Acer AL2216W / DAC-19M009 dead?
  • hitz
    • 36
    • germany
    Re: Acer AL2216W / DAC-19M009 dead?
    U7 gives me 13 Ohms on middle pin vs. ground from the VGA connector, close enough to zero? =(
    • jetadm123
      • 2169
      Well, the regulator could be internally shorted to ground. The only real way to test would be to remove U7 from the board and measure the middle pad to ground. Once off, you can also try testing U7 with a 9V battery. Apply the 9V to the input and measure the output with your meter. However, without a load on the regulator, there's potential for a false reading. Of course, if you read a zero volt output, then you know it's bad for sure.
      • hitz
        • 36
        • germany
        Okay, i'll try it tomorrow. Thank you so far
          Looks like Jetadm is leading you to the right path to find the problem. If you remove the regulator and the low resistance reading is still there, then you can possible have bad MLCC , there are 5 of them that are connected to the regulator output pin, they tend to fail shorted out.
          • hitz
            • 36
            • germany
            I just unsoldered the regulator. Its resistance values are:
            GND/ADJ - OUT: 338 Ohms
            GND/ADJ - IN: 1810 Ohms
            IN - OUT: 1491 Ohms
            Looks fine so far, I guess.
            I measured the caps you marked on the picture. I unsoldered one side of each one and measured eachs resistance, all infinte -> caps are fine too?
              Are these the value measure at the pads on the board without the regulaor or the measurement made on the regulator itself?
              The resistance we are interested in is the OUT pin pad and Ground pad reading.
              • hitz
                • 36
                • germany
                #27
                Values are from the regulator itself. So I have to unsolder it again and measure between the connectors on the circuit board?
                  We need to find out where the 13 Ohms reading on the OUT pin is from.
                  • hitz
                    • 36
                    • germany
                    #29
                    Ah okay. I unsoldered it and it gives me the 13 Ohms between GND/ADJ- and OUT-pad.
                    Following the conducting path near the left cap you marked me (red) led me to the blue marked component. Ohm-meter gives me 13 Ohms between both pins and 0 Ohms between bottom pin and ground of the DVI-connector. The brown color implies that component being burnt, especially because its nearby "friends" are all black. What kind is it? It says "Z6" on circuit board and C2 (or 02?) on the component itself.
                      OK, you found it! Those are protection diodes for the Video dvi input signal, you can remove the burnt one out and see if the 13 Ohms goes away. They are use for the surge and spike protection for the DVI, there should be similar setup for the VGA input also.
                      • hitz
                        • 36
                        • germany
                        #31
                        I removed the burnt one and reassembled the monitor as far as needed to test if it works now.
                        Plugged it in -> no LED, no starting possible.
                        I measured the Voltage of top 2 pins from the PSU: 1.11V giving me 1.27V on the circuit where the sources of the LED-MOSFETs and the OUT-pin of the regulator are in. Any new ideas? :/
                          Ok , so the 13 Ohms is no longer there? And unless I read it wrong, what voltage do you get now at the Out put of the regulator, it should be 3.3V as Jetadm had indicated.
                          • hitz
                            • 36
                            • germany
                            #33
                            13 Ohms gone, 338 Ohms now (guess from the regulator OUT-GND).
                            The voltage is the 1.27V I mentioned above (remeasure gave me 1.35V now), thats the circuit in which the sources of the status LED controllers are.
                              From the thread, it is indicated that this is a 3.3V regulator, same as the other one on this board, both of them has the same number printed on them, right? If that is the case, this one should also put out 3.3v, it could be damaged due to that 13 OHMS load. You were getting less than 0.5V before you found that shorted component.
                              • selldoor
                                Slow Learner
                                • Dec 2010
                                • 7870
                                #35
                                Did you test the regulator with the 9 volt battery? - post 22
                                • hitz
                                  • 36
                                  • germany
                                  #36
                                  Yes, i just did. New 9V battery (delivered 9.6V) attached to the regulator gave me 3.6V from OUT-pin.
                                    The ADJ pin connected to the Negative of the batteries, and put a 100 Ohms resistor between Out pin and negative of the batteries, then check the output reading again.
                                    • hitz
                                      • 36
                                      • germany
                                      #38
                                      Guess i just wrecked it. Shortened OUT and GND with my multimeter tip, 0V OUT since then.
                                        I still think this regulator is already bad, I would just get another one.
                                        By the way, when you were measuing 3.6V at the output pin, was the AGJ pin connected to the negative of the batteries, if not, that may explain why you are getting 3.6 instead of 3.3V
                                        • hitz
                                          • 36
                                          • germany
                                          #40
                                          I'll order some new, hope they will be delivered on saturday and 0.29€/pc is a good price
                                          I checked the voltage of the battery with my multimeter, positive 9.6V were shown, so I put the GND/ADJ pin to the battery terminal where the black tip was while measuring the voltage.
                                          • double_DD
                                            How can I be sure that my EC chip is dead?
                                            by double_DD
                                            As the title suggests, how can I be sure that my EC chip is really dead?
                                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                            03-12-2025, 07:47 AM
                                          • disorder
                                            ps5 edm-033 dead after hdmi/usb ports destroyed
                                            by disorder
                                            hello guys,
                                            i need help to repair a edm-033 ps2
                                            history : as always hdmi port and usb ports destroyed after unplugged
                                            after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                            so i changed it
                                            now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                            but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                            i don't see any projection of liquid metal on pcb.
                                            01-14-2025, 12:48 PM
                                          • zunasthegreat
                                            Chieftec GPS-450-AA with dead 20N60C3
                                            by zunasthegreat
                                            Hello everyone hope all doing well!
                                            I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                                            09-01-2024, 07:12 PM
                                          • Beton
                                            Finding a dead short component
                                            by Beton
                                            Hi guys!
                                            I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                                            So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                                            I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                                            I have a bench PSU and if I try to inject voltage the voltage...
                                            12-10-2021, 01:05 PM
                                          • FiguringITout
                                            MSI Raider GE75 - Not posting, probable dead CPU
                                            by FiguringITout
                                            Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
                                            Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
                                            07-25-2024, 07:27 AM
