Benq FP91G+ few milliseconds to black - beyond my expertise
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    When I got this Benq FP91G+ its power light wouldn't even come on when the power button was pressed
    One of the C5707 pair indicated by red arrows tested faulty, so I replaced the pair
    A solder joint on the component between those C5707 was cracked, so both its legs have been resoldered
    Because a joint was cracked, I've also resoldered legs of the components indicated by yellow arrows - are they usually FU9024 ?
    Not in this instance - one is marked F1 F37 FQU 11P06, the other F1 F38 FQU 11P06
    I've also resoldered legs of the transformers
    The C5707 pair indicated by green arrows is original
    All capacitors have been replaced, not necessarily by high quality ones, but sourced from a local specialist supplier (not a chain store)
    Now after pressing the button, the power light stays green
    There'll be a brief flash from the backlights, usually with the Benq logo visible on screen for a fraction of a second
    Help please - how do I progress from here ?
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
  • mariushm
    • May 2011
    • 3799
    Re: Benq FP91G+ few milliseconds to black - beyond my expertise
    This issue can also be caused by CFL lights going bad (too old) or due to the wires having a poor connection to the lamp ends.
    The wires going to each lamp are simply soldered to the end of a lamps, as you can see in this page here: http://www.ccflwarehouse.com/lasotu.html
    See the pictures in the link above
    Often the wire breaks under that silicon jacket, or the solder no longer makes good contact and the connection is interrupted.
    The inverter has a sort of "protection" mechanism in which if a lamp doesn't start in a second or so, it turns off all lamps.
    So you'd have to carefully open the back of the panel to reach those silicon jackets, pull them gently to get access to the solder and visually check if the wires are properly connected and to be sure the insulation is not damaged by electric arks. Be sure to do this with the monitor turned off, the lamps have 700v going through them when turned on.
    Ideally, you'd just use another cfl tube with the wires already connected and known to work (maybe removed from a monitor that failed for other reasons) so you save yourself the trouble of disassembling the thing.. this way you just unplug one lamp at a time and replace it with your test lamp and if the monitor stays on you know that lamp you disconnected was bad.
      Fuse PF801 read less tahn 1 Ohm?
      • pfrcom
        Oldbie
        • Jun 2006
        • 1230
        Reads ~ 556 Ohm in either direction
        • pfrcom
          Oldbie
          • Jun 2006
          • 1230
          Originally posted by retiredcaps
          3) Open fuse
          Some boards will have a fuse (F designation) or picofuse (PF designation) and they may be open because a transistor was shorted or some other component went bad.
          If you have a manual range multimeter, set it to 200 ohms (two hundred). You can test for open fuses "in circuit" by (with power off and unplugged)
          a) put black probe on one pin and red probe on other pin - read/record ohm
          A reading of less than 1.0 ohms indicates a good fuse. Anything higher than 1.0 ohm is a sign of an open fuse. Do NOT replace fuses and turn on the power back on without checking for what caused the fuse to go open otherwise you will just be replacing the fuse again.
          Damn - looks like I wasn't thorough enough
          I'd already desoldered, and put back, diodes which, in circuit, showed ohms in both directions - but seemed OK out of circuit
          How bad would it be, to swap in a resetable fuse salvaged from a motherboard ?
          Or for that matter, a one-time fuse salvaged from a motherboard ?
          • retiredcaps
            • Apr 2010
            • 9271
            Resolder all the inverter transformer pins regardless how they look. If you don't the picofuse is likely to blow again. Don't ask me how I know!
            --- begin sig file ---
            --- end sig file ---
            • retiredcaps
              • Apr 2010
              • 9271
              Here is a case where the fuse isn't quite 100% open. On really cheap multimeters the threshold for continuity is any reading less than 1800 ohms which could mislead the user into thinking the fuse is good because the multimeter beeps continuous.
              • pfrcom
                Oldbie
                • Jun 2006
                • 1230
                Thanks budm - looks like you've saved another one for me
                Replaced PF801 as shown in first attachment, with fuse salvaged from a computer motherboard - probably a keyboard fuse in its original incarnation
                Leads were barely long enough to be soldered, shown by second attachment, apologies for the blurred pic - measure ~ 0.02 ohm solder joint to solder joint, so should suffice
                I hope people who know what they're doing aren't horrified by a 5A fuse replacing the original 3A - only alternative on hand was unmarked, so I thought better the devil you know ...
                Now the monitor lights up and complains about no connection, so time to reassemble and test properly
                @retiredcaps - the inverter transformers are the black components with yellow tape on them, aren't they ? - I think I've already done them all, sorry to be vague but this one's been hanging around a while
                • retiredcaps
                  • Apr 2010
                  • 9271
                  Yes.
                  • smason
                    • 1652
                    Now that's an interesting case.
                    My (flawed) logic would have been to think "ok the backlights come on briefly, if the fuse was blown, they wouldn't come on at all" and I probably wouldn't have gotten around to testing the fuse.
                    • pfrcom
                      Oldbie
                      • Jun 2006
                      • 1230
                      Mine too - and the reason this one's been hanging around for a while
                      Talk about a DOH moment when budm asked about PF801, then I measured it
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        Since I have worked on 4 or 5 of these Benq variations, I meaure the fuse regardless of the symptoms. It only takes 5 seconds and then I move onto checking all the usual suspects.
                        553 ohm fuse is not the same as an open fuse (infinite resistance).
                          This Belfuse, when it goes bad (over current), instead of going completely open circuit, it has high resistance instead, so it is like feeding B+ through 500 Ohms resistor to run the inverter circuits.
                          • pfrcom
                            Oldbie
                            • Jun 2006
                            • 1230
                            UPDATE
                            Pleasure of this repair lasted only a few months before being replaced by pain from the monitor refusing to switch on one morning
                            So it got put aside until I needed a working monitor
                            Expecting my recycled picofuse to be the culprit, I was surprised to find that it tested OK
                            Not necessarily the case for F601, the fuse beside the AC input socket
                            F601 has no audible beep when tested with the Diode test / Continuity setting of my Fluke 77
                            Although it does measure ~6.45 M if I use the meter's Ohm setting - presumably this number is MilliOhms, indicating a good fuse ?
                            Am I barking up the wrong tree, or have I found the likely culprit ?
                            I'd already tested the four C5707 as good, before checking the fuses
                            HELP PLEASE
                              • 31013
                              suspect a problem with the caps - eiher the 4 blue ceramics or the 2 gray poyesters.
                              most likely the polyesters.
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                No, that is MEGA ohms on the Fluke 77.
                                The Fluke 77 can only show 0.1 ohm resolution. Straight from the manual.
                                • seppde
                                  Benq Zowie XL2540K / Power board failure / 6Pin-SOP-Chip identification
                                  by seppde
                                  I've got a Benq power board of a XL2540K monitor which suffered from a power cut and is since defective / won't turn on. It's got obvious defects, some blown resistors, some burning around the drain pin of a MOSFET...
                                  ... and some 6-pin IC I struggle identifying, that is driving said MOSFET.
                                  The IC is labeled as IC601, so someone with a circuit schematic could probably identify it really quick, unfortunately I can't find the schematics.
                                  In other power boards of Benq for which I did find the schematics, IC601 is an 8-pin NCP1200 PWM controller - I suppose...
                                  02-09-2024, 05:19 AM
                                • AJ847.63e
                                  BenQ TH681 Originally overheating now wont fire the lamp - Colour wheel not starting
                                  by AJ847.63e
                                  Hi All.
                                  Does anyone have any reference materials or something I can use to try troubleshooting a BenQ TH681? Google unfortunately has turned up zip. I did find a service manual for a W series BenQ but that is pretty much useless, it's more a glorified user manual. A list of voltages would be great as I suspect my mainboard is faulty, the colour wheel voltage is not dipping like it should.
                                  The one I am troubleshooting now was originally overheating after a lamp replacement. It originally would take 2 minutes or so for it to shut off and blink the temp and lamp lights...
                                  09-18-2023, 06:42 PM
                                • ChatBTC
                                  Benq EX3501R
                                  by ChatBTC
                                  Hi!
                                  I am new to this site, and found it via LLM ChatGPT.
                                  I got a BenQ Ex3501R monitor which i have had for a while now, it works pretty good until recently, it struggles to turn on, i can see the purple welcome screen is shown for a brief time before it vanish again, usually it stays on for a couple of seconds before the main computer screen is shown, but image is still kept black, before i just had to turn it off and on a few times and that would leave it on, but now it takes ever longer to stabilize the image on the screen, ocasionally i can see the computer desktop...
                                  01-24-2025, 08:49 PM
                                  BenQ JoyBook S52 S53 Laptop Schematic
                                  Quanta ED3...
                                  11-01-2024, 02:03 PM
                                  BenQ S72 Laptop Schematic
                                  Inventec Grasshopper Rev 3.0...
                                  11-01-2024, 07:23 AM
