troubleshooting DAC 19M008 power supply
    Re: troubleshooting DAC 19M008 power supply
    But for the fuse for the 5V which is used by the Main board to blow open, the main board must be drawing too much current from the power supply board.
      You may have active short, see page 59, you will see that the V5A feeds two regulator U4, U6. Check the resistance of the output pins (2, 4) and ground and see what you have, the short can also be in the T-CON board which is fed by 3.3v vreg U6. You may also want to disconnect the ribbon cables to the LCD panel and see if the 5v will be OK, I hope you have more than 1 fuse, you can use 0.47 Ohm 1/4w in place of the fuse for testing.
      • mikeh1
        • Feb 2013
        • 37
        • usa
        #43
        on both U4 and U6, both the leftmost (#2 ?) of the 3 pins are short to ground (using the heads of the mounting screws), could both regulators have gone bad?
        • jetadm123
          • 2169
          #44
          You may be measuring the ground pin of the regulator against ground, which will show a short. Suggest to download the datasheet for the regulator and compare the pin you're measuring against the datasheet.
          • mikeh1
            • Feb 2013
            • 37
            • usa
            #45
            found a datasheet for the AMC1117 regulator, the pin I was measuring was pin 1 which is ground, pin 2 and 4 are output and neither regulator is short at these pins
            • mikeh1
              • Feb 2013
              • 37
              • usa
              #46
              I'm going to order some more fuses, this time I'm going to power up the power supply board all by itself, to see if it pops the fuse.
              • mikeh1
                • Feb 2013
                • 37
                • usa
                #47
                Just replaced the F102 fuse, with power supply board not connected to the main board I get 5v at the 5v pin on the main board connector, so it seems to be the main board that's blowing the fuse.
                Are there any other parts on the main board that can be tested with power off?
                • selldoor
                  Slow Learner
                  • 7870
                  #48
                  Diodes
                    Did you disconnect the cable as I suggested?
                    • mikeh1
                      • Feb 2013
                      • 37
                      • usa
                      #50
                      Just powered it up with the two LCD panel cables disconnected, was unable to disconnect cable from speaker/button board. Fuse popped again. Do I have a bad main board?
                      • mikeh1
                        • Feb 2013
                        • 37
                        • usa
                        #51
                        Is there a trick to removing the speaker/button-board ribbon cable from the main board. The two LCD panel cables were easy enough, but can't see how to disconnect other cable.
                        • Mark369
                          • Jul 2009
                          • 163
                          #52
                          just pull out no trick
                          • mikeh1
                            • Feb 2013
                            • 37
                            • usa
                            #53
                            Got it. I was looking for some kind of release like the other two connectors. Guess I'll get another main board since it looks like there isn't much serviceable on this board and the regulators aren't shorting. Found one on Ebay for $10.
                            • mikeh1
                              • Feb 2013
                              • 37
                              • usa
                              #54
                              Just got around to ordering the main board. I will post the results once I get it installed. Keeping my fingers crossed!
                              • mikeh1
                                • Feb 2013
                                • 37
                                • usa
                                #55
                                FIXED!! troubleshooting DAC 19M008 power supply
                                FIXED!! Thanks to Sabre504 and budm for all your help AND patience! Hopefully I'll get another 7 years out of this monitor.
                                  by sam_sam_sam
                                  03-31-2024, 02:12 PM
                                • shamsudeen
                                  Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                  by shamsudeen
                                  Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                  I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                  i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                  07-19-2025, 07:14 AM
                                • dragon3x
                                  >>> Troubleshooting Delta Power MAX 500ATX ATX power supply
                                  by dragon3x
                                  Hi, this is for troubleshooting and, hopefully, repairing a Delta Power psu
                                  that is still quite new, as it worked OK for some months until it failed.
                                  At the time I was not into power supply electronics; it was put
                                  aside and a new power supply installed inside the computer. Also at the time
                                  power supplies were half the price of today's.
                                  On the PCB there are a D339 and 7500B chips.
                                  I have found that schematics with these 2 chips (see included file).
                                  Does it represent the actual circuit of the MAX-500ATX, I cannot tell.
                                  Some measurements,...
                                  06-05-2024, 03:34 PM
                                • JimBanville
                                  Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                  by JimBanville
                                  The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                  Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                  I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                  I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                  09-13-2023, 07:21 AM
