Hyundai ImageQuest L70S+
+ More Options
Posts
  • 820uF
    • Apr 2012
    • 39
    • Russia
    Hi!
    I have this problem with this display "when power cable connected, power button green LED blinking" Nothing happens when button pressed.
    All caps look fine.
    Transistor secondaries differ under 3%
    Big Diodes show:
    ...with 2k ohm function:
    D3. .256 back on cathode side, second way it shows .743
    D6. .256 back on cathode side, second way it shows .747
    Images from power poard:
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Hyundai ImageQuest L70S+
    On the back of the board there is a place marked F3 - is there a fuse on the front of the board to correspond?
    With it all connected up and on ,black probe on ground with the red probe test each pin on the connector to the main board. List what you get
    along with what it should be (listed on the back of the board.
    • 820uF
      • Apr 2012
      • 39
      • Russia
      F3 fuse is ok. current flows thru - no resistance.
      Now about voltages - when video board connected they start jumping -
      12V: 11-18V
      5V:1,5-4,5V
      SLP: 0,00V
      MID: 0,7-2,4V
      When video board not connected:
      12v: 12,24V
      5V: 4,98V
      SLP: 0,00V
      DIM: 2,57V
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        Do the backlights flash at all
        Can you check the voltage on each side of that fuse.
        Black lead on ground then red probe on each side of fuse
        Please post clear pictures front and back of the main (Video) board
          I'd replace the startup cap if voltages are jumping.
          • 820uF
            • Apr 2012
            • 39
            • Russia
            actually the display powers on after some time led blinking
            • selldoor
              Slow Learner
              • Dec 2010
              • 7870
              The startup cap is probably the one next to U2
              After the set has cooled down switch it on again and try heating that cap with a hairdryer to see if the set comes on quicker
              • 820uF
                • Apr 2012
                • 39
                • Russia
                replaced this cap (47uF 50V) with same parameter cap and still same blinking.
                • 820uF
                  • Apr 2012
                  • 39
                  • Russia
                  both sides 16,12V it droped about 2minutes from 16,4V - same voltage as 12v pin has.
                  pics of mainboard:
                  • selldoor
                    Slow Learner
                    • Dec 2010
                    • 7870
                    Was that with all boards connected?
                    On the main board there are two voltage regulators can you test them.
                    ( Haha Up to the same point as in your other thread)
                    • 820uF
                      • Apr 2012
                      • 39
                      • Russia
                      U1
                      pin 1 = 0,01
                      pin 2 = 2,50
                      pin 3 = 4,40
                      U3
                      pin 1 = 0,01
                      pin 2 = 3,30
                      pin 3 = 4,40
                        U1 (2.5V REG), U2 (3.3V REG)
                        They are OK.
                        Can you take the resistance reading on the IC2 (Vref Diode, ?? 431)) on the power supply board. Take the reading like this:
                        Pin 1 & 2
                        Pin 1 & 3
                        Pin 2 & 3
                        • 820uF
                          • Apr 2012
                          • 39
                          • Russia
                          on 20k function
                          IC2
                          Pin 1 & 2 - 9,93
                          Pin 1 & 3 - 3,7
                          Pin 2 & 3 - 13,64
                            It's IC1 in this case that's the Vref.
                            • 820uF
                              • Apr 2012
                              • 39
                              • Russia
                              on 20k function
                              IC1
                              Pin 1 & 2 - 1,02
                              Pin 1 & 3 - 4,09
                              Pin 2 & 3 - 3,71
                                Sorry, that will be IC1.You have to test it off the board. I have them here also.
                                Flat side toward you, legs down.
                                The readings on all 3 leags combination usinh Ohm meter should be in the Mega Ohms (to over range) range (does not matter how you use red/black probes)
                                • 820uF
                                  • Apr 2012
                                  • 39
                                  • Russia
                                  IC1 offboard
                                  on 2M
                                  Pin 1 & 2 - first it showed jumping numbers around 1.400, now it shows nothing
                                  Pin 1 & 3 - nothing
                                  Pin 2 & 3 - nothing
                                  IC1 offboard
                                  on 2k
                                  Pin 1 & 2 - like runs out of scale
                                  Pin 1 & 3 - 1.207
                                  Pin 2 & 3 - .913
                                  IC1 offboard
                                  on 20k
                                  Pin 1 & 3 - nothing
                                  Pin 2 & 3 - nothing
                                  IC1 offboard
                                  on 200k
                                  Pin 1 & 3 - nothing
                                  Pin 2 & 3 - nothing
                                  • 820uF
                                    • Apr 2012
                                    • 39
                                    • Russia
                                    is "TL431CLP 2.5-36V 100mA" suitable replacement for this "UTC TL431 SAF" ?
                                    • 820uF
                                      • Apr 2012
                                      • 39
                                      • Russia
                                      replaced this TL431CLP and same
                                      • selldoor
                                        Slow Learner
                                        • Dec 2010
                                        • 7870
                                        Ok - try a hairdryer on different parts of the board to see if it comes on any quicker
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • survivalbloke
                                          Acer Predator Helios 300 - will not power up if battery is CONNECTED
                                          by survivalbloke
                                          This was a no power initially. Thanks to your help, I discovered it was the first mosfet, so I replaced. Now, the device will power up only if the battery is NOT connected. As soon as I connect the battery, it shuts off. If I connected the battery while the device is off, it simply will not respond to the power button. I replaced the battery, and while I suppose the new battery could be faulty, I'm assuming it is not. I'm having the same behavior with the new battery. I measure .2v at the charging coil. Manually applying power to the + and - at the battery header, there is no charging happening....
                                          06-25-2025, 12:20 PM
                                        • beogeek
                                          820-2915-A Wont power on with battery connected
                                          by beogeek
                                          Ok so this doing my head in and hopefully someone more knowledgeable will be able to assist.
                                          I've got a MacBook Pro 820-2915-A it will power on without the battery connected, but when the battery is connected it will do a 2,3-second fan spin when pressing the power button and then nothing.
                                          After measuring and probing around I found that R7051 was bad, reading high instead of 2.2Ω so I replaced it. Still the same issue, I have the green light on the charger but it won't power on or charge the battery.
                                          So to cut the long story short I've replaced U7000,...
                                          02-26-2022, 01:29 AM
                                        • muhuruu
                                          PS5 too many USB devices connected
                                          by muhuruu
                                          Hello. I have a problem with a PS5 console that I bought to learn electronics repair. The auction description indicated that the console had been dropped. The HDMI port and USB ports were damaged. The HDMI port was replaced by the previous owner, and after his repair, the console worked for 2 days and then became dead. After receiving the console, I replaced all the USB ports. After replacing them, the console started to turn on. On the logo screen, it displays "too many USB devices connected". My further attempts to fix the error involved replacing the Southbridge, 4 TPS2001D chips,...
                                          05-19-2025, 07:14 AM
                                        • versionlab
                                          Weird problem, laptop stays on when connected to another pc
                                          by versionlab
                                          Hi, I want to ask for advice about an interesting issue I've been having with a sony vaio laptop.
                                          Client came and said that "a desklamp touched the back of the lid while laptop was operating normally and it caused the office's circuit breaker to trip. Laptop had never turned on since".
                                          After taking the laptop apart (checked dc adapter everythin ok), I found a faulty MOSFET on the motherboard which I replaced. Laptop managed to turn on. However, while booting it shut down. Nothing else seemed faulty and thermals were ok. Shutting down was coming at random...
                                          10-26-2022, 03:43 AM
