Dell 2408WFP
  • johnnydiaz
    • Apr 2012
    • 52
    Dell 2408WFP
    I have 2 Dell 2408WFP monitors. For the past few days when I turn one of them on in the morning for the first time it appears to be 20-30% dimmer and within 10-15 minutes it gets brighter and remains that way until I shut it off for the night. I haven't opened it up yet. Just wondering what the symptom could be.
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Dell 2408WFP
    Description suggests bad caps. With the back off try heating the boards gently with a hairdrier to see if you get it brighter quicker.
    Welcome to the forum-
    We can often help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back (in the same orientation) and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
    Examples of what is needed
    https://www.badcaps.net/forum/attach...7&d=1280167246
    https://www.badcaps.net/forum/attach...6&d=1280167246
    https://www.badcaps.net/forum/attach...4&d=1280167246
    It will be useful if you can say a bit about yourself - skills tools etc.
    • Toasty
      • Jul 2007
      • 4171
      Re: Dell 2408WFP
      Could also be old tubes. Room temperature also affect fluorescent tubes brightness at startup.
      Try starting it and going to an all white screen. Notice any pinkish hue? If so, I'd bet on the tubes starting to weaken.
      Not sure of the style used in the 2408, but the 2407 uses 6 "U" bend tubes @ $20 each.
      T
      veritas odium parit
      • johnnydiaz
        • Apr 2012
        • 52
        Re: Dell 2408WFP
        Sorry I havent had time to open the unit up. This morning when I was using the monitor it had green dotted horizontal lines and the screen was moving left and right. When I read a pdf with a gray background the green horizontal lines disappear but the screen still shakes left to right. What does this sound like?
        • johnnydiaz
          • Apr 2012
          • 52
          Re: Dell 2408WFP
          Does anyone have a service manual for it?
          • LAS
            • Sep 2011
            • 144
            Re: Dell 2408WFP
            Johnnydiaz, let me know if you can confirm it's bad tubes. If so I may be able to help you with the leftovers of my 2408.
            • Bowline
              by Bowline
              06-11-2025, 10:13 AM
            • master3112
              by master3112
              07-29-2025, 01:55 PM
            • F R 2568
              Dell Latitude 5420 does not start (no post) need help to find the reason why
              by F R 2568
              Hello all,
              this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
              I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
              If the laptop is only connected to the AC adapter (battery removed):
              When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
              The power/battery...
              01-08-2025, 05:45 AM
            • diamon
              Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
              by diamon
              I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
              Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
              Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
              Pictures of these boards:
              Dell Latitude 5520 https://www.ebay.com/itm/256052956663
              Dell Latitude 5530 https://www.ebay.com/itm/125844181534
              Dell...
              02-28-2024, 12:51 PM
            • lalle-
              Dell G5 SE 5505 - "Invalid memory installed" after BIOS update.
              by lalle-
              Hello!
              I have a problem with a Dell G5 SE 5505 laptop that I hope someone can give me a few pointers on.
              [OK, it's not really a laptop, I'm running the motherboard on my desktop with only cooling, RAM and an M2 drive attached.]
              I had some performance issues, so I decided to update my BIOS from 1.7.0 to the latest version, 1.20.0.
              The computer restarted and the update dit not want to continue without a battery connected, even though I used dell's method of bypassing this requirement.
              I tried updating to a custom BIOS from Reddit user Satori_Nori https://www...
              08-11-2024, 02:01 PM
