Acer AL2216W / DAC-19M009 dead?
  • hitz
    • 36
    • germany
    Hello!
    I've got a serious problem with my Acer AL2216W. It started with the orange stand-by LED getting darker a few weeks ago. Until yesterday there was no problem except the LED, the monitor was working fine. So yesterday i turned it off and when i came back, the orange LED was off and the monitor didn't start at all.
    I opened it and checked the caps (had to change them a few years ago) two 1000μF were bulged. Today I replaced them with some of the same local shop, re-assembled the monitor, but no orange LED, no starting
    So I plugged it in and checked the outgoing voltages:
    13.8V pin was about 14.3V (a little high?)
    5V pin was exactly 5V
    Back to checking parts: The power switch and LEDs were fine, so I followed up the conducting path from the LEDs on the switch circuit board to the MOSFETs (K84 T9) and measured the voltage of the pins to case-ground:
    green LED (power on):
    Gate: 3.26V
    Source: 0.16V
    Drain: 0V
    orange LED (stand-by):
    Gate: 3.26V
    Source: 0.16V
    Drain: 0V
    I checked the MOSFETs with the diode-check of my multimeter when the PSU was off, both gave me same values for the different measuring options (G-S, G-D, whatever).
    So I followed the MOSFET's source circuit track to the PSU-connector. Its taken from a circuit between the top two pins (8 & 16) - voltage between them: 0.16V
    The voltage seems a bit low to me, but following the pin conducting paths didn't lead me to any new idea. At this point I'm out of knowledge, so please help me!
    Re: Acer AL2216W / DAC-19M009 dead?
    "I checked the MOSFETs with the diode-check of my multimeter when the PSU was off, both gave me same values for the different measuring options (G-S, G-D, whatever)."
    So what is the reading?
    And "whatever" what does that mean?
    Use Ohm mode and check S-D, S-G, D-G and tell use what the readings are, also tell us what ohm scale you are using, when look for short, I use 200 Ohms first then go lower scale from there.
    Also check the fuses:
    https://www.badcaps.net/forum/showth...ght=DAC+19M009
    • hitz
      • 36
      • germany
      Didn't know the exact combinations I measured, but those combinations gave me nearly same values for both MOSFETs.
      The Ohm-mode shows only a "1" in first position on the display, but in diode-check mode it shows following values (guessing its Ohms cause values for resistors were the same in Ohm-mode an diode-mode):
      (left: black tip - right: red tip)
      orange LED's MOSFET:
      S-D: (starting with 752, slowly decreasing to) 684 Ohms
      G-S: 1247 Ohms
      G-D: 1806 Ohms
      green LED's MOSFET:
      S-D: (starting with 750, slowly decreasing to) 688 Ohms
      G-S: 1248 Ohms
      G-D: 1820 Ohms
      Fuses are fine (F102, F200, the one near AC connector and F1 near 16-pin connector on the smaller circuit board).
        "green LED (power on):
        Gate: 3.26V
        Source: 0.16V
        Drain: 0V
        Gate: 3.26V
        Source: 0.16V
        Drain: 0V"
        Th voltage reading you are showing indicated that you are not getting the DC voltage feeding the MOSFET. What DC voltage do you get on that axial glass fuse, that fuse feeds the 14vdc fo powering the inverter circuits.
        • hitz
          • 36
          • germany
          Its 23.2V
            Please see pictures, you need to check the DC for the inverter again.
            OK, your earlier post are not the same MOSFET I had in mind, the MOSFET'S are the 8-pin dip on the power supply-inverter board
            • selldoor
              Slow Learner
              • 7870
              Originally posted by hitz
              Its 23.2V
              Was your meter on vDC?
                Or at the right ground point?
                • hitz
                  • 36
                  • germany
                  I hold the black tip onto a screw attached to the monitor case. 23.2VDC, controlled it. The P605 Ohm-values are for both MOSFETS the same, as u can see on the picture i attached. The 3rd pin shows only shortly a value ~1700Ohms but then goes to unmeasurable.
                    "P605 Ohm-values are for both MOSFETS " What is the P605 Ohms?
                    There are 4 MOSFET's 8-PIN DIP that I redlined and I need the resistance reading of ALL FOUR MOSFET's.
                    • hitz
                      • 36
                      • germany
                      I've only 2 on my board, both got the values you can see on the picture i attached to my previous posting.
                        OK, I see and understand your answer now. Sorry about the confusion.
                        • jetadm123
                          • 2169
                          If I correctly understood your testing of the AOP605, you tested S-D and G-D, but not S-G. You can test S-G by measuring across pins 1-2 and 3-4 of both AOP605.
                          • hitz
                            • 36
                            • germany
                            Oh yes, I missed that.
                            Pins: Top/Bottom MOSFET
                            1-2: 284 Ohms / 282 Ohms
                            3-4: 740 Ohms / 741 Ohms
                            • jetadm123
                              • 2169
                              Try checking fuse F1 (to the right of the black 16 pin connector) on the main/logic board.
                              • hitz
                                • 36
                                • germany
                                • jetadm123
                                  • 2169
                                  Oops! Missed the earlier post about F1. Since you're not getting a power led, but good output voltages, possibly something wrong with the main board. There appears to be two voltage regulators on the main board U7 and U4? (upper right corner). Reconnect the power board to the main board and measure the voltage at each pin of U7 and U4. Also, what are the part numbers of U7 and U4?
                                  • hitz
                                    • 36
                                    • germany
                                    Its U7 in the middle and U6 in upper right corner. Both are labeled 50117K-G.
                                    The middle pin of U7 is directly connected to the source pins of both LED-MOSFETs I mentioned earlier.
                                    For measured voltages open the attached picture.
                                    • jetadm123
                                      • 2169
                                      It looks like U7 may be bad. We also want to make sure the output of the middle pin of U7 is not shorted to ground. To verify, unplug your monitor from power. With your meter set to 200 ohms, place one probe on the middle pin and the other probe to a ground point. Hopefully, you won't read zero ohms.
                                      I'm thinking the regulators are part of the 1117 family of regulators.
                                      • jetadm123
                                        • 2169
                                        If you look at the link below, post #5, you will see that a Viewsonic VX2235 uses the same mainboard as your Acer. And the output for both regulators should be 3.3V. If U7 passes the ground test, you should be able to use a 1117-33 regulator as a replacement.
                                        https://www.badcaps.net/forum/showth...light=50117K-G
                                        • double_DD
                                          How can I be sure that my EC chip is dead?
                                          by double_DD
                                          As the title suggests, how can I be sure that my EC chip is really dead?
                                          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                          03-12-2025, 07:47 AM
                                        • disorder
                                          ps5 edm-033 dead after hdmi/usb ports destroyed
                                          by disorder
                                          hello guys,
                                          i need help to repair a edm-033 ps2
                                          history : as always hdmi port and usb ports destroyed after unplugged
                                          after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                          so i changed it
                                          now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                          but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                          i don't see any projection of liquid metal on pcb.
                                          01-14-2025, 12:48 PM
                                        • zunasthegreat
                                          Chieftec GPS-450-AA with dead 20N60C3
                                          by zunasthegreat
                                          Hello everyone hope all doing well!
                                          I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                                          09-01-2024, 07:12 PM
                                        • Beton
                                          Finding a dead short component
                                          by Beton
                                          Hi guys!
                                          I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                                          So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                                          I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                                          I have a bench PSU and if I try to inject voltage the voltage...
                                          12-10-2021, 01:05 PM
                                        • FiguringITout
                                          MSI Raider GE75 - Not posting, probable dead CPU
                                          by FiguringITout
                                          Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
                                          Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
                                          07-25-2024, 07:27 AM
