceramic capacitors. I can do simple low capacitance tests on multi-meter .I can test using 100u, 2u, 200n, 20n.
                          All of the following capacitors are located next to the mosfets which I measured in the previous post.
                          Capacitance test – On the board ( 100u)
                          C106 – 14.5 uF
                          C105 – 14.5 uF
                          C30 – 2.2 uF
                          C31 – 0.8 uF
                          C2 – 14.5 uF
                          C4 – 14.5 uF
                          I originally thought C30 & C31 were broken because the values were considerably less than the other capacitors on the board. Then I decided to test it out of the board and the results came back all the same.
                          Capacitance test – Independently ( 100u)
                          C106 – 2.2 uF
                          C105 – 2.2 uF
                          C30 – 2.2 uF
                          C31 – 2.2 uF
                          C2 – 2.2 uF
                          C4 – 2.2 uF
                          This led me to test the bigger capacitors which were Nkcom 180uF 30V. All three capacitors were testing out of the circuit and came back with completely different results with the same capacitance settings. I know my meter can't read 180uf but I still expect to see some consistency with the results.
                          I've bought some Panasonic 180uf 35V caps to use as replacements because something must have be wrong with them. Hopefully these caps have enough surges and irregularity to break fuses.
                          Thanks for your help guys, I can tell I'm/we're making progress.
                          I know it would be a lot easier if I had a lot more knowledge and the correct equipment, lol.
                          • m1ch43lzm
                            by m1ch43lzm
                            05-12-2025, 08:37 PM
                          • Borse2008
                            Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
                            by Borse2008
                            Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
                            I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
                            • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
                            • There’s
                            07-15-2025, 04:55 AM
                          • Garret Matt.
                            DELL Latitude 5430 Rugged CORE_D5K Rev.A00 Schematic and/or Board View
                            by Garret Matt.
                            I'm Working on replacing an Inductor on this Dell's board and I need to come up with a compatible replacement. As much as I would like to smash a comparable 2R2 in the same spot I'd like to confirm the specs before confirming a killed board. For my purposes I'd be happy with a second opinion on the replacement inductor or the actual schematics/board view. As this is a commonly used Dell Rugged in my local service area, schematics would greatly help in the future.
                            Thank you in advance for any assistance you can render.
                            Inductor In question. Buzzes like...
                            06-20-2025, 01:21 PM
                          • howardc64
                            by howardc64
                            Yesterday, 05:17 PM
