Dell 1707FPt No Power
  • maybenever
    • 158
    I got this monitor apart and I don't see any for sure bad caps. I've read all the threads on this monitor, but no one ever listed the pin voltage going to the logic board. When I first put AC power to the main boad, I get 2.45vdc at the two top pins, then the voltage starts falling, finally going to .o1 volts.
    I have 163vdc across the large filter cap. Am I kooking at a cap problem somewhere?
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Dell 1707FPt No Power
    Disconnect all boards from the power board. After doing so, are all the DC voltages on the pins stable and steady? List them like so
    pin 1 = 0.0
    pin 2 = 2.45
    etc
    If they are steady, then reconnect the main board and re-measure the same pins. Report your findings.
    --- begin sig file ---
    --- end sig file ---
    • maybenever
      • 158
      pin 1 = 0.0
      pin 2 = 2.45
      etc
      Board was disconnected when I was checking voltage. Pin 1 pin 2, same reading 2.45v and steady drop to almost nothing.
      • retiredcaps
        • Apr 2010
        • 9271
        What about the other pin voltages?
        • maybenever
          • 158
          With board turned over, pins in the upper right corner, top pin (1) and pin 2 had voltage. Don't have the board at hand to recheck, but I think pin 3 also had voltage. pin 4 & 5 were gnd, and the rest of the pins had no voltage. I checked voltage at different spots, and where I found voltage, it was counting down like the pin voltage. I did find at one spot that had 21.5v, and it seemed to be steady.
          • maybenever
            • 158
            Pin 1,2,3,&4 2.45vdc and droping, pin 5,6,7,8 = no voltage. pin 9 = .8vdc, pin 10 & 11, no voltage.
            That was yesterday when I had heat in my shop, 65 degrees.
            This moring, I wanted to check the voltage to be sure, no heat, it was 35 degrees, voltage changed.
            pin 1 thru 4 = 5.3 to 5.1, but not droping.
            pin 5 thru 8 = no voltage
            pin 9 = 1.5 to .5vdc
            pin 10 & 11 = no voltage.
            In one thread, you found pin 10 to be BL and pin 11 to be brightness adjustment ( I think ).
            • maybenever
              • 158
              Update, went back in my shop this afternoon, 50 degree, pin 1 thru 4, 5.25vdc and holding. Pin 9, 1.73v and holding. Whats going on? Fired up the heater, held the board in front of it for a minute, voltage started droping, .01v per sec, all the the way to zero. Pin 9 seemed to stop at .03v. Pins 5 thru 8 check to be grounds, .05ohm between them and ground. This is a cap problem, right? Which ones first? (or all).
              Does anybody know what the voltage should be at these pins?
              • maybenever
                • 158
                Does this picture help any? I've got most of those caps on hand (panny FM), I've got them all in the correct uf, but Dell used larger volt caps than most, I'd have to get some of those.
                • retiredcaps
                  • Apr 2010
                  • 9271
                  I suspect someone has worked on this board before. I don't recall seeing United Chemi-con KY caps on a power board mixed in with Rubycon YXG. Both brand and series are good quality.
                  The fact that it fails when heated could be a cap problem or a bad solder joint.
                  If it was my monitor, I would reflow each capacitor joint with some fresh 60/40 solder and retest.
                  • maybenever
                    • 158
                    I'm going to work on it right now, I'll get back. I wish I knew to proper output voltage, seems like one pin should be 12 or 14 volts. No markings on either board (thanks dell).
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      Who makes these two caps? What brand and series?
                      • maybenever
                        • 158
                        It looks like SU Scon 0627 (M) 220uf 35v
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          I would replace those two for sure with Panasonic FR/FM/FC.
                          • maybenever
                            • 158
                            Thanks alot for the help. I've got those in 220uf 50v FMs, I'll give it a try.
                            I'm going over the back of this board with a 10x glass, if someone has worked on it, damm, they're good.
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              I could be wrong on that. It is just surprising to see 3 different capacitor brands used. If they were all one brand, then I wouldn't suspect anything.
                              • maybenever
                                • 158
                                I replaced the 220uf caps (circled in red), no change, voltage flopping between 5.14v & 5.25v, held board in front of heater a few seconds (a 35,000 btu space heater), voltage started dropping. I replaced the 10uf 50v cap (circled in yellow), voltage held steady at 5.25v on all 4 top pins. Pin 9 steady at 1.68v. After a few minutes (all voltages holding steady), I held it in front of heater, damm, the voltage did not drop, only flopped between 5.14v and 5.25v again. Unplugged AC, had a beer, plugged it back in, voltage steady again. Gotta be going in the right dirrection.The cap circled in green is a 4.7uf 50v, that one I don't have. Tomorrow, I'm connecting boards together and see if it has any life. I'll get back.
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  The yellow one is the startup cap. That would have been one I would have suggested next to replace after a 60/40 reflow.
                                  The Su'scon had to go though.
                                  • maybenever
                                    • 158
                                    That 4.7uf cap is a Su'scon, is it a startup cap?
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      The green cap is on the other side of the optoisolator. It may be part of the feedback circuit?
                                      • retiredcaps
                                        • Apr 2010
                                        • 9271
                                        What brand was the 10uf 50v cap (yellow)?
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          I'm trying to troubleshoot a Microsoft Surface Pro (5th gen) model 1796 that won't power on. Motherboard model is M1007506-015. My priority is retrieving data, but the SSD is integrated so it looks like if I can't repair it it'll need to go to a data recovery company. I've done a little basic board repair before, but nothing this advanced until now. So please forgive my ignorance in advance. ๐Ÿ˜…
                                          05-29-2024, 02:01 PM
                                        • Mark01
                                          Dell Optiplex 7490 AIO - red power led after flash
                                          by Mark01
                                          Hi guys,
                                          This is my first post! ๐Ÿš€
                                          I have no idea what Iโ€™m doing, but Iโ€™m learning by trial and error.
                                          Iโ€™m currently working on a Dell Optiplex AIO 7490โ€”one of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...
                                          07-04-2025, 12:54 PM
                                        • zlr8r
                                          Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
                                          by zlr8r
                                          hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
                                          Ill try and give as much info as I can.
                                          Dell Inspiron 17 (7786) Laptop
                                          Service Tag: 5J0NHT2
                                          Bios: 1.9.0
                                          When I received this , it would only flicker on the KB backlight for a second, then off and on.
                                          Then it started getting weirder!
                                          Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
                                          12-12-2023, 09:31 PM
                                        • LimesKey
                                          Dell Inspiron 7506 Silver 2n1 - "HELLCAT 15" - No power
                                          by LimesKey
                                          Hi everyone, I have an Inspiron 7506 laptop I've had for a few years, and it'd occasionally have a problem where after I'd power it off, it wouldn't turn on again unless I disconnected, drained residual voltage by pressing the power button, and reconnected the battery. It now seems to be occurring every single time I shut down the laptop and attempt to turn it back on again. I have done all the common troubleshooting steps, such as completely disconnecting the battery & CMOS battery and draining the voltage and leaving it for an hour, and I've even replaced the battery. This is definitely...
                                          10-17-2025, 05:33 PM
